Welcome to the North American Subaru Impreza Owners Club Tuesday December 1, 2020
Old 10-17-2020, 12:00 PM   #1
m5gorrf
Member#: 468210
2006 WRX Wagon
Default Differences when a VF48 replaces a TD04, Advice Pls
Thanks for reading!
I am looking for others experiences and any concerns when a VF48 replaces a TD04.
I am only looking for better top end power for passing for now. The motor has almost 200K miles on it and has had head gaskets in the last 25K, with reasonable compression.
2006 WRX Wagon
Larger aftermarket TMIC
Cobb DP and 3" to the rear
Stage 2 accessport tune with proper pill in vac line
Silicon inlet
If the VF48 for now, was forced to behave like the TD04 other then better top end for passing over 80mph, I would be find. I have a STI shortblock sitting waiting for B25 heads then when time allows an engine swap. Also a full tune at that time.
Should I remove the pill from the wastegate vac line?
Other suggestions or things I should be aware of.
Thanks again
m5gorrf is offline   Reply With Quote
Old 10-17-2020, 01:10 PM   #2
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
https://forums.nasioc.com/forums/sho....php?t=2740715 needs to be followed to the letter. Your care is old and there are things that need looked at. There is no way to make a VF48 behave like a TD04, that's an upgrade and needs supporting mods and a tune.
Old 10-17-2020, 01:56 PM   #3
m5gorrf
Member#: 468210
2006 WRX Wagon
Thanks, owned from new, all fluids change well before normal schedule. All plastic / rubber parts inspected / stressed or changed.
'Not behave the same' what do you suspect the VF48 will do or how will it be different?
Old 10-17-2020, 08:45 PM   #4
LAS04subie
Member#: 379520
2005 Wrx
You would need some injectors and a tune at the very least. You canít just throw on the turbo and hope itíll work out.
LAS04subie is offline   Reply With Quote
Old 10-17-2020, 10:28 PM   #5
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
When I put a VF39 on top of my catted downpipe and stock exhaust, I gained nearly 70whp/tq compared to the TD04. It did need a new tune.
It's the single biggest bang for the buck on that car, as it already has the injectors to handle it (same as Sti injectors for the same year). You do NOT need new injectors! This argument has been settled numerous times. I did install an Sti intercooler I picked up for $150 at the time. A Walbro 255 fuel pump probably wouldn't hurt, either.
The car was a monster compared to its old self, with tremendous pulling power up top. (As time went on I got used to it, of course!)
Old 10-18-2020, 12:20 AM   #6
m5gorrf
Member#: 468210
2006 WRX Wagon
Did the VF39 spool slower at bottom end compared to the TD04?
I was hoping to install the VF48 & drive it to the tuners.
I will most likely hold off installing the VF48 until the engine swap as it needs to be tuned for the STI motor anyway. Just thought the ECU might be able to control the VF48 & not let it change the performance envelope other then better power top end..
Thanks for all the input.
Old 10-18-2020, 12:50 AM   #7
cdska
Member#: 458809
2005 wrx wagon
You can install it and use a cobb ots vf39 map with all the other appropriate supporting mods to drive to the tuner. Just stay out of boost.
cdska is offline   Reply With Quote
Old 10-18-2020, 11:30 AM   #8
m5gorrf
Member#: 468210
2006 WRX Wagon
Great advice thanks
