Welcome to the North American Subaru Impreza Owners Club Thursday February 27, 2020
Old 02-11-2020, 06:19 PM   #76
08redWRX
Member#: 186068
2019 STi
Originally Posted by grumble_ae86 View Post
After a failed ej205 swap, i've decided to do this in my coupe. 2021 my Impreza becomes exempt from inspection. I plan on using a locally sourced 4g63 mated to a 15+ sti transmission while retaining my oem interior harness. I plan on getting a haltech from iwire and delve deep into the evo+nasioc forums to successfully build this abomination. Any and all advices are welcome. Keep your criticism to yourself. I have a wallet to burn. If you like it, good. If you hate it, good. Gapplebees for everyone
Good luck! Will look forward to the outcome. Hopefully you start a new thread to show the progress.
08redWRX is offline   Reply With Quote
Old 02-11-2020, 06:43 PM   #77
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
This is a crazy amount of work at a very high cost. Good luck.
Old 02-12-2020, 09:54 AM   #78
grumble_ae86
Member#: 487293
1996 Impreza L, 2.2L
I honestly don't think its too much work. Custom fab on mounts and getting an adapter from tpg would be the hardest part for the build. Wiring can be easy if I try to be meticulous. Finding crashed sti's at auction sites are plentiful. Worst case scenario, go for a 06-07 sti dccd from jspec. I'm roughly looking at 12-13k at most. Engine is around 1500-2000. Haltech for 2-3000. Sti transmission+diff+axles for another 3-4000. Rest is all labour at Dialed In Performance up here, in Rochester. The 4g63 is tall, but not as tall as the k series. And if a 2jz fits, height wise, the 4g63 should as well. Roughly similar height by what i've seen from dimensions. At most a custom oil pan for better oil pickup/baffle and subframe clearance. Even then I don't see this build going past 16-17k. Power goal is (a reliable and robust) 500whp max. I've actually willed it up for the car to be scrapped if I unfortunately pass away lol.
For my spirited driving, I don't trust H4 at all anymore. Even professionally built motors fail. Which not to mention end up costing almost similar to this build.
grumble_ae86 is offline   Reply With Quote
Old 02-12-2020, 02:33 PM   #79
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Likely will be less work than you think. LS1....been done. The old school Honda guys would make that 4g63 fed by Weber down draft ITBs. Wait...you also mentioned a K swap in passing.
Old 02-12-2020, 02:40 PM   #80
Fierysun
Member#: 82745
2005 Subaru STI
That's a ton of work for only 500whp, which the EJ is solid at with a good build, tune and spot on owner upkeep/maintenance. The EJ is not one of those motors you can just abuse like the LS, however it's a great motor if you keep it where it wants to be.
Old 02-12-2020, 04:13 PM   #81
Jedi03
Member#: 491095
2009 STi Blue
i like my EJ as well, but the 4G has been around since early 90s iirc, it has been tried and true without blowing up on several cars...regardless of the outcome this will be fun to watch!
Jedi03 is online now   Reply With Quote
Old 02-12-2020, 05:03 PM   #82
AmericanJager
Member#: 487006
2015 WRX
It was only a matter of time, like Rob Dahm's rotary c7 build. Looking forward to see what this looks like.
AmericanJager is offline   Reply With Quote
Old 02-12-2020, 05:23 PM   #83
nealric
Member#: 450518
2016 STI
Arrest Me Red
I don't know why you'd bother with this engine swap if you are trying to make big power. The 4g63 isn't all that much more robust than the EJ, especially if you address the EJ's weakspots (which would be cheaper/easier than everything that would need to be done for a 4g).
If your goal is to make big power reliably, you want a bigger motor- not a smaller one. There's a reason why most pick the LS. They are compact, relatively light weight, cheap, reliable, and have excellent parts support. Makes 400hp in tame OEM spec and 1,000+ fairly easily.
nealric is offline   Reply With Quote
Old 02-13-2020, 02:22 PM   #84
BurninSTI
Member#: 510655
Watch out for the subinati
BurninSTI is offline   Reply With Quote
Old 02-13-2020, 02:41 PM   #85
grumble_ae86
Member#: 487293
Ls1, 2jz, any other v-engine, i6-engine, requires firewall reconstruction. Im not going to compromise anything with another 4 banger. People have done rotary swaps, k-swaps, sr20 swaps for almost equivalent value. Plus, I still want to drive this legally on the streets, beat it at the auto-x, etc. At the end of the day, imo, it comes to keeping true to the rally heritage and my 2-digit iq brain wants to make the best of both worlds. If I could, i'd use a 3sgte. But parts are scarce, and engine's going north of 5k min, with high mileage. 3sgte is ideal because celica gt-fours had tmic as well. But my Toyota knowledge is low, and I know no one near me who deals with them.
Ej requires 2x maintenance than a 4g63. Im sure, if not a lot, a few of you will agree with it.
Just enjoy the build. And the loss of countless 10mm's.
Old 02-13-2020, 03:43 PM   #86
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
You do realize that the 2JZ swapped subarus don't use the Subaru transmission, correct? Paying a shop to custom fab something is not cheap if it has yet to be done. Without a jig there are hours in just measuring **** to make sure the geometry is 100% correct.
Turpid Porpoise is offline   Reply With Quote
Old 02-13-2020, 05:36 PM   #87
grumble_ae86
Member#: 487293
Yeah, that's why i'm having an adapting plate fabbed up to mate with a sti transmission. I rather fab that than a transmission mount+undercarriage
Old 02-13-2020, 05:45 PM   #88
4S-TURBO
Member#: 67807
.... Fred Dryer as
---HUNTER--->
K swap.
Old 02-14-2020, 03:00 PM   #89
Turpid Porpoise
Member#: 476573
You will still have to fabricate motor mounts and probably a cooling solution since the engine will now overhang the front axle by the length of 2 more cylinders.
If it were my car, I'd much rather chop and reweld the tunnel to accommodate a transverse 4g63/EVO transmission than try to fabricate the motor mounts and re-engineer the cooling system to account for the extra length of the drivetrain.
Not to deter you or throw shade as I respect anyone who wants to fab something unique but I really don't see the point in this. Why not just buy an EVO? The subaru chassis really isn't anything special and by the time it's all said and done you'll probably be looking at the cost of a used EVO.
Old 02-14-2020, 03:27 PM   #90
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
bmxhotsauce is offline   Reply With Quote
Old 02-14-2020, 03:28 PM   #91
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
Old 02-14-2020, 04:40 PM   #92
Turpid Porpoise
Member#: 476573
Originally Posted by bmxhotsauce View Post
Very well executed swap but an R32 is a much better chassis than a GRB.
Old 02-14-2020, 09:38 PM   #93
grumble_ae86
Member#: 487293
Its that 'first car' itch. Always want to keep it and do dumb stuff with it. Similar to that k-swap video actually. He made custom adapter, custom mounts. I disliked the subframe cutting and adding washers. Makes it unsafe. Will have to do lots of fitments prior to dropping it in, one last time. I'm prepared for it. I'll be done with my university, a steady job after and just work on the car everyday. That's how it has always been for enthusiasts and I don't expect it to be any easier.
STi and EVO pad swap? 06steelgraysti Brakes, Steering & Suspension 4 12-09-2007 07:42 PM
2003 Evo 4g63 For Sale Venom911 Engine/Power/Exhaust 8 01-04-2007 05:05 PM
FS: 89 Plymouth Colt with 4g63 swap FAST! Aspen_2.5RS Private Vehicle 'For Sale' Classifieds 8 10-21-2006 02:33 AM
EG Civic with 4G63 swap on eBay. :eek: rice h8r Off-Topic 20 06-30-2006 05:16 AM
4g63 swap into a justy ?? v8mazda Subaru Conversions 6 11-08-2003 07:09 AM
