Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2020
Old 05-05-2020, 09:18 PM   #1
Padawan
Member#: 406834
Exclamation Need a hero - Intermittent cranking, no start, no spark
Two days ago, my 2006 WRX started up, went ten feet, died, and wouldn't restart. Thinking it was too low on fuel, I came back to it several hours later, added five gallons and it started on the first crank.
I drove several miles home and it ran perfectly fine, but a few hours later, it again would crank but not start. The next morning, it started right up, I drove several more miles as a test, parked it, then started it up again a few times. I left it idling for a short while, and when I came back to it, it had stalled and now will no longer start at all no matter how long it sits.
Here is what I've tried and observed, plus some misc. info:
  • Car is stock (195k miles), and has been running fine with no codes
  • Tried a brand new crank position sensor - no change
  • Battery is full charged
  • All fuses are good
  • I can hear the fuel pump whirring normally when the key is switched on, and smell fuel after it cranks for a while
  • I pulled one of the plugs and it is not sparking. It was wet from fuel (I dried it before testing for spark), so fuel is definitely making it to the cylinders
  • I have a new FPR on order but am very confident this is electrical
  • OBD tool shows no codes, all sensors ready. The ECU accepts a flash (stock BIN) using ECUFlash, and has been running the same BIN for roughly 60k miles.
Any thoughts on how I can further troubleshoot this would be a godsend. With no codes and no apparent faulty components, I'm really at a loss. Is it possible the ECU could have gone "bad" but still accept a flash and still scan normally with the OBD tool? Is there any other common issue that would prevent spark on all 4 cylinders and then allow it to run perfectly fine after sitting?
I've searched extensively and can't find anything to point me in a direction, so I'm dead in the water at the moment.
Thanks in advance.
Padawan is offline   Reply With Quote
Old 05-06-2020, 01:50 AM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
so does it run rough and then dies? how long does it take to die?
Old 05-06-2020, 08:25 AM   #3
Padawan
Member#: 406834
No, when it starts it runs perfectly and idles rock solid. This last time it ran for about 15 minutes, then just died almost instantly. Now it won't start at all anymore.
Old 05-08-2020, 10:51 PM   #4
603boostfreeordie
Member#: 514568
2012 Wrx Sedan, Grim
Check the o ring on the fuel pump, I had a similar issue in 2012 don’t know how similar the setup is but If that o ring on top of your pump is bad you’ll get fuel at the motor but it won’t run maybe sputter a couple times
603boostfreeordie is offline   Reply With Quote
Old 05-09-2020, 02:26 AM   #5
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Pull the rest of the coilpacks and plugs to check if they are good. Also try to get an inline fuel pressure gauge on there to see if you are getting consistent pressure.
Check fuel pump connectors for any corrosion. I've seen corrosion at the connection point from the bottom of the fuel pump assembly (tank side) to the pump itself. If there is that, you may need to replace the fuel pump controller located on the right rear of the vehicle.
Pakin is offline   Reply With Quote
Old 05-10-2020, 12:55 AM   #6
igoiks
Member#: 326692
2012 sti
Check crankshaft position sensor very common issue
igoiks is online now   Reply With Quote
Old 05-10-2020, 01:14 AM   #7
4bang4now
Member#: 489016
2015 STI
You have obd scanner that shows data? Is the cam sensor showing data when cranking? Crank sensor actually providing data? My 15 is car will not start if cam sensor is unplugged.
Many cars 00 plus will throw a crank code sometimes and the cam sensor will fix. Fn stupid. Dodge has that issue alot as well as kia.
4bang4now is offline   Reply With Quote
Old 05-10-2020, 07:10 AM   #8
some dude
Member#: 100300
06 WRX
What fuel pump is in the car now? My 2006 started acting like your car, the culprit was a rubber seal in the fuel tank, on the pressure line. I had a Walbro 255, my FPR went dead-head, not returning fuel, and the pressure line blew a seal causing intermittent behavior, followed by crank no starts. When the car started, it would run and drive. Eventually it stopped starting. It would deliver fuel to the engine, but not enough to start it. Check fuel pressure when key is turned on, priming the pump. My 2 cents. good luck!
Old 05-13-2020, 10:38 PM   #9
Padawan
Member#: 406834
Thanks for all the replies. I've replaced the FPR, the crankshaft position sensor, and the cam position sensor, with no change. Still not getting any spark, but the plugs are wet so fuel is definitely getting to the cylinders. I have a basic OBD scanner but it's not showing any codes.
Old 05-14-2020, 02:52 AM   #10
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Make sure you're getting rpm signal when cranking
spoolinsti05 is offline   Reply With Quote
Old 05-14-2020, 06:02 AM   #11
bp05obxt
Member#: 459799
I would suggest looking into the wiring and identify the wires for the coils and check continuity. Sounds as a signal, common power, or grounding issue is preventing the coils from firing. If the engine is getting fuel it tells me most likely the position sensors are working allowing the injectors to fire.
I would also say it wouldn’t hurt to unclip the injectors to prevent them from aimlessly pumping fuel into a cylinder without spark. Once you correct the spark issue plugging the injectors back in is simple enough.
An older higher mileage car can have some corrosion build up on the connectors for the harness. It can sometimes help to “swipe” or disconnect and reconnect the the main harness connection to allow the pins and contacts to remove minor corrosion.
bp05obxt is offline   Reply With Quote
Old 05-18-2020, 09:19 PM   #12
SubieHondaGuy
Member#: 312223
X2, they fail when they get warm.
SubieHondaGuy is offline   Reply With Quote
Old 05-20-2020, 11:40 PM   #13
shadowsports
Member#: 446364
'17 STI LMT '08 LGT
DGM / QSM
Greetings,
Most common causes have already been mentioned. Main circuit connections are worth a look. Also check you clutch pedal position switch. A failed switch could keep the car from starting. Probably unrelated since you are not getting spark, but I know at this point you are considering everything.
shadowsports is offline   Reply With Quote
