Welcome to the North American Subaru Impreza Owners Club Saturday March 6, 2021
Old 11-12-2020, 10:50 AM   #1
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default Killer B Motorsport - High Flow Water Pump Inlet
• 3D CAD Designed & Simulation Tested
• Made from Heat Treated Cast Aluminum
• Smooth Taper Inlet for Turbulence Free Flow
• Bead Assures Proper Hose Connection
• Large Smooth Bend Transitions into the Housing with Maximum even Flow distribution.
• Machined Flange for a Leak Free Install
• Designed and Made in the USA
In typical fashion, we just can't leave things alone. We've been making a high flow water pump inlet for years that have been geared towards the higher end track guys. We've change manufacturing technologies, tweaked the design some, and will be providing a High Performance Water Pump Inlet at a more reasonable price: $99. Presenting, the Killer B Motorsport V2 high Performance Water pump Inlet.
Old 11-12-2020, 12:29 PM   #2
08wrx440
Member#: 261040
04 STi
Bravo for another great product!
08wrx440 is offline   Reply With Quote
Old 11-12-2020, 02:23 PM   #3
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Pics?
Old 11-12-2020, 02:25 PM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thank you!
Originally Posted by BlackFighter View Post
Pics?
They are in the OP. Can you not view them?
In not you can view them HERE too.
Old 11-12-2020, 02:50 PM   #5
JSR84
Member#: 469585
2009 STi
Funny enough I just ordered one along with a filler neck relocation and upper coolant reservoir yesterday. ***128077;
JSR84 is offline   Reply With Quote
Old 11-12-2020, 09:51 PM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Awesome. Thanks so much for your support!
Old 11-15-2020, 12:25 PM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Have had a couple questions about the factory hose fitment. It's super easy. Reverse the hose and trim 1/2 from each side and it fits perfect.
Old 12-18-2020, 10:57 PM   #8
08wrx440
Member#: 261040
04 STi
Are these available yet
PM me price shipped to 44149 !
Thx!
Old 12-18-2020, 11:22 PM   #9
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Midnight Black Pearl
Thx!
BAM!
https://www.killerbmotorsport.net/hi...ries.html.html
K3rm1tth3fr0g is offline   Reply With Quote
Old 12-18-2020, 11:25 PM   #10
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Going to be switching to either a Koyo or CSF rad in the spring. Would you recommend one of these for a 207 while I'm in there? Any other cooling system mods you recommend? Already have cyl 4 mod. Currently have 20g xtr and am planning on going EWG, and flex fuel in the spring. Will be doing track days and some auto-x.
snow_bound26 is online now   Reply With Quote
Old 12-19-2020, 11:04 AM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by K3rm1tth3fr0g View Post
Beat me to it, thank you!
Koyo-R is the lowest grade radiator we recommend. I've not tested the CSF. In your location, ambient temps shouldn't be bad like we see with guys in Arizona, SoCal, Australia, Philippines, etc.... A FMIC will also contribute to the radiator needing improved capacity, as well as significant power increase, which you're not really at yet. Also the type of events and how you drive. Road coarse will give you far better ambient airflow than and be far less abusive than brake-boosting through and auto-X event (no airflow and continuous high load). So many factors to consider. And if all else fails, we sell the hammer (radiator) when no other tool will work. Another tip for improving radiator performance (regardless of what you use) is to improve ambient airflow. A splitter, radiator shroud, belly pan (although the OEM one is really good), and even closing up gaps around the radiator will all contribute to improved cooling performance.
Old 12-19-2020, 01:01 PM   #12
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Auto-x is not a focus and no intent on being competitive. I use it a few times a year for training and keeping my reflexes good. I have fun with it but no interest on being competitive. Mostly HPDE and track days working toward time attack style events. I do spend time in UT and may do some track days there but it would be in May, September and October.
I will be making a custom belly pan and splitter in the spring. Already have a radiator shroud. I use a TMIC so no FMIC blocking flow. I'm using OEM fans and will be keeping them.
I was more thinking how you stated this pump housing is designed for higher rpm. Where do you find the OEM housing starts to suffer from turbulence?
Old 12-19-2020, 02:03 PM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Smart move. OEM fans are as good as it gets unless you're going to spend +$600 for a fan.
+6,500 RPMs and worse above 7,500. Sustained high PRM is where this product shines.
Old 12-19-2020, 02:19 PM   #14
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Perfect. This is exactly what I needed to know. Looks like a worthwhile upgrade for me. Thanks
Old 01-19-2021, 11:31 AM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No problem! At the price point, it's a popular piece
