Welcome to the North American Subaru Impreza Owners Club Tuesday December 1, 2020
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 07-03-2020, 11:11 AM   #1326
timpala11
Member#: 512891
2019 WRX Stage 2+FF
ISM
2019 WRX - 7375 miles
Cobb AP
Cobb Big SF
Grimmspeed Catted J-Pipe
Invidia R400
PRL TGV/EGR Deletes
Grimmspeed EBCS
Process West Verticooler
Cobb Flex Kit
Deatschwerks DW300C
E74 - 364HP/359TQ
93 - 330HP/330TQ
Tuned by RT Tuning in SE PA
timpala11 is offline   Reply With Quote
Old 10-17-2020, 01:59 PM   #1327
Lelorex
Member#: 496161
Default 2018 Wrx
Hey guys.
EFI Logics in CT
275 HP
298 TQ
Peak boost is around 18PSI going down to 16.6PSI - 17PSI at redline
Mods:
MA performance intake
Perrin charge pipe
Perrin BPV
GS EBCS
Perrin TGV delete
EGR unplugged
STI mid pipe
Nameless axle back
Tune feels okay so far. Didnít really talk to the tuner much while I was there. Didnít get a baseline from the base map they sent me.
Lelorex is offline   Reply With Quote
Old 10-17-2020, 07:26 PM   #1328
BoostedTeaParty
Member#: 515430
2017 WRX Premium
'19 X3 M40i
Chassis: 2017 WRX Premium 6MT - stock motor, transmission, and clutch
Dyno Type: DYNOmite
Stock FA20 on Dyno: 220 whp
SAE Correction: standard
Boost: 20 psi
Fuel: Shell 93 Octane (E10)
Conditions: 69 F, 45% humidity, sea level
Peak HP: 309 whp @ 5800 RPM
Peak Torque: 306 lb/ft @ 4250 PRM
Just prior to tune - oil change, spark plugs, walnut blast
Cobb AccessPort v3
Cobb Big SF Intake
Cobb SS 3" J-pipe (catted, resonated) with Perrin turbo sump restrictor
Invidia Q300 cat-back exhaust
Perrin TGV Delete
EGR Delete
Cobb Bypass Valve
Cobb 3-port boost control solenoid
Process West Verticooler + charge pipe
Killer B Air/Oil Separator
Killer B equal length IWG headers
SoCalPorting v3 turbo upgrade (w/ Turbosmart internal wastegate actuator)
Cobb Stage 1 Drivetrain kit (shifter plate, shifter bushing, shifter stop)
Whiteline Gearbox Positive Shift Kit
Group N Transmission Mount
Perrin Pitch Stop Mount
Perrin Pitch Stop Brace
Car made 318 whp after adding in a bottle of VP Madditive Octanium, which boosts the effective octane level to 98-100 octane depending on how much 93 is in the tank. Bottom line is I really need to go flex fuel. Tuner said I'd be at 375 whp easily on an E55-60 mix. One of the only stations in all of New England that carries it is ~25 minutes away, so I don't have an excuse.
BoostedTeaParty is offline   Reply With Quote
Old 10-19-2020, 01:35 PM   #1329
jason02wrx
Member#: 222893
2016 WRX DGM Limited
2002 WRB/2012 SWP Hatch
Dyno Type: DYNOmite
Boost: 20 psi
Cobb AccessPort v3
Cobb Big SF Intake
Perrin TGV Delete
EGR Delete
Cobb Bypass Valve
Thereís 4 in MA
jason02wrx is offline   Reply With Quote
Old 10-20-2020, 01:16 PM   #1330
BoostedTeaParty
Member#: 515430
2017 WRX Premium
'19 X3 M40i
Originally Posted by jason02wrx View Post
Thereís 4 in MA
I know about the one in Chelsea and Cambridge. Unless there is another one in north shore (or even NH) I don't know about, which would seriously make my day.
