Welcome to the North American Subaru Impreza Owners Club Saturday February 22, 2020
Old 01-22-2020, 11:52 AM   #3176
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Originally Posted by kg23 View Post
Warranty work was done less than 4 years ago. The warranty on that work is apparently whatever they decide.
Short block warranty is whichever is greater of the following:
Remainder of factory 5 year, 60,000 powertrain warranty
3 years or 36,000 miles
1 year unlimited mileage.
The warranty for your repair has expired on all 3 counts
RexyGirl is offline   Reply With Quote
Old 02-14-2020, 12:23 AM   #3177
PilotKD
Member#: 131702
2017 WRX Premium
CWP
Make: '17 WRX
Mileage: 27k
Time Out Of Use: n/a
Problem And Likely Cause: Chirping throw-out bearing (TSB), unacceptable rattle behind headunit, broken rear cupholder
Modifications: None
Submitted For Warranty Work (Yes/No): No
Reason Given For Denial: Despite TSB, dealer claims noise is not indicative of a problem with the throw-out bearing and will not replace it under warranty. Dealer says diagnostic for rattling noise behind headunit will be $100 and didn't give me a warm fuzzy anything would be covered under warranty, even if they found and fixed the issue. They gave me a price to fix the rear cupholder and never mentioned or offered to pay for it under warranty.
Your Story: This is mainly about the throw-out bearing. Bought the car used with about 25k miles. About a week after I got the car, I started hearing a chirping sound coming from underneath the car. I actually heard it while I was going through a drive-through as the sound was bouncing off the building and being amplified. I actually pulled over in the parking lot to figure out where it was coming from and discovered it was the throw-out bearing after I found pressing on the clutch pedal stopped the noise. Did some searching online and found the threads and TSB about it. I took a few vids on my phone over the course of a few weeks and brought that to the dealer with the TSB.
So I guess that is how it works these days. You own a $30k+ car with issues and have to play hardball to get them to honor the warranty that every car manufacturer touts as some sort of good thing.
PilotKD is online now   Reply With Quote
Old 02-14-2020, 11:01 AM   #3178
2018wrx_newbie
Member#: 477489
2018 WRX Limited
CWP
Take it to a different dealer.
Originally Posted by PilotKD View Post
Make: '17 WRX
Mileage: 27k
Modifications: None
2018wrx_newbie is offline   Reply With Quote
Old 02-14-2020, 12:15 PM   #3179
PilotKD
Member#: 131702
2017 WRX Premium
CWP
Already scheduled.
Old 02-15-2020, 12:26 PM   #3180
ImprezziveRex
Member#: 124788
2018 WRX
Make: '18 WRX limited
Mileage: 7300k
Time Out Of Use: None yet
Problem And Likely Cause: Car threw a check engine light yesterday (Friday 2/14) morning. Result of code P0172 System too rich bank 1
Modifications: Cobb Stage 1 + (big sf intake)
Submitted For Warranty Work (Yes/No): Yes
Reason Given For Denial: Was told that "vehicle is currently modified and thus not covered by warranty"
Your Story: So yesterday morning I wake up to a Christmas tree on my panel. Check engine light, blinking cruise control light, hill assist, etc. I schedule an appt at my local subaru dealership for around lunch time. At my appt they check the code and find the above and then start to look for the cause. Eventually they get to checking the software for upgrades and find that I have a modified tune. At this point they call subaru (guessing SOA?) who tells them that because of the modified tune they are to stop working immediately and return the car to me. They never even find the root cause of the code. ALSO they tell me that my "vehicle factory powertrain and emissions warranty is now void due to modified tuning." They provided me a case number for the "modification form" they submitted to I think contact SOA?
I realize this seems very odd since all I have heard about is people being denied warranty work due to mods but this dealership just told me that not only would they not continue working on the car but that I would need to seek out a third part subaru mechanic to do future work (on powertrain and emmisions items). I still don't know what is throwing the code but I guess that is for me to now discover.
Obviously this sucks since I have a 10 year extended warranty on my car (and yes I realize I was playing with fire by going any stage on my car with this warranty). All of the other components are still covered but anything powertrain and emmisions is no longer. The service manager basically said I should cancel my warranty if this was going to be a big problem.
Anyone have any thoughts on this?
ImprezziveRex is offline   Reply With Quote
Old 02-15-2020, 01:51 PM   #3181
n2oiroc
Member#: 141952
18 golf arrrr!
Mileage: 7300k
not much you can do aside from find an independent shop. i also agree with getting a refund on the warranty. im sure you can find another dealer to work on the car, but you are going to be paying out of pocket for it.
n2oiroc is online now   Reply With Quote
Old 02-15-2020, 02:56 PM   #3182
ImprezziveRex
Member#: 124788
2018 WRX
I haven't read all 132 pages but I thought the whole idea that they couldn't "void" your warranty was the main theme at yet here I stand?
Old 02-15-2020, 04:04 PM   #3183
Supraru
Member#: 23313
99' 2.5Rs
black
Mileage: 7300k
Sounds like you didn't do your homework before you modded your car. Dealerships don't want to deal with your aftermarket intake and aftermarket tune. They will tell you to put it back to stock. If the light comes on then they will diagnose the car. They aren't going to waste their time if there's an issue with a tune that they had nothing to do with.
Supraru is offline   Reply With Quote
Old 02-15-2020, 04:40 PM   #3184
n2oiroc
Member#: 141952
18 golf arrrr!
they cant void your warranty for using non oem parts that meet oem specs. oil filters and oil for example. changing the tune certainly voids the warranty because it makes the engine run outside of its designed parameters. more boost and power it wasnt designed for. they have no way of knowing if the tune is good or not.
Old 02-16-2020, 09:07 AM   #3185
PilotKD
Member#: 131702
2017 WRX Premium
CWP
"According to the Magnuson-Moss Act, a vehicle manufacturer cannot automatically cancel your warranty just because you’ve installed aftermarket car parts. This is an illegal practice. That said, if your aftermarket part somehow causes or contributes to a failure in your vehicle, the dealer may be able to deny your warranty claim—as long as they can prove the connection. In these cases, the burden of proof is entirely on the dealership."
Most of us have known this for years, but we all know the MMA is a bunch of BS. "The burden of proof is entirely on the dealership". Yeah right. The only way to win in these situations is to pony up with an attorney that specializes in these things and go after Subaru of America.
QUESTION: Once you flash your car with an AP, am I correct in saying that you cannot put the ECU back to stock (even if you flash the "stock" Cobb flash map)? The dealer can see that you have flashed the ECU forever, correct?
Old 02-17-2020, 02:06 PM   #3186
absubie
Member#: 196235
2016 WRX Limited
Pure Red
From everything I have read, there is simply a logged count of ignition cycles or something along those lines, which is reset upon a reflash or complete loss of power to the ECU. When you uninstall the AP it flashes the copy of your original map it takes during install - as I understand it.
absubie is offline   Reply With Quote
Old 02-18-2020, 04:43 PM   #3187
MadScientist84
Member#: 468911
2016 WRX Premium 6MT
Mileage: 7300k
The code is indicative of a dirty MAF no doubt caused by the oiled filter element. I have a K&N drop in, and i normally clean the MAF every OC because if i don't, I'll (sometimes) get that code after every 7K miles (every other OC). Once i clean it, it is fine until i have to recharge the filter or i go longer than 7K miles without cleaning it.
I 2nd the canceling the warranty as it is now worthless, as the dealership sent in paper work to flag your VIN.
MadScientist84 is offline   Reply With Quote
Trouble/Warranty Denial Report Thread: Electrical (Lighting, ECU, Sensors, Etc.) North Ursalia Warranty Issues & SOA Problems 141 10-26-2019 01:59 PM
Trouble/Warranty Denial Report Thread: Suspension North Ursalia Warranty Issues & SOA Problems 58 10-19-2019 05:03 PM
Trouble/Warranty Denial Report Thread: Braking System North Ursalia Warranty Issues & SOA Problems 97 09-27-2019 01:46 PM
Trouble/Warranty Denial Report Thread: Body/Exterior of Vehicle North Ursalia Warranty Issues & SOA Problems 146 03-02-2019 01:31 PM
Trouble/Warranty Denial Report Thread: Interior North Ursalia Warranty Issues & SOA Problems 71 11-14-2018 09:18 AM
