#1 |
Member#: 510046
![]() I'm going to try and keep this short, I'm not looking to be lectured or to be told everything else that could be wrong, I'm just trying to figure out why for the time being; here we go.
Car is a 2006 sti, 580 miles ago had a full rebuild with forged components and hardware. This includes pistons, rods, head studs, master gasket kit, full valve job, timing belt, water pump, and all other items you do with a rebuild. Today I hopped in the car, let is idle for :45-1 minute, then started on my way. 30 seconds later I hopped onto the main road, went 1st, 2nd, and shifted into 3rd at 4500ish, shifted into 4th and the car died upon going into gear, I coasted to the side of the road, tried to restart and it just cranked. checked fuel, spark, and ECU, all good. Pulled the timing cover off to find my driver side intake cam has slipped 180 degrees out! removed the belt, checked all the idlers, checked the tensioner, checked all the cams, and of course rotated everything by hand. I have to be missing something right? I used an AISIN kit purchased from Amazon sold and shipped by Amazon, tensioner piston is not wet, no bearings are broken, and all gears have all sprockets intact. Can anyone shed any light on what could have possibly happened here? And for those of you wondering, I put the motor back into time, with the old belt and tensioner and it fired up, it turned over and idled without any concern I could hear. I will be doing a leak down test to see if there's anything that was hurt; but I'm just trying to get to the bottom of what happened right now.
#2 |
Member#: 450712
Vehicle:04 STi WRB |
![]() Someone correct me if I'm wrong... I would have thought that with the timing being out that far after slipping - your pistons would have had a conversation with your valves, being that these engines are interference engines. So I'm surprised that re-timing it that it even started back up.
Have you driven it since getting it back together? |
#3 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
![]() if OP was lucky it would have just not been able to create compression thus the shutoff...dunno what could have happened to create 180 degree...thats alot of slip..
#4 |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
![]() Could have been the AISIN kit tensioner. Thats why I use gates. Only thing i can think of.
#5 |
Member#: 510046
![]() Last edited by Jp925; 11-12-2020 at 03:11 PM. |
#6 |
Member#: 373868
Tri-State
Vehicle:'04 STi WRB |
![]() Is gates good again I've heard mixed things? On the flip side I've always used aisin parts with good success in the past. Many of them are made in Japan. I'm surprised this tensioner failed so badly.
#7 |
Member#: 510046
![]() I've read several articles about AISIN being the direct OEM supplier. I'm just not sure what to make of this horrible failure.
#8 |
Member#: 22412
SWIC
Vehicle:2012 Legacy 2.5GT Ice Silver Metallic |
![]() Are all of the belt guides in place?
#9 |
Member#: 510046
#10 | |
Member#: 373868
Tri-State
![]() Quote:
Majority of aisin off the shelf parts are made in Japan or USA. I was strongly considering them over gates for my next timing belt change so seeing this is making me wonder the root cause of OPs issue since typically the quality of Aisin parts are not questionable. |
#11 | |
Member#: 510046
![]() Quote:
#12 |
Member#: 510046
![]() Has anyone with any timing belt they’ve ever bought received “bleeding” instructions? How many subie guys out there bleed their tensioners before install?
#13 |
Member#: 512771
#14 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
![]() I would say its a installers fault as it is very wierd to be exactly 180 degrees out. to me that very suspect
#15 |
Member#: 487
TXIC
Vehicle:1998 /2005 STunIcorn Acadia Green RS-T |
![]() Probably too obvious
Intake cam bolt torqued correctly? I remember lining up all 7 timing marks (B4 I bought cam bolt lock) That intake cam would spin 180 degrees if I breathed on it too hard while lacing tbelt around Tensioner is good guess as well |
#16 |
Member#: 510046
![]() Confirmed bunked tensioner, seems to be just a huge bummer of dumb luck. Ended up buying the gates blue kit and installing that. I have a pretty bad valve tick and leak down shows down 20 psi from the exhaust valve in cylinder 2. I’ll pull the heads and have them rebuilt in a few months. Major bummer but looks like it’s just a random failure.
#17 |
Member#: 510046
