Welcome to the North American Subaru Impreza Owners Club Thursday June 17, 2021
Old 02-10-2020, 05:38 AM   #1
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Default DR20Tís MY00 Australian GC8 WRX Build - POZ35D
Hi All,
Been around here for a while - previously had the version 10 GRB spec c ej207 in an MY04 Australian delivered Liberty (Legacy) GT.
Sold that a couple of years back and moved away from Subarus for a while. Had an Audi s3 with stage 2 mods etc but found that really mundane and boring to be honest. Was lucky enough to get a new work car so found this little beauty as a weekend car.
Decided to start a build thread for my new project - itís an Australian delivered MY00 WRX. Have owned it for about 7 months.
This is how I bought her:
What it came with:
OEM EJ205 with BOV and 3Ē TBE
Unknown coilovers with BC springs 10kg Front 8kg rear (I think theyíre the maxspeeding rods nasty ones)
Replica recaro seats
Rays engineering Sti RS Zero (S201) 17x7.5 forged monoblock wheels with RE003 tyres all round
Rebuilt 5 speed box with short shifter and hd exedy clutch
Dba T2ís all round and I think bendix pads
Carbon fibre sti front strut brace and white line rear strut bar
JDM sti tailights
JDM Sti cluster
Sound system (alpine amp and 12Ē sub with four kicker speakers and pioneer headunit with Bluetooth)
Various autometer gauges
Well it didnít take long for the bug to bite again and in the first three weeks of ownership I purchased the following for her:
JDM V8 EJ207 Sti complete engine
Aus spec ej207 ecu and transponder etc
2002 full wiring harness for wiring merge job
PPG loaded 5 speed (straight cut 1/2 and helical 3/4 - synchro not dog engagement)
VF48 (will throw twin scroll housing on this to use with my twin scroll jdm headers) - ended up running the vf37 noting theyíre internally exactly the same with a differnt housing obviously for twin scroll
Arp 2000 head studs
2015 STi OEM TMIC
Mishimoto silicon kit
Custom CAI with AEM dryflow filter in inner guard
GFB Respons adjustable BOV
AP Suretrac r160 LSD diff (need to change pinion and crown to suit 3.54 ratio)
Id1300x injectors
Walbro 460
Raceworks Surge tank setup and AN fittings
Radium fuel rail kit and torque solutions fittings and lines
Process West splitter for gc8 (to suit wider tmic)
Twin scroll bell mouth dump pipe starter (will weld to my existing 3Ē dumpĒ
Various new gaskets etc to suit above
Killer B sump baffle
Pierburg 3 port bcs
DBA T3 front rotors
Winmax w5 front pads
Dot 5.1 fluid
Kap industries fire extinguisher mount
Genuine JDM V5 Type R alloy control arms
JDM GC8 Sti quick steering rack
New MCA Reds valved / sprung for my setup
And most importantly - new ledís for the interior...
Also bought a set of 22b pedals which are in pretty good condition (have the wider bottom accelerator pedal for heel / toe)
Plan is to use this as a weekend car with 4-6 track days a year
Have installed all of the above and loaded the latest Carberry 16 bit rom on there (4.2) - have been tuning the rom and have recently rescaled the maf accurately - itís now making 342g/second and 3.91 g/rev load - which is pretty cool for a vf37 e85 setup.
I have also purchased a genuine Garrett GTX2867 Gen 2 which I will be putting a kinugawa twin scroll housing on to suit the stock jdm twin scroll headers (stock location) - waiting on the housing to become available again so this is on hold until then.
Any thoughts and advice welcome
Cheers
Mick
dr20t is offline   Reply With Quote
Old 02-10-2020, 09:21 AM   #2
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Awesome build mate!
CEEBEE is offline   Reply With Quote
Old 02-10-2020, 09:21 AM   #3
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
More photo's please...
Old 02-10-2020, 05:51 PM   #4
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Thanks mate.
Here are some more pics. The engine bay pic was a couple of weeks ago so some things have been cleaned up and changed since then
Also - didnít mention but I also bought another gc8 in world rally blue. This had a blown engine so i threw my stock ej205 motor from the silver one into this and sheís running great.
Bonus was the genuine sti lip and fog light covers, jdm sti type r 4.44 5 speed and rear diff and a few other little bits and bobs. This was is going to be a keeper for storage.
Old 02-13-2020, 11:39 PM   #5
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
So Iíve scaled my maf pretty close with corrections / learning now down to under 3% either way
Iíve got it setup to switch from map to SD at 10psi boost (24.7psia) with 85% blending from 0psi boost (14.7psia)
Logged a second gear pull onto freeway ramp today and the car jumped a little after hitting a slight bump - revs jumped from 7300 to 7645 in next log line, and airflow g/s went from 348g/s to 379.
Can someone help me explain what I perceive to be an inaccurate airflow reading seeing as my maf is scaled?
Or is perhaps my maf scaling out at higher voltage but Iím not seeing it because my final fuel base is changing due to the switch to SD at 10psi boost?
If my last comment / question is confirmed, this would explain the high reading right?
Canít see how a vf37 at 22psi tapering to 18.5 can be making that sort of hp
Mick
Old 02-15-2020, 06:33 PM   #6
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
You should fix your links so they show the pic in your thread, so no one has to click any of the links.
Fierysun is offline   Reply With Quote
Old 02-15-2020, 07:05 PM   #7
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
I did it on the app so itís showing for me on here in the thread. Do I just add image tags to them?
Old 02-16-2020, 01:59 PM   #8
fitzgerald_moto
Member#: 500292
Default GC8 Doors
Hey mate,
Beautiful ride and work.
Can anyone advise if GC8 sedan front doors also be used on a 2.5 coupe? Picking up some front doors from a sedan and want to make sure they're can swap out without issue.
fitzgerald_moto is offline   Reply With Quote
Old 02-16-2020, 02:36 PM   #9
Aczwild
Member#: 71721
98 RSTi, 00 RS
13 Sierra
Originally Posted by fitzgerald_moto View Post
Hey mate,
No, the coupe and sedan doors are different in length.
To the OP, nice little old school Impreza. These cars really are the best and it looks like you have a real nice starting point for an awesome car long term.
Aczwild is offline   Reply With Quote
Old 02-16-2020, 07:16 PM   #10
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Hey mate,
Thanks mate.
Yes as stated coupe and sedan door differnt lengths.
You lucky bastards in the US got the 2.5rs two door
A 2 door was only released as a v5 sti in Australia - 300 of them released.
These fetch anywhere from $45,000 to $100,000 now in Australia depending on condition and originality!
Mick
Old 02-19-2020, 03:26 AM   #11
bigBADbenny
Member#: 314324
MY07 Lib GTB 6MT Wag
Two much is never enough!
Looking forward to the updates mate
bigBADbenny is offline   Reply With Quote
Old 02-19-2020, 08:38 AM   #12
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Haha indeed
Thanks Benny
Change of course. Kinugawa twin scroll housing on long back order with no eta on availability.
So Iíve purchased a Blouch 1.5xtr twin scroll
Will be here later this week and hopefully on next weekend.
Hoping to squeeze over 300awkw out of this on e85
Will update once done
Any thoughts on my previous question re: maf g/s?
Mick
Old 02-24-2020, 05:33 AM   #13
bigBADbenny
Member#: 314324
I'd ask terryjr of exotruck foz fame on rs25 or rr forum.
Old 02-28-2020, 11:02 AM   #14
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Iíd ask terryjr of exotruck foz fame on rs25 or rr forum.
ask away
no694terry is offline   Reply With Quote
Old 02-29-2020, 06:33 AM   #15
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Mick
Thanks Terry - was referring to this.....
Old 03-02-2020, 02:55 AM   #16
bigBADbenny
Member#: 314324
Mick, youíve had this issue (blip/blank in rpm in logs) before, with the Lib/Leg.
Was it the stock location lift pump choking on the restrictive stock jet pump?
Old 03-02-2020, 08:49 PM   #17
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Good memory. But that was completely different. Car is actually running great. Just the question regarding reading of maf g/s with a blended carberry rom.
The lib had a stumble at transition from vacuum to boost which I ended up putting down to the twist mount adapter
Mick
Old 03-10-2020, 12:07 PM   #18
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
So I've purchased a Blouch 1.5xtr twin scroll
Do you have a part # for the Kinugawa turbine housing? This is the exact setup that I've been searching for (Gen 2 GTX2867R mated to a JDM twin scroll housing). It's too bad that ATP doesn't sell a twin scroll housing anymore.
I also considered the Blouch 1.5 XT-R out of convenience, but I think it's a little too large for the responsiveness that I'm after. I'd be content with ~400whp on E85.
Thanks for the assistance. Good luck with your build! Cant wait to see the results.
Edit: I reached out to Kinugawa and they only plan to offer twin entry (not twin scroll) housings for some of the GT lineup (Garrett GT3071R & HKS 2835). My search for my ideal twin scroll turbo will continue
WRXnick16 is offline   Reply With Quote
Old 03-10-2020, 04:50 PM   #19
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Yeah unfortunately they came to me in February and said the back order is indefinite. They had one listed on their store and when I went to order it in November, it was unavailable. Was told production would resume in January then well that changed.
Thanks for your kind words. My thinking was aligned with yours initially around response vs power - hopefully not giving too much up with the Blouch but will update once im done tuning.
Mick
Old 04-19-2020, 10:47 PM   #20
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
So the Blouch 1.5 xtr twin scroll is in. Had an issue with the coolant pipe hitting the GRB STI intercooler - some bending of the pipe fixed that.
Absolutely love this turbo. I honestly feel like itís more responsive off boost than the vf37 - I put that down to reduced back pressure from the larger wheel and housing so the avcs can be optimized better to allow the engine to breathe thus improve VE. This is supported by me having to fine tweak my open loop fueling and VE table at 0-10psi
Running 24psi I clicked 4.27 g/rev load and looks like the maf is maxed out at 399.99g/s airflow. Thatís running 15 degrees in the midrange and 22 up top. So a little more headroom.
Overall really happy with this turbo. Just need to fix a slight stumble at 5-7psi which I believe is related to the load smoothing due my blended mad/sd tune on carberry.
Mick
Old 04-20-2020, 04:34 AM   #21
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Edit - never mind
Old 04-20-2020, 07:46 AM   #22
Foo_Blyat
Member#: 93750
Your car is beautiful! She's so clean and rust free too. Looks half her age
Foo_Blyat is offline   Reply With Quote
Old 04-21-2020, 01:55 AM   #23
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Thanks mate - I do love the tidiness of the car. I have to clean up the engine bay a little better to my liking but slowly
Changed plugs today.
Here are how the iridium plugs that were in there before look:
Old 04-24-2020, 03:24 PM   #24
RhdBugeye10
Member#: 496047
Clean car, love the build man
RhdBugeye10 is offline   Reply With Quote
Old 04-26-2020, 08:06 AM   #25
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Thanks mate
Will be doing a few little things this week hopefully and update as I go
Mick
