Welcome to the North American Subaru Impreza Owners Club Saturday December 5, 2020
Old 10-25-2020, 11:01 PM   #1
PHARxMACYPIMP
Member#: 146403
2005 Legacy GTWagon
Pearl
Default Purchased used 6 speed...did I make a mistake?
So I picked up a used 05 STi 6 speed to swap into my Legacy advertised as 120k on stock power. Price was friendly and local but should I be concerned about the following images. It most certainly looks as if the thing was taken apart from the gasket sealer and oil leak?
Am I looking to get this serviced before I swap?
PHARxMACYPIMP is offline   Reply With Quote
Old 10-26-2020, 11:00 AM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
I would be more concerned with what looks like a big crack in the plate between the main body and the tail section.
If you had a concern, why did you buy it in the first place?
Old 10-26-2020, 11:05 AM   #3
shagfagon
Member#: 337836
2002 WRX Wagon
Its not a crack. Its a piece of gasket.
shagfagon is offline   Reply With Quote
Old 10-30-2020, 11:10 AM   #4
Sleeping 9-2X
Member#: 519801
Looks ok, I just bought a used 6 speed also, mine came with an axle input shaft seized into the transmission. Good luck with the tranny swap.
Sleeping 9-2X is offline   Reply With Quote
Old 10-30-2020, 11:18 AM   #5
Samurai Jack
Member#: 21145
2002 Enemy of Aku
If that's all it is, then from a couple of simple pictures, and no other info, it looks OK.
That's all anyone can say at this point.
Old 10-30-2020, 07:42 PM   #6
Sleeping 9-2X
Member#: 519801
That is definitely excess gasket, I had the exact same stuff on mine, perfectly normal.
