Welcome to the North American Subaru Impreza Owners Club Friday August 7, 2020
Old 07-31-2020, 08:54 PM   #1
defury
Member#: 428480
2003 Jdm Forester
Default Rod knock? (video)
You can hear the noise slightly better near the end, its subtle but underneath the rest of the engine noise (fans kicked in mid recording) the engine was hot as I had just been driving for 30 minutes, this is why I used the throttle to really rev the engine as the cable was to hot to hold.
Since I've taken delivery 11,000km ago the vehicle has had 3 oil changes all with motul xcess 5w40, the car consumes no oil, the timing belt and tensioners/pullys and water pump were all done, AC compressor rebuilt, cam seals checked, valve cover gaskets replaced (began sweating no real leak caught it early) and cams and cam gears/avcs sensors inspected. No boost leaks recently tested, knock sensor recently replaced to diagnose Phantom ecu knock, tech heard no real engine knock with mics hooked up to the block while driving.
Coolant temp in this video is 190f and the oil was checked and was full before recording.
I see no reason this would be rod knock but there's definately a low hollow knock from something. There's also a ticking from the valve train, I need to adjust the lifters so that's not the noise I'm referring to.
Thoughts?
defury is offline   Reply With Quote
Old 08-01-2020, 12:07 AM   #2
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Piston slap.
D-Rodman is offline   Reply With Quote
Old 08-01-2020, 04:28 AM   #3
defury
Member#: 428480
2003 Jdm Forester
Originally Posted by D-Rodman View Post
Piston slap.
Even though the engine is fully warmed up after a 30 minutes drive?
Old 08-01-2020, 09:48 AM   #4
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Pistons can still slap, itís not rod knock on that video.
Old 08-01-2020, 12:57 PM   #5
subaru_gc8
Member#: 29292
2004 WRX wagon
Pistons can still slap, it’s not rod knock on that video.
unless your have a forged engine, slap will means you probasbly haver alot of wear on your rings. might wnat to take the oil fill cap off when its cold to see if there is any smoke coming out of it
Old 08-01-2020, 02:22 PM   #6
defury
Member#: 428480
2003 Jdm Forester
The vehicle consumes no oil so I doubt the rings are bad. It's the first Subaru I've owned where I never have to top up the oil.
Old 08-01-2020, 10:20 PM   #7
Shik
Member#: 132
2006 GT Ltd 5spd sdn
'15 WRX 6spd CWP, '02 WRX
I wouldn't be concerned with that at all. I can't remember hearing an ej205 that didn't have that noise. Piston slap has been around Subarus since the 90s. Here's a short video explaining a bit about it from a shop that has been around a long time:
It sounds like you are on top of all the maintenance. Just run it, keep up on the basics, and you'll be good to go.
Shik is offline   Reply With Quote
Old 08-02-2020, 12:00 PM   #8
Samurai Jack
Member#: 21145
2002 Enemy of Aku
I'm not hearing anything but a normal EJ205 at idle or otherwise.
