Welcome to the North American Subaru Impreza Owners Club Friday February 26, 2021
Old 11-21-2019, 03:13 PM   #7426
PDXGSXR
Member#: 374344
Default Bump for Sottozeros
Was reading the thread and see a lot of tire options but seems like the Pirelli Sottozero 3's have fallen out of favor a bit in the recommendations.
Just want to throw those out there again for the people looking for a performance winter tire. I just ordered my second set after three seasons of many ski trips and drives over the passes here in the Northwest - IE snow, ice, slush, wet snow, dry snow, deep snow, thin snow and everything in between.
The Pirellis have had great traction in all of the above but retain plenty of dry/wet grip/handling - the steering response is better than my old Conti DW's in fact. W/ Subaru AWD and low weight/CG in these cars I don't see any reason to go with a more aggressive snow tire unless you live above the snow line or in a place that sees regular freezing rain etc.
They stand up to a bit of hard driving as well but be aware that with the soft compound you risk damaging/smearing the siping if you really push it regularly (especially in warmer temps) - as is the case with all winter tires.
PDXGSXR is offline   Reply With Quote
Old 11-21-2019, 03:37 PM   #7427
tokksic
Member#: 441539
2015 WRX
Glad to read this, as I just had these tires delivered. I wanted a performance winter tire- had Hankook iPikes before, but my climate was always plowed roads or slushee snow. They were too soft for those roads, I anticipate the Sottozeros will be perfect for minimal snow/slush/paved roads and cold temps.
tokksic is offline   Reply With Quote
Old 07-19-2020, 09:05 AM   #7428
T-Madj
Member#: 516428
2020 WRX STi
MGM
New Pirelli P Zero Winter
Thinking about trying these out this winter in Colorado. No ratings yet, but they look like they have promise. https://m.tirerack.com/tires/tires.j...=WinterSection
T-Madj is offline   Reply With Quote
Old 07-19-2020, 03:46 PM   #7429
serrilion
Member#: 348982
03 OBS
The Pirelli's look like they are banking on deep snow traction on the outer part of the tire and normal pavement style driving on the inside. I would be curios to see how these preform, also if they come studded and whats the price point. I live in Vermont were Nokian's dominate our state for winter tires, used to run WRG3's year around with out issue
serrilion is offline   Reply With Quote
Old 09-16-2020, 08:13 PM   #7430
T-Madj
Member#: 516428
2020 WRX STi
MGM
Per Tirerack, the P Zero Winter tires are not studdable. If they were it would be a $15 charge per tire. Mine came in the other day, so I look forward to testing them out in a couple of months.
Old 09-20-2020, 12:52 AM   #7431
krzyss
Member#: 8365
2019 Mazda MX-5 RF
Machine Grey
PZero Winter seem to be performance winter tires.
No studs for them.
Krzys
Old 10-06-2020, 10:34 AM   #7432
KoiQ
Member#: 373393
06 WRX Limited
What wheels and tires are you guys running with RT fender flares? I am very very very close to pulling the trigger on installing RTs but I was looking at options for winters and like.. with the wheel size you need for them, there are literally no winter tire options.
Need help finding winter tires and wheels to fit. (2015 wrx)
edit: the height of the car can be adjusted potentially to fit.
KoiQ is offline   Reply With Quote
Old 10-06-2020, 11:08 PM   #7433
krzyss
Member#: 8365
2019 Mazda MX-5 RF
Machine Grey
Not sure that I understand your problem.
Does it mean that with flares you will have too much room?
What are the tire sizes you are looking for? What was OE size?
Krzys
Old 10-09-2020, 01:46 PM   #7434
OmahaSTI
Member#: 519254
2019 Audi S4
Red
I recently got the Pirelli PZero Winters on Sport Edition 18x8 A10-2's for my 2020 STI from tire rack. Unfortunately, I'll never be able to try them out as I sold the car already.....
Trying to figure out how I can post in the classifieds as I am sure someone on here will make use of them.
OmahaSTI is offline   Reply With Quote
Old 10-09-2020, 07:20 PM   #7435
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Since youre new, you probably need to have a certain number of posts to post an ad. Check the forum rules.
left footed whooten is offline   Reply With Quote
Old 10-09-2020, 11:11 PM   #7436
OmahaSTI
Member#: 519254
2019 Audi S4
Red
Thanks for that - I've now checked that out. Appreciate the pointer..
Old 10-20-2020, 03:58 PM   #7437
AdamBabikian
Member#: 501327
I have a 2019 STI and looking to buy a set of all seasons for my stock 19in wheels would I have any problems if I get tires that are 245/40R19.
AdamBabikian is offline   Reply With Quote
Old 10-26-2020, 01:29 PM   #7438
Eldiarslet
Member#: 519672
can i run 245 45 17 on my 06 sti if i run 225 25 17 as summertires?
Eldiarslet is offline   Reply With Quote
Old 11-05-2020, 01:23 AM   #7439
ST3EZZY_WRX
Member#: 484895
debating if I should start running 225/45 blizzaks or continue running barum 3hm 245/45?
located on west coast.
fyi dont reccomend barum's. horrible grip!
ST3EZZY_WRX is offline   Reply With Quote
Old 11-05-2020, 02:10 PM   #7440
krzyss
Member#: 8365
2019 Mazda MX-5 RF
Machine Grey
West Coast runs from San Diego to Seattle.
You have also change of elevation from below sea level to quite high mountains.
You may have been anywhere in the USA with such spread of climates.
Krzy***347;
Old 11-29-2020, 02:09 AM   #7441
Tyjamo87
Member#: 520275
Nokian HAKKAPELIITTA R3
Yokohama Blu Earth winter V905
Michelin X Ice Xi3
What would you choose?
Tyjamo87 is offline   Reply With Quote
Old 11-29-2020, 08:53 AM   #7442
soloz2
Member#: 260128
2019 WRX Limited
Lapis Blue Pearl
Michelin X Ice Xi3
I don't have experience with the Yoko's, but the Nokians over the Michelins hands down. I ran Xi3 on my old Outback and Crosstrek and currently have the Hakkas on my newer outback. Good tires. Not too soft on dry and good grip on snow and ice. Good deep snow traction as well.
soloz2 is offline   Reply With Quote
Old 11-29-2020, 09:29 PM   #7443
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Youll never regret hakkas
Old 11-29-2020, 09:53 PM   #7444
krzyss
Member#: 8365
2019 Mazda MX-5 RF
Machine Grey
There are people who regret Hakka R3 in dry and wet.
Tyjamo87, what do you want from your winter tires?
I think 2 tires on your list are studless and one is performance winter.
Put: dry, wet, snow, ice, noise in order of importance and our suggestions may be better.
Krzys
Old 11-30-2020, 03:41 AM   #7445
Tyjamo87
Member#: 520275
I've just obtained my first Subaru, '07 WRX wagon Limited. It will be the snow car, but would really like to have good performance on the dry and wet too, which leaves me leaning toward the Michelin. This winter I'll still be in W. WA where the only snow is up on the mountains, for snowboarding. But next winter I'll be in Montana and want a proper snow tire, which at this point it seems would be the Hakka. Thanks all!
Old 11-30-2020, 08:37 AM   #7446
krzyss
Member#: 8365
2019 Mazda MX-5 RF
Machine Grey
If you want good wet and dry performance you will trade ice and some snow performance for them. There is no free luch or tire that does everything very good.
Some would argue that "proper winter tire" has studs and that would be Hakkapellitta 9 factory studed but they may be illegal depending on location.
Krzy***347;
Old 11-30-2020, 04:58 PM   #7447
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
True, i never went r anything, just all the numbered ones except 5 and 6 i think. Bummer theyre not great on wet and dry, my rotiivas continue to impress in all conditions. Outperform my snow tires in snow
Dunno what tire people are using up there, heard of folks liking the goodyear up there but models are dofferent now
Old 12-10-2020, 01:54 AM   #7448
Tyjamo87
Member#: 520275
I opted for the new Michelin X Ice Snow.
Old 12-11-2020, 05:29 PM   #7449
h2s
Member#: 453454
2017 WRX sport tech
Dark metallic grey
17" wheels and WS80 on my 2017. So comfy
h2s is offline   Reply With Quote
Old 12-11-2020, 06:03 PM   #7450
Snow Drift
Member#: 75071
'19 xvPHEV,Tesla MY
05 08 11 WRX 18 STI 18TM3
I ordered X-ICE Snow from TR for our Model Y in August but they got back ordered until the end of time.
So, I got Pirelli P Zero Winter.
I can't wait to try them in snow. On dry roads they grip so much better than the stock A/S.
This here is the Android OS thread. All phones, news, general info welcome. under pressure Off-Topic 10849 12-13-2011 11:10 PM
WTB: Winter wheels/ or All season tires on wheels, or just all season tires! Robstunner MWSOC Private Classifieds 0 10-29-2009 12:42 PM
Winter Tires vs. All Season Tires wrx425 Tire & Wheel 22 01-16-2009 12:34 AM
same tire thread all around for AWD? MystikalDawn Newbies & FAQs 6 10-15-2008 12:28 PM
Anybody get tired of all your mods and go back to stock or somewhere in between?? Farnsrocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 09-11-2007 11:06 PM
