Welcome to the North American Subaru Impreza Owners Club Sunday July 25, 2021
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 07-03-2020, 10:11 AM   #1326
timpala11
Member#: 512891
'19 WRX Stage 2+FF
'16 XT (hers)
2019 WRX - 7375 miles
Cobb AP
Cobb Big SF
Grimmspeed Catted J-Pipe
Invidia R400
PRL TGV/EGR Deletes
Grimmspeed EBCS
Process West Verticooler
Cobb Flex Kit
Deatschwerks DW300C
E74 - 364HP/359TQ
93 - 330HP/330TQ
Tuned by RT Tuning in SE PA
timpala11 is offline   Reply With Quote
Old 10-17-2020, 12:59 PM   #1327
Lelorex
Member#: 496161
Default 2018 Wrx
Hey guys.
EFI Logics in CT
275 HP
298 TQ
Peak boost is around 18PSI going down to 16.6PSI - 17PSI at redline
Mods:
MA performance intake
Perrin charge pipe
Perrin BPV
GS EBCS
Perrin TGV delete
EGR unplugged
STI mid pipe
Nameless axle back
Tune feels okay so far. Didnít really talk to the tuner much while I was there. Didnít get a baseline from the base map they sent me.
Lelorex is offline   Reply With Quote
Old 10-17-2020, 06:26 PM   #1328
BoostedTeaParty
Member#: 515430
2017 WRX Premium
'19 X3 M40i
Chassis: 2017 WRX Premium 6MT - stock motor, transmission, and clutch
Dyno Type: DYNOmite
Stock FA20 on Dyno: 220 whp
SAE Correction: standard
Boost: 20 psi
Fuel: Shell 93 Octane (E10)
Conditions: 69 F, 45% humidity, sea level
Peak HP: 309 whp @ 5800 RPM
Peak Torque: 306 lb/ft @ 4250 PRM
Just prior to tune - oil change, spark plugs, walnut blast
Cobb AccessPort v3
Cobb Big SF Intake
Cobb SS 3" J-pipe (catted, resonated) with Perrin turbo sump restrictor
Invidia Q300 cat-back exhaust
Perrin TGV Delete
EGR Delete
Cobb Bypass Valve
Cobb 3-port boost control solenoid
Process West Verticooler + charge pipe
Killer B Air/Oil Separator
Killer B equal length IWG headers
SoCalPorting v3 turbo upgrade (w/ Turbosmart internal wastegate actuator)
Cobb Stage 1 Drivetrain kit (shifter plate, shifter bushing, shifter stop)
Whiteline Gearbox Positive Shift Kit
Group N Transmission Mount
Perrin Pitch Stop Mount
Perrin Pitch Stop Brace
Car made 318 whp after adding in a bottle of VP Madditive Octanium, which boosts the effective octane level to 98-100 octane depending on how much 93 is in the tank. Bottom line is I really need to go flex fuel. Tuner said I'd be at 375 whp easily on an E55-60 mix. One of the only stations in all of New England that carries it is ~25 minutes away, so I don't have an excuse.
BoostedTeaParty is offline   Reply With Quote
Old 10-19-2020, 12:35 PM   #1329
jason02wrx
Member#: 222893
2016 WRX DGM Limited
2002 WRB/2012 SWP Hatch
Dyno Type: DYNOmite
Boost: 20 psi
Cobb AccessPort v3
Cobb Big SF Intake
Perrin TGV Delete
EGR Delete
Cobb Bypass Valve
Thereís 4 in MA
jason02wrx is offline   Reply With Quote
Old 10-20-2020, 12:16 PM   #1330
BoostedTeaParty
Member#: 515430
2017 WRX Premium
'19 X3 M40i
Originally Posted by jason02wrx View Post
Thereís 4 in MA
I know about the one in Chelsea and Cambridge. Unless there is another one in north shore (or even NH) I don't know about, which would seriously make my day.
Old 01-28-2021, 06:14 PM   #1331
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
93 oct (my crazy 2008 STI is full E85 and I didn't want another E85 vehicle )
Cobb SF intake
FP Turbo inlet
BRZ intake manifold with 3" ETS FMIC
TGV upper and lower deleted (IBR BRZ IM adaptor)
EGR delete
Perrin IWG headers
Invidia catless J-pipe
Invidia 3" Q300 exhaust
Grimmspeed EBCS
Cobb AP
Previous setup (dotted lines) was on stock turbo inlet, Grimmspeed TMIC, and stock IM
user1029 is offline   Reply With Quote
Old 01-28-2021, 11:32 PM   #1332
egodestruct
Member#: 508775
2020 WRX
CWP
That's some good top end power. Is that mostly from the intake mani?
egodestruct is offline   Reply With Quote
Old 01-29-2021, 12:03 AM   #1333
user1029
Member#: 57064
2008 STi IAG built
FP turbo inlet probably helped a little as well
Still stock turbo and engine
Old 02-14-2021, 09:08 PM   #1334
nubWRX
Member#: 459345
Default 2015 WRX Dyno Thread
Mishimoto boxed CAI, invidia J pipe, R400 catback, TGV/EGR delete, Perrin charge pipe, Grim Speed TMIC, 93 Oct, COBB V3 - ProTune.
349 ft-lbs
320 whp.
nubWRX is offline   Reply With Quote
Old 02-15-2021, 09:31 AM   #1335
Straight6
Member#: 419593
Cobb SF intake
FP Turbo inlet
EGR delete
Perrin IWG headers
Grimmspeed EBCS
Cobb AP
Whoa, that is nice!
Straight6 is offline   Reply With Quote
Old 03-06-2021, 09:14 PM   #1336
Greezy
Member#: 521679
OMGHi2U 2015 WRX 394/362 e53
394hp/362tq at e56
Parts list(to the best of my knowledge):
COBB:
  • TMIC
  • AOS
  • BIG SF
  • EBCS
  • Resonated Catted J-pipe
  • Flex Fuel Sensor
Other Brands:
  • IAG Stage 2 FA20DIT Short Block
  • Boomba Bypass Valve
  • Awe Track Edition Exhaust
  • TGV Delete
  • EGR Plug(not delete)
Car is tuned for a max of e65 currently
91 Map was with some ****ty valero gas I had to put in since I almost ran out of gas on the way to the tuner so with some higher quality 91, it would likely be a little higher.
Next, I plan on getting a nostrum hpfp and going full e85 since it's a lot easier than going back and forth between the pumps.
Greezy is offline   Reply With Quote
Old 03-07-2021, 03:14 PM   #1337
wuuusaa
Member#: 92894
2015 Wrx
Wait is the color of your car Magnetite Gray Metallic with TE37's?
wuuusaa is offline   Reply With Quote
Old 03-08-2021, 10:57 PM   #1338
Actionwrx17
Member#: 464519
https://imgur.com/gallery/rpZR73J
17 wrx, stage 2 block, fp blue, killer b ewg header, ets fmic, brz manifold, port injected, motec ecu
Actionwrx17 is offline   Reply With Quote
Old 03-08-2021, 11:03 PM   #1339
wuuusaa
Member#: 92894
2015 Wrx
Do you guys set up rolling anti lag?
Old 03-08-2021, 11:08 PM   #1340
Actionwrx17
Member#: 464519
Itís set up, but not using it with just the stage 2 block and blue. Needs a closed block and bigger ets kit to really use. 2 fp turbo bearings couldnít handle it tuning it
Old 03-09-2021, 10:04 AM   #1341
noobultimatum
Member#: 431550
2016 WRX
ALL THE STAGES
This is on 93 with p/i?
noobultimatum is offline   Reply With Quote
Old 03-09-2021, 10:11 AM   #1342
Actionwrx17
Member#: 464519
Itís e60
Old 03-09-2021, 01:43 PM   #1343
noobultimatum
Member#: 431550
2016 WRX
ALL THE STAGES
Itís e60
So, If i am understanding correctly... The limiting part in generating power for your build is the turbo?
Old 03-09-2021, 09:31 PM   #1344
Actionwrx17
Member#: 464519
I love the set up, car is fast and fun but that turbo can only hold 24 psi, anymore then it breaks. If your looking to do a motec setup get a ets or killer b turbo kit. Just from my experience
Old 03-10-2021, 03:13 PM   #1345
noobultimatum
Member#: 431550
2016 WRX
ALL THE STAGES
You plan on upgrading the turbo to see where your system takes the power to? very interesting since you have controlled port injection now
Old 03-10-2021, 07:24 PM   #1346
Actionwrx17
Member#: 464519
Most likely, Iím starting to get smoking issues again, like the past 2 times when the bearing went out on it
Old 03-10-2021, 09:06 PM   #1347
Rexy18
Member#: 500337
You thinking about having the same guy try the repair a third time?
Rexy18 is offline   Reply With Quote
Old 03-11-2021, 10:53 PM   #1348
Actionwrx17
Member#: 464519
Probably, u know a better place to go to in nj?
Old 03-18-2021, 10:22 PM   #1349
user1029
Member#: 57064
2008 STi IAG built
Cobb SF intake
FP Turbo inlet
EGR delete
Perrin IWG headers
Grimmspeed EBCS
Cobb AP
I take that back, got E60 flexfuel tune
Old 04-08-2021, 09:09 PM   #1350
PilotKD
Member#: 131702
2017 WRX Premium
CWP
2017 WRX - Had BrenTuning do a lot of the installation and the tune (nothing but great things to say about them btw).
GS TMIC
GS Charge Pipe
GS EBCS
Cobb Big SF Intake
Cobb BPV
Cobb Catted/Resonated J-pipe
KillerB Swaincoated Header
Perrin cat-back exhaust
Radium AOS
Fresh set of plugs and an intake valve walnut blasting immediately prior to tuning.
I did not get a before dyno, but the car had a high-flow drop in air filter, GS TMIC, GS Charge pipe and Perrin cat-back with the Cobb Stage 1 93 octane map on it when it went in for the rest of the mods so I assume I was somewhere in the 255-260whp range beforehand if a stock 2015+ dynos around 240-245.
338whp/335ft-lb torque
PilotKD is offline   Reply With Quote
