Welcome to the North American Subaru Impreza Owners Club Thursday October 22, 2020
Old 09-16-2020, 08:59 AM   #101
Latin.pitbull
Member#: 518381
Only if someone would commit to making a PNP harness.I would if I was confident and experienced to do so,but electrical is not my thing.
On those 10 pin connectors there is a 10 pcs minimum.You need 2 for yourself And are left with enough connectors to make another 4 and offer them for sale.I wouldn’t mind contributing to that to get the ball rolling if someone committed to making it.I was hoping Andrew_l_s would make them since he offered a PNP harness for the front camera and already invested in a crimper. Some one please make this harness so I can order the folding mirrors.
Latin.pitbull is offline   Reply With Quote
Old 09-17-2020, 05:47 PM   #102
joshcastorillo
Member#: 518663
Default Mod
Nice mod man! I really appreciate you sending out actual instructions making it a fairly easier diy for newbies wanting power folding mirrors
joshcastorillo is offline   Reply With Quote
Old 09-20-2020, 11:35 PM   #103
andrew_l_s
Member#: 446616
2018 WRX Limited
Lapis Blue Pearl
I'm doing some digging into it, stay tuned.
Also looking at the possibility of swapping power folding mirrors from the 2020 Ascent. They're the updated mirror design that's more aerodynamic for less wind noise and readily available from US suppliers.
AND the parts exist to put the Side View Monitor cam on the passenger side mirror
andrew_l_s is offline   Reply With Quote
Old 10-11-2020, 10:17 PM   #104
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
Any updates??
murrdogg24 is online now   Reply With Quote
Old 10-11-2020, 11:16 PM   #105
Subie Muchacho
Member#: 490151
2018 WRX STI Limited
Ice Silver Metallic
Impatiently waiting I still have my JDM w/BSM mirrors waiting to be installed I’m a super fan of plug-an-play mods.
Ascent info is interesting.
Subie Muchacho is offline   Reply With Quote
Old 10-15-2020, 11:40 AM   #106
blueberryapple
Member#: 519370
2020 WRX
So basically for 2017 and newer wrxs that aren't the limited trim, we just need to repin the d84/83 kick panel footwell harness to pins 24 and 25 using the diagram from @ajsti24 and then follow directions from OP to get everything working?
blueberryapple is offline   Reply With Quote
Old 10-19-2020, 01:42 PM   #107
qnzfinestflip
Member#: 218339
2017 STI
Lapis Blue Pearl
Originally Posted by ajsti24 View Post
Warning: Not an easy install on 2017+ WRX/STi's due to subaru revised/rewired the door side mirror connector to receive the Blind Spot Monitor function on the mirror lens. I think 2015-2016 Model years should be ok with this mod, just re-pinning only on the mirror side connectors. Next, you need to make room for the JDM mirror switch in the driver side window switch trim.
This is the BSM wiring diagram on the side mirror door harness/connector: You need to rewire the Light green wire/Black wire Pin#2 and #6 (Connector D5/D15) and connect/tap to the door harness/plug pin#25 & #24(D83/D84) respectively. For the driver side plug D84, light green wire(remove from D84 pin#14 and tap/connects to pin#25 (Black with red stripe wire) and the black wire(D15 pin#6), this wire needs to be cut from the mirror plug and ran a new wire through the door harness grommet(PITA) and tap to pin#24 of D84(Blue with red stripe). For passenger side same procedure light green wire re-pin from pin#14(D83) to pin#25 (was left blank from the factory), the black wire(D5 pin#6) same as the driver side, cut and ran a new wire through the door grommet, add a female pin and plug to connector (D83 pin slot#24).
So, found his post on iwsti explaining what wires i need to move and tap into. I was only able to move pin#14(D83 plug) to pin#25 slot and passenger mirror was able to fold close. I was not able to finish up since i ran out of time. So, im guessing it should be wire like this:
Driver side:
-D84 plug
remove pin#14(Light green) and tap into pin#25
-D15 plug
pin#6(Black), cut and run a new wire and tap into pin#24(Blue with red stripe) on D84 plug
Passenger side:
-D83
remove pin#14(Light green) and re pin to pin#25(blank spot from factory)
-D5
pin#6(Black), cut and run new wire and tap into pin#24 on D83 plug
Then the mirrors would be able to fold open and close by pressing the switch on the panel. Hope this sounds correct or hope you can chime in and help out
qnzfinestflip is offline   Reply With Quote
Old 10-20-2020, 12:49 AM   #108
blueberryapple
Member#: 519370
2020 WRX
Driver side:
-D84 plug
-D15 plug
Passenger side:
-D83
-D5
Yup you're spot on. I DMed him last week and he said pretty much the same thing. Going to try this mod out this weekend or the next. Are you also planning on installing the auto folding module?
Old 10-20-2020, 01:13 PM   #109
qnzfinestflip
Member#: 218339
2017 STI
Lapis Blue Pearl
Yes, Hopefully I could get to wiring it up this weekend.
