Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2020
Old 05-06-2020, 11:32 PM   #1
ProjectWhiteWrx02
Member#: 514524
2002 Impreza WRX Bug
Default 2002 WRX - First Subaru - Project Car
Hello everyone my name is Ismael, i'm 32 Active Duty Army. I am a noob subaru owner,i am more experienced with Nissan, 240sx/350/370z.
I plan on building up my Impreza here in the next few months.
I've always wanted a Subaru, i love the older Legacy specifically.
I've owned 2 240SX, a Nissan Sentra R, 350z, wife had a 370z.I've had a few motorcycles, 01 R1, 06 R6, 17 R3, and 2 Thundercats, and a Ninja250.
Anyways I bought this car and did a lot of research, I plan on Doing a V7 Swap, with a 6speed,and brembos with a r180 diff.
This car has seen better days, i was scared driving it home and didn't get it over 50... Suspension is shot, brakes, rotors, tires are non existent, the tubing that connects to the intercooler is torn, and the turbo was definitely not activating. I could tell it previously had a FMI but it was reverted to stock. Came with Carbon Fiber hood and Fenders so i'll take a win there? ha.
I don't have any good pictures right now, its dark out, and not 100% sure how to post pictures currently.
ProjectWhiteWrx02 is offline   Reply With Quote
Old 05-07-2020, 12:03 AM   #2
BigWrecKs
Member#: 93830
'06 Silverado
'19 STI
Hey, welcome. Make sure to document your journey! Post pics often
BigWrecKs is offline   Reply With Quote
Old 05-09-2020, 08:38 PM   #3
ProjectWhiteWrx02
Member#: 514524
Will do, I need to save up a little more. AT the moment I have about 5K saved. I want to think I can afford to do the transmission, differential, axles clutch, e brake, flywheel, brembos. The only part that gets me is if my stock wheels would fit, because if that's the case I'd drive it again with this setup. I need to look into it some more.
Ideally I want to start shopping at 7k.
The car itself is not driven because I don't want to beat it while it's already downish, I plan on trying to sell the motor trans and all the stock stuff to purchase newer pieces so keeping it sitting for myself seems like a better option than thrashing it while I still have means of other transportation.
Old 05-10-2020, 08:25 AM   #4
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
I miss my Nissan days. My S14 was still the most fun car I ever had. Enjoy the Subaru. They have a lot to offer as well.
snow_bound26 is offline   Reply With Quote
Old 05-10-2020, 09:56 AM   #5
D-rock240
Member#: 284221
2011 WRX GV SSM
2003 Outback wagon 2-tone
I sold my S13 6 months before F and F came out and the values shot up
Welcome OP!
D-rock240 is offline   Reply With Quote
Old 05-10-2020, 03:41 PM   #6
ProjectWhiteWrx02
Member#: 514524
Welcome OP!
Yeah, i had an 89 Hatch and a 92 Coupe, the coupe was nothing but bad luck, did almost everything i wanted to it but paint it, and thats because the traction on it was so bad i never got it right. Normal day headed to work in CA, i barely hit a small bump at the top of the on ramp, snapped a front LCA and i told myself it was time to go, they used to call my coupe a death trap, its bitter sweet just to even talk about it.
Old 05-10-2020, 03:44 PM   #7
ProjectWhiteWrx02
Member#: 514524
Long over due! Picked this car up as a Birthday present to myself back in February 2020.
Can't wait to start digging into around July. Other than the Turbo timer, for a turbo that doesn't operate, it has CF hood and fenders and the battery has been relocated in the rear.
Old 05-12-2020, 10:55 AM   #8
CTFlyer11
Member#: 514682
That certainly looks like quite the project car! I'm excited to see/follow the progress
CTFlyer11 is offline   Reply With Quote
Old 05-14-2020, 07:52 PM   #9
ProjectWhiteWrx02
Member#: 514524
A bunch of parts coming in next week, getting excited.
I'll be working on it tomorrow, (tune up)going to try and get it ready atleast to pass inspection here in El Paso TX. Hope to atleast get it running -effectively- ha.
I need to do some digging and see if the turbo is toast, or if the stock inlet needs to be replaced - causing leak on a possible good turbo? Hoping just the inlet, but prepared for the worst.
Edit
Also found out the hard way.
Stock 15s DO NOTTTT clear Brembos with extended ARP studs and wheel spacers!
Old 05-16-2020, 09:36 PM   #10
ProjectWhiteWrx02
Member#: 514524
Did an oil change on it today and took the TMIC off. Plan on taking off the Turbo inlet next go around, it came with an aftermarket K&N air filter so i took that off to recharge it with stuff i had leftover from my 06 R6.
Found leaks everywhere, specifically rear main seal, small leak in the block. Found a small puddle in the rear while the car was jacked up, nothing while its been on all fours. There was a lot of loose bolts ill need to tighten when i tear off the front end of the motor near the radiator on the underside, some type of cover? Not 100% sure.
I have a question hopefully i can get some help with, I plan on going to the yard(tomorrow) to pick up a few items hopefully.
I know a lot of parts are interchangeable with WRX and STI and such, would i be able to find hardware (bolts and nuts) from any other models/yr? The front end of this car is held up by Zip ties... every single bumper fastener is a zip tie*, the grill, rad. support, its all zip ties thanks in advance thanks for reading.
Added: its a 2002 Impreza WRX Bugeye
Old 05-18-2020, 08:15 PM   #11
ProjectWhiteWrx02
Member#: 514524
I feel like i am going to wind up spending a lot of cash because of how compulsive obsessive i am with doing things right.
Parts i will replace/Need.
Front Bumper
Headlights
Fog lights- Doesn't have anything on there anyways.
Bash and Bar foam insert
Rad support
Fuse box
Weather strip near the top of the hood.
[IMG]
[/IMG]
Old 05-19-2020, 07:56 PM   #12
ProjectWhiteWrx02
Member#: 514524
Took out the Turbo inlet today, no luck taking off the turbo there is a broken bolt on the passenger side that goes from front to rear, sent my wife to get me a grinder to see if i can make some magic happen.
Not sure what brand ill be replacing the inlet with, i think at the moment im going to go with a Perrin in black or red.
Old 05-20-2020, 12:41 PM   #13
ProjectWhiteWrx02
Member#: 514524
Very stressful job this was, Took a Drill, Grinder, and a hand saw to finally snap that exterior bolt off.
Now that everything is out i am uncertain if i want to reuse this turbo.
-Pros
It might be salvageable with the 20 dollar repair kit i purchased (does not include the blades and such, just seals and other small components)
-Cons
Waste of money, might not work and i don't plan to dig in to it until i receive my kit.
could use the money towards a known good working turbo.
I could have weakened the housing due to grinding the entire side bolt mount off.
*Edit I need a bunch of hoses for this thing, they are almost all worn out, and wasn't looking forward to swapping them until the new motor comes in, but i need to register it and get it to pass inspection.
Old 05-23-2020, 04:15 PM   #14
ProjectWhiteWrx02
Member#: 514524
Alrighty, some updates to my project.
-Headers/Up pipe/Flex pipe
Unbolted headers to find out its a one piece, no up pipe, flex pipe was already busted so i tugged on it a little and i was able to pull the top side out without effort, otherwise it appeared like i needed to hoist or bump the engine up some. Took it to a muffler shop and got a custom up pipe set up on it for now with a new flex pipe. 6 bolts under the car, very easy to uninstall and install.
- Turbo
Turns out the turbo on there is a VF30, not a TD04. I'm somewhat happy about this, but hopefully that doesn't mean i need to invest in a FP, and other stuff. <need to research the VF30>. I ordered a kit to repair the td04 but after i started cleaning up the turbo, i realized the turbo is in pretty good shape, no play(very minimal) on either side blades, just some build up that i had to clean up. Prepping it up for paint, just waiting for the wind to settle a bit.
- Wheels
I purchased a set of Avid 06 wheels for about 550 shipped(discount for inconvenience!) in HyperBlack (17x8 5x100), and found a good deal on a set of Dunlop Sport Maxx for 200, 50 bucks for new stems, balance and mount. Things are getting spicy. I recieved my kartboy rear brembo bracket adapters aswell, I'm going to be up early tomorrow trying to do my best with what i currently have, just waiting on UPS to find my brembos, they seem to have misplaced them or shipped them to the wrong address ._.
Old 05-25-2020, 07:26 PM   #15
typexero
Member#: 514651
Keep the dream going. Love the bugeye .
typexero is offline   Reply With Quote
Old 05-26-2020, 12:12 AM   #16
silverbur
Member#: 515039
Welcome!..another one new here
silverbur is offline   Reply With Quote
Old 05-29-2020, 01:26 PM   #17
ProjectWhiteWrx02
Member#: 514524
Thanks everyone, planning on installing the intake, headers, turbo, and exhaust today, wish me luck, hopefully the inlet does not provide to much trouble, but i've seen videos and well it looks pretty awful.
Old 06-02-2020, 10:29 PM   #18
ProjectWhiteWrx02
Member#: 514524
So today I finally managed to finish reassembling everything, I reconnected the battery, let oil prime by disconnecting fuse so that the car would crank but not start, I let the fuel pump run, connected the fuse back and the car didn't start. Tried to start it maybe 3 times more and it finally cut on. It was pissed off, really bad idle at about 0400rpm, gave it a little gas to see if it was just mad because I havent started it in over a month. Gas peddle was unresponsive, tried again, nothing, finally got out quick before it sputtered to death and tugged on the accelerator cables from the engine bay... uh oh, smoke. Turns out I lost all my power steering fluid somehow. The car was too hot to examine at that point and its sitting on blocks so I couldn't really dig in much further... as far as I could tell the turbo did not function after I installed everything back together, not enjoying the path the car has taken me so far, and this is just for inspection... tomorrow going to stop by the auto parts and pick up some more fluid see if I can find out what happened, oil and radiator fluid were fine.
Old 06-04-2020, 01:45 AM   #19
concernedparent
Member#: 515319
damn, that thing looks fun.
concernedparent is offline   Reply With Quote
Old 06-13-2020, 06:10 PM   #20
ProjectWhiteWrx02
Member#: 514524
So far, it's been stressful but fun, not knowing much about turbo engines, let alone a boxer engine has shown me a lot.
Picked up a Mishimoto radiator and air/oil hose kit, DW255 fuel pump, Tom Yocka headers and up pipe, and a hard line that runs the coolant return from radiator to the reservoir on top of the intake manifold. Later today I plan on sitting down and purchasing an affordable turbo to get value out of the sti pinks and other mods, I'm leaning towards the VF39 as its plug and play and will be compatible with the mods the car will have until the real build begins.
Also! I got a pretty good quote from a bodyman whos willing to knock out the damage on the left rear Quarter Panel for under 200 bucks, I'll be dropping it off next week hopefully to let him work his magic.
Old 06-19-2020, 06:12 PM   #21
ProjectWhiteWrx02
Member#: 514524
Got a few items in the mail, just missing the VF39(arriving tomorrow). Going to pull everything out again once it gets a little cooler out, its like 97 degrees right now and well <i'm not up for it>., I'll take a peek at the power steering seals tomorrow most likely.
Mishimoto Rad
Radiator line from Subaru dealership
STI pinks<not in picture>
DW255 FP
Tomioko Equal length headers and Up pipe <I was really impressed by their package, offered exhaust wrap and ties, gaskets and new bolts just from a quick glance>
[IMG][/IMG]
Old 06-20-2020, 09:18 AM   #22
ProjectWhiteWrx02
Member#: 514524
Can anyone tell me if this is the PCV Diagnostic Connection that goes into the turbo inlet near the manifold?
Also shiny headers
[IMG]
[/IMG]
Old 06-22-2020, 09:29 PM   #23
ProjectWhiteWrx02
Member#: 514524
Alright more pictures, hoping someone can help identify the 2 nipples on the intake, since i already had no clue what modifications were done to the car prior to me owning it, i just need to know if i have to plug those up, i'm assuming they are apart of the evap system, but again im not certain.
Headers wrapped and installed with 02 sensor, tomorrow i plan on finishing up the entire front side of the engine as it will be more bearable outside temp wise, i really need an overhead tarp or awning or a garage(i like the garage idea)
left to do:
Install up-pipe - Done
Install Turbo
Install Down pipe
Install remaining Aux hoses - Done
Revise all work - hoses and bolts
Install Fuel Pump
Install injectors
Fluids
Pray it starts
Get it tuned through Patterson Performance
