Welcome to the North American Subaru Impreza Owners Club Saturday January 16, 2021
Old 11-07-2020, 07:43 PM   #1
valerka6234
Member#: 349565
Default Power Loss / Boost Leak? / Up Pipe? / Loud Squealing
Hey guys. I have a 2014 Sti that is basically stock.
I’m having a loud squealing and hissing noise whenever my car goes to boost (3k rpms). Sounds like a loud pig! Noise sounds like is coming from passenger side. I checked for boost and vacuum leaks and replaced the following:
Intercooler couplers
Turbo inlet hose
All clamps
Car acts normal when idling; only weird under boost. Any idea what’s going on?
Could an up pipe be causing problems?
Problems started after I test fitted a cold air intake, took it for a drive, and put the stock back on (I know, it needed a tune).
valerka6234 is offline   Reply With Quote
Old 11-08-2020, 12:02 AM   #2
Raven2510
Member#: 378873
2012 WRX Sedan
Ice Silver Metallic
Did you check the intercooler to throttle body coupler? Its know to slide off or crack.
Check the turbo inlet where it meets the turbo. It can also crack or fall off.
Raven2510 is offline   Reply With Quote
Old 11-08-2020, 12:17 AM   #3
valerka6234
Member#: 349565
Yes I changed them both
Old 11-08-2020, 11:22 AM   #4
heiche
Member#: 400179
2009 wrx
sounds like a boost leak test might be in order. it only takes 2 or 3 psi usually to find leaks. checking by eye is a good first thing to try, but there are so many places that boost leaks can hide - but they usually can't hide from a boost leak test. while testing listen for the same noise, sometimes you can feel air blowing out from a leak, or sometimes spraying soapy water on everything will cause bubbles at the leak.
heiche is offline   Reply With Quote
Old 11-08-2020, 12:41 PM   #5
valerka6234
Member#: 349565
Do I need to block off the vacuum lines and open the engine oil cap before I do a smoke test? I’m getting different answers from different people
Old 11-08-2020, 12:48 PM   #6
heiche
Member#: 400179
2009 wrx
yeah, lots of different ways to do it. personally i just go for the very low (2 or 3 psi) test, remove oil cap, then remove the large hose from the air cleaner housing and use something cobbled together to get air into that. then listen and feel for leaks, and spray soapy water if necessary on everything that could be a leak.
with that low pressure test, i don't find it necessary to block off any vac lines etc.
Old 11-13-2020, 03:18 AM   #7
Sjp831
Member#: 519457
if you do a smoke test, is that more thorough then a pressure test? or do they achieve different things?
also when doing a smoke tes, do you need to block off vacuum lines?? i need to know as well lol
Sjp831 is offline   Reply With Quote
Old 11-20-2020, 12:23 AM   #8
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
Lots of people would say this harms rubber hoses etc
But
I would spray either carb/brake cleaner around engine bay
With car idling.......if you have dip/rise in RPM.....there is your leak man
(If u use non-chlorinated BC, RPM will dip down)
AliBenn is offline   Reply With Quote
