Welcome to the North American Subaru Impreza Owners Club Thursday September 24, 2020
Old 05-12-2020, 12:12 PM   #1
harryr34
Member#: 190824
2004 Impreza STI UK
Default 07 UK STI 2.35 EJ22T Front Mount EFR9180 Build
Hi All,
I hope you are well, thought i'd share my STI build that is nearing completion over in the UK. It should be ready for mapping within the next 7-10 days.
- 2.35 engine, EJ22T block bored to 97.5mm, Mahle extreme pistons
RCM arrow extreme rods, mahle bearings, 79mm crank, rcm 14mm headstuds, RCM gaskets, Kevlar HKS belt and pulleys, AVCS JDM 2.0 fully ported and polished heads with Lateral Performance race cams and Supertech valves, titanium retainers, double valve springs and seats, Adjustable vernier cam pulleys.
- Dailey engineering dry sump kit.
- Custom front mount exhaust manifold and 3.5" downpipe/exhaust (Walton Motorsport UK).
- Borg Warner EFR9180 turbo, 0.92 twin scroll housing, 2x EWG.
- Cosworth Inlet Manifold with TGV Delete Housings and Fuel Rails.
- 2x external Bosch 044 Fuel pumps with a 3L swirl pot setup and ASNU 1500cc injectors, -8AN Teflon Braided lines throughout.
- Syvecs S6+ Including Toucan and associated sensors.
- Aquamist HFS3 water/meth injection kit.
- JDM Spec C Quick Steering Rack.
- Cosworth AP front brake kit.
- CAE Ultrashifter
harryr34 is offline   Reply With Quote
Old 05-12-2020, 01:18 PM   #2
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Will be very interesting to see how that big EFR responds to your low mount setup , appears to be a wonderful all around build. If only you had access to the E85 we have in the states.
How do you like the quick jacks ?
Gigs90 is online now   Reply With Quote
Old 05-12-2020, 03:05 PM   #3
harryr34
Member#: 190824
2004 Impreza STI UK
Fingers crossed it will be worth the effort.
I love the quick jacks, have had them for almost 3 years, a pleasure to use.
Old 05-13-2020, 12:05 PM   #4
Chooten
Member#: 497524
Great looking build!!
Chooten is offline   Reply With Quote
Old 05-13-2020, 05:33 PM   #5
Swift2
Member#: 135432
2006 WRX STI Limited
Urban Grey
Amazing build! I am also doing an EJ22 block into 2.35L, but going with a smaller turbo.
Who did the build and who is your tuner?
Also the heat wrap looks proper, is that bonded to the piping like for F1 cars?
Swift2 is offline   Reply With Quote
Old 05-14-2020, 07:29 PM   #6
technikhaus
Member#: 425609
Wow what an epic looking machine.
With those specs I was expecting a fully caged race-car.
That's going to be an amazing road machine!
technikhaus is offline   Reply With Quote
Old 05-15-2020, 08:08 PM   #7
harryr34
Member#: 190824
2004 Impreza STI UK
Thanks, it has been a long term, spare time build, looking forward to completing it now.
Thanks, the engine was built by Area52 in the UK, the rest has been put together by myself bar the exhaust and intercooler/piping work. For mapping I usually use Martyn @ Enginetuner in the UK.
The exhaust lagging has been done by Thermo Met in the UK, their work is amazing!
Thanks, I really want to keep this as a road car for a couple of years at least as my 4 year old son is quite hands on with this build, itd be nice to get some use out of it with the family before stripping it and caging it for track use.
Old 05-17-2020, 11:54 AM   #8
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Looks awesome! What heat wrap is that on the header and dp?
OppositeLock is offline   Reply With Quote
Old 05-17-2020, 05:24 PM   #9
stu
Member#: 25768
2003 GEN2 GTX35 40++
2.3 slobaru
good job. love that wrap!
stu is offline   Reply With Quote
Old 05-18-2020, 05:31 AM   #10
harryr34
Member#: 190824
2004 Impreza STI UK
Thanks, the manifold and downpipe heat lagging was completed by https://www.thermomet.co.uk/
Old 05-18-2020, 08:02 AM   #11
Smurftastic
Member#: 243697
17.4 PSI ECUtuned 02
BLOD Cofounder|TopScoob31
Epic build! Out of sheer curiosity, how to you handle the routine MOT requirements?
Smurftastic is offline   Reply With Quote
Old 05-18-2020, 12:23 PM   #12
OppositeLock
Member#: 54060
Cool stuff, thank you!
Old 06-01-2020, 05:32 PM   #13
harryr34
Member#: 190824
2004 Impreza STI UK
In between life getting in the way I’ve managed to make some progress;
- Dry sump lines have all been covered in fire sleeve, fitted up and the whole system has been primed.
- ASNU 1500cc injectors fitted.
- Breather pipework fitted.
- Turbowerx Exa turbo scavenge pump fitted.
Outstanding tasks:
- Turbo oil drain pipework
- Fuel pump carrier AN fittings and pipework to swirl pot
- Wire in the the rest of the sensors to the Syvecs ECU, load a basemap, tweak IO and get it running.
Old 06-11-2020, 04:12 PM   #14
Barge
Member#: 62941
2004 #LesboRacer
#TunedbyBarge
Is that a custom radiator? It looks kind of like a subaru radiator but kind of not.
Barge is offline   Reply With Quote
Old 06-11-2020, 05:52 PM   #15
harryr34
Member#: 190824
2004 Impreza STI UK
It is an off the shelve Mishimoto Universal Radiator, 25.51" x 16.3" x 2.55".
Old 08-01-2020, 04:16 PM   #16
harryr34
Member#: 190824
2004 Impreza STI UK
Old 08-01-2020, 05:27 PM   #17
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
If you want the radiator to actually work correctly and not waste time dealing with overheating, get a proper shroud and not something like Mishimoto offers. You need two shrouds, one for each fan, and both shrouds should seal to the edge all the way around the shroud. Aftermarket slim fans already aren't up to par with oem for flow, using aftermarket shrouds is a disaster waiting to happen. I constantly see people chasing high temperature situations and they are usually running aftermarket garbage shrouds and fans. Do yourself a favor and avoid all of that.
And yeah, that looks like some serious power will be had. Will definitely be paying attention. Have fun!
2slofouru is offline   Reply With Quote
Old 08-01-2020, 06:03 PM   #18
harryr34
Member#: 190824
2004 Impreza STI UK
The advice is much appreciated, Ill be monitoring temps and changing parts if required. Space is at a premium with the turbo positioned where it is, on the first pass I managed to squeeze in a pair of 9 Davies Craig fans, if theyre not up to the task Ill have to cut away some of the front panel and implement a better solution.
https://daviescraig.com.au/product/9...c-fan-12v-0160
Old 08-01-2020, 06:23 PM   #19
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
The advice is much appreciated, I’ll be monitoring temps and changing parts if required. Space is at a premium with the turbo positioned where it is, on the first pass I managed to squeeze in a pair of 9” Davies Craig fans, if they’re not up to the task I’ll have to cut away some of the front panel and implement a better solution.
Don't mention it, anything to help a fellow enthusiast. It pains me seeing so many high power subies with coolant setups that are lower capacity than the original oem, yet demanding much more cooling capacity. Aftermarket fans simply aren't designed to move as much air and dropping fan size and blade pitch further lowers their efficiency. They are designed primarily for setups that have less than oem room for fans.
Keep in mind, a fan is only as good as the shroud it's attached to. If you don't have much depth, you need to get the largest fans possible and design your shroud to fit and seal well.
The subject of fan and radiator setups isn't discussed nearly enough here. We need a thread dedicated solely for radiator and fan shroud design, discussion always seems to splinter off into nonsense. I'd start a thread, but don't have enough proof of my knowledge to keep people participating in the thread. People here expect a racing pedigree or degree thermodynamics before they will actively engage in a thread on something this controversial. I just stick with trying to help when the opportunity arises.
