Welcome to the North American Subaru Impreza Owners Club Tuesday April 13, 2021
Old 06-06-2019, 10:07 AM   #51
pennswoodsed
Member#: 86205
1997 obs ,T?
Greyish ,greenish
Sure ,
With enough boost (30psi?) and fuel ! and the right cam and turbo(s) I don't think a stock block and crank ,etc would take it for too long !
pennswoodsed is offline   Reply With Quote
Old 06-06-2019, 02:01 PM   #52
pcampbell
Member#: 437670
2005 2.5 SC OB
Default Subaru Cylinder Head Flow Database
Well I meant the heads not the block. I think I found someone who did nearly that much.
https://forums.nasioc.com/forums/sho...highlight=sohc
pcampbell is offline   Reply With Quote
Old 10-31-2019, 11:10 AM   #53
pcampbell
Member#: 437670
2005 2.5 SC OB
What is the cost to have a head or intake flow tested?
Old 03-25-2020, 09:09 AM   #54
Stoni23
Member#: 488540
2003 Wrx
Originally Posted by ASF Machine View Post
Patience young padowan.
You guys here are pretty knowledgable, can yall help??
https://forums.nasioc.com/forums/showthread.php?t=2918706
Link to my 03 build thread. Have a jdm longblock and whatever is in the wrx atm jdm or usdm idk but have two sets of heads. Idk which to use, maybe yall can help with the phasing stuff too, not sure what phase engines I have
Stoni23 is offline   Reply With Quote
Old 03-25-2020, 10:08 AM   #55
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
https://forums.nasioc.com/forums/sho....php?t=2918706
Iirc anything with a 6 bolt bell housing is phase 1 if it's a usdm chassis you need to run the usdm heads or adapt the hall effect sensor. Or convert your ECU to JDM setup.
Old 03-25-2020, 10:19 AM   #56
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Originally Posted by gunt View Post
these questions could be answered somewhere [ i have spent a good time looking ] but as with the bore size , i have a question with regards to troth size , on std valves size are you increasing it if so how much [ some might not like to say by how much ] we usually get to open them by 1mm on std valves on other brand engines / and this is where i wonder does everyone increase troth size when using bigger valves or are new bigger seats or keeping std troth to increase venturi ,
i seen someone rote that the newer std heads are flowing near b16a head figures , this is a point where i see subaru lacking as these cfm figures obivouslly flow perfectlly adiquatlly for 16-1800cc and the increase in subaru cc only increase the restriction and therfore the hugh fall off in what we see the graphs , cam are really only an attempt to sort the issue
has anyone got a set of cams cut to suit the head they have flowed
Cheers
I have the d25 heads ported Chambers all matched to (52cc) on a 100mm bore extensive bowl porting with 1mm added before the valve seats. Blended into the ports with extensive matching to the dog leg and straight port exhaust ports. Std aftermarket valves GSC super alloy valves, GSC s2 cams and they do great shimmed GSC beehive springs. On a 6466 turbo. I'm very happy with the combo. Great response great flow all throughout the rpm range.
If you look you'll see that GSC s2 cams are basically a equal grind to a jdm big port cam.
Old 01-16-2021, 08:54 AM   #57
Kremer930
Member#: 349916
2008 WRX Sti Spec R
WRC blue
Default IAG stage 5 heads vs Crest cast heads
Hi. Thanks for the useful thread with flow rates. Does anyone know what a dual avcs 257 head flows with plus 1 valves and 272 Kelford cams vs IAG stage 5 vs the Crest CNC cast heads? Thanks
Kremer930 is offline   Reply With Quote
Old 02-22-2021, 08:55 PM   #58
Scargod
Member#: 260314
2007 STI
silver gray metallic
W25 heads: I ported and unshrouded the heads myself. They were CC'd and bench flowed after Supertech +1mm valves were installed. Assembly work and testing was done by Heads Up Machine in NY.
Flow average of 284/219 @ .445" lift
Kelford 220-C cams (272/268 for DAVCS).
My engine made 470 HP on 24.0 PSI, running Premium gas with Torco additive.
Scargod is offline   Reply With Quote
Subaru Cylinder Head Info+ Specs cribbie Built Motor Discussion 7 11-21-2018 11:53 PM
EJ205 heads flow? leighton1245 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-06-2010 09:34 AM
subaru cylinder heads TimBeeno Private 'Wanted' Classifieds 2 09-27-2007 11:45 PM
Cylinder Head Flow Bench nkeehn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-18-2003 05:34 AM
Air flow data - Cylinder Heads Trey Technical Forum Archive 16 08-10-2000 11:38 AM
