Welcome to the North American Subaru Impreza Owners Club Wednesday February 19, 2020
Old 12-24-2019, 04:15 PM   #51
evilWagon
Member#: 128739
Originally Posted by TheNovaScotian View Post
I had the vibration in 4th and it got really bad at 10,000kms in my 2019 wrx.
Took it to dealer and they took out my transmission and took all kinds of measurements. They put it back in and told me they would contact me when there was a fix.
6 months later I got a call that the parts were in and it got fixed.
All vibration is gone in 4th. I think they said it was a shifting fork that was out of tolerance.
Can you share anymore details or the reciept for the work etc. From my recent research this is one of the only cases that's been fully resolved.
I understand a car company might not get something perfect but it's how they come to plate with the fix that makes the difference.
evilWagon is offline   Reply With Quote
Old 12-29-2019, 10:35 AM   #52
2018wrx_newbie
Member#: 477489
2018 WRX Limited
CWP
Would love to hear more details on this. You seem to be the only one that got this issue fixed. Please share.
2018wrx_newbie is offline   Reply With Quote
Old 12-29-2019, 05:15 PM   #53
Buffman
Member#: 189212
2019 WRX
I did notice when I went to the weighted grimmspeed knob, 4th gear vibration on the shifter was greatly reduced..
Buffman is offline   Reply With Quote
Old 01-05-2020, 10:49 PM   #54
psychos2
Member#: 414084
2015 wrx premium
crystal black silica
can you please give more info. I am having this problem and tech line says they have never seen it. thanks shawn
psychos2 is offline   Reply With Quote
Old 01-14-2020, 07:10 PM   #55
psychos2
Member#: 414084
2015 wrx premium
What dealership did you get it fixed at ?
Old 01-17-2020, 12:48 PM   #56
blane101
Member#: 510804
Any update on this? I've noticed that when shifting from 3 to 4, if you make some movement in neutral side to side it sometimes remedies the issue. There is certainly something not lining up correctly, I sometimes have the issue and sometimes it is completely gone and the gear is fully engaged. To add to everyone's dealership qualms, I went to a dealer and they did not acknowledge the issue, said they checked the AWD system and said everything is fine, also claimed it's due to the linkage style shifter on a WRX. Horrible Subaru dealer / "shop".
blane101 is offline   Reply With Quote
Old 01-18-2020, 08:18 PM   #57
mcorpsage
Member#: 510513
2019 WRX Series.Gray
Cool Gray Khaki
Default Same Issue in a 2019 WRX w/ STI short shifter
I am having the same vibration in 4th gear in a 2019 WRX with the STI short shifter. There is virtually no vibration in any other gear at any RPM. In 4th gear, between 2500 and 3500 RPM when accelerating the shifter vibrates pretty bad. At times it vibrates so much i can hear it rattling. Below 2500 and above 3500 and there is virtually no vibration. I contacted Subaru and they said they have never heard of the issue in a 2019...not that they hadn't head of the issue. I have a free oil change coming up soon at the dealer so i will ask them to take a look. I have the COBB stage 1 drivetrain package installed so i am concerned they are going to blame everything on that. I believe there would be issues in more than a very specific RPM range of a single gear if the COBB parts were to blame.
mcorpsage is offline   Reply With Quote
Old 01-18-2020, 10:30 PM   #58
psychos2
Member#: 414084
2015 wrx premium
I have a friend that is a tech at a subaru dealership. He is looking into it. When I find the solution I will be posting it everywhere. I have found a few forums where people got it fixed, but no one will reply when asked about it.
Old 01-19-2020, 12:38 AM   #59
2018wrx_newbie
Member#: 477489
2018 WRX Limited
CWP
Found this on Reddit. Also has a link to shop work order.
https://www.reddit.com/r/WRX/comment...ear_excessive/
Old 01-20-2020, 10:53 AM   #60
Norm Peterson
Member#: 498642
'19 WRX Limited 6M
'08 Mustang GT (the toy)
I have noticed the same thing, that a slight amount of lateral movement can sometimes stop the vibration. Also that slight forward movement of the lever can accomplish the same thing, but neither movement works all the time. I don't like the idea of forward movement, as that's directly in a direction to disengage 4th, but taking the two movement solutions together may shed some light on what's going on.
This vibration, which has never been visible or audible in our '19 Limited, has always been something that could be felt in 4th, and on rare occasion 3rd (typically while investigating the 4th gear issue to see if it showed up anywhere else). Both my wife and I have noticed it (I think she was the first to notice it). We did note it as something for service to check when taking the car in for a sound system issue, but didn't get any solution or satisfaction concerning this issue.
Now before the "you're not doing it right" crowd chimes in, this vibration is something that you can detect with a very light fingertip touch where you aren't holding or moving the lever at all. If you're paying enough attention while you are about to make a shift out of 4th you can feel this little buzz as you're going through the process of grabbing the gearshift knob before you're actually moving the lever at all.
I've been driving stick-shift transmission cars since 1963, and almost exclusively stick-shift since 1972. This model WRX is the only car in all that time where shifter vibration has been noticeable.
Norm
Norm Peterson is offline   Reply With Quote
Old 01-20-2020, 11:43 AM   #61
Norm Peterson
Member#: 498642
'19 WRX Limited 6M
Originally Posted by SirBrass View Post
In 4th gear, you're pushing the cable forward. If you jiggle the shifter within the boundaries of the gate, you'll find the vibration disappears when you push the shifter within that "zone" forward about 1mm.
This tells me that something along the cable line is contacting a vibrating surface when in 4th.
I'm wondering if it could be more involved than just that. Seems to me if it was that simple that a change in just that one cable that's under compression in 4th might have fixed things.
What I'm thinking is that the other cable is in a condition of little or no tension or compression because 3-4 is the gate that the shifter naturally seeks.
Has anybody noticed whether the vibration at the shift knob is mostly fore-aft in nature or mostly lateral? Knowing which might help point to where the problem lies.
Unfortunately, it appears you can't disassemble the shifter assembly. Otherwise, there might be something you could do, like an easy way of introducing a little friction at the pivot to help damp out the vibrations going up the lever. Looking for a fix here, whether Subaru-approved or not (old hotrodder attitude).
Norm
Old 01-21-2020, 02:30 PM   #62
blane101
Member#: 510804
Please let me know how you make out. Also, where in the US?
Old 01-23-2020, 02:11 PM   #63
psychos2
Member#: 414084
2015 wrx premium
The dealership is in Saratoga Springs NY.
Old 01-27-2020, 03:06 PM   #64
blane101
Member#: 510804
Any update? I'm bringing my car in on Wednesday, we'll see what this dealer says.
Old 01-28-2020, 10:45 PM   #65
2018wrx_newbie
Member#: 477489
2018 WRX Limited
CWP
Seems like it is very difficult to get any info on this issue. Curious to hear more if anyone has had any success getting this fixed.
Old 01-29-2020, 10:56 PM   #66
blane101
Member#: 510804
Went to dealer today. Service manager knew exactly what the issue was before even test driving it. Turns out to be a damaged bushing on one of the transmission forks. They have made this repair before and is very common. Also occurs in the 2014 Crosstrek. Test drove the car, verified the issued and ordered the parts for me, should be in sometime next week and will take a few days to install. All covered under power train warranty. 2018 WRX limited, no mods, 19,000 miles, noticed the issue almost a year ago.
So happy to have found a solution. I'll follow up in a few weeks on the outcome of the repair, but sounds very promising.
Old 01-30-2020, 01:51 PM   #67
Subidoo19
Member#: 487386
2019 WRX Limited
WR Blue Pearl
If you get this taken care of, would you mind posting a work order/invoice? Then we can have something to refer to when they claim this is "normal". I, along with a lot of others, have been told by the dealership that there is nothing wrong and vibration is normal in 4th gear. Even though mine is audible and somewhat visible through the shifter, depending on the rev range.
I'm glad you were able to see some progress on your end! That does sound very promising.
Subidoo19 is offline   Reply With Quote
Old 02-03-2020, 03:50 PM   #68
psychos2
Member#: 414084
2015 wrx premium
What is the name of the dealership and the service manager that you talked to. Thanks Shawn
Old 02-09-2020, 10:42 AM   #69
blane101
Member#: 510804
Got my car back on Friday. Issue resolved, they replaced the 3/4 fork in the transmission. All under warranty.
Old 02-10-2020, 01:49 PM   #70
psychos2
Member#: 414084
2015 wrx premium
What dealership?
Old 02-12-2020, 11:10 AM   #71
psychos2
Member#: 414084
2015 wrx premium
How come anyone that gets this fixed will only post , that they got it fixed. Would be nice to get a little more info like where. What dealership , service managers name.
Old 02-12-2020, 12:14 PM   #72
Norm Peterson
Member#: 498642
'19 WRX Limited 6M
Better yet would be if there's a TSB out on it, and if so what its number might be. That way the individual dealership service department wouldn't matter.
Norm
Old 02-12-2020, 10:18 PM   #73
blane101
Member#: 510804
All American Subaru in Old Bridge NJ. There is a TSB, but not sure what it is. If your close to NJ, just go there, or at least call, they are very helpful. It's under warranty and you get a loaner car.
Old 02-13-2020, 08:09 AM   #74
Norm Peterson
Member#: 498642
'19 WRX Limited 6M
Thanks.
Old Bridge, hmmmm . . . can't be too far from what used to be known as Englishtown.
Norm
Old 02-13-2020, 01:52 PM   #75
psychos2
Member#: 414084
2015 wrx premium
