Welcome to the North American Subaru Impreza Owners Club Thursday April 15, 2021
Old 05-31-2020, 08:05 PM   #126
JDwhiteWRX
Member#: 190502
This weekend I finished the passenger side rear upper control arm which was the final control arm for this project. I had already cut and notched some of the tube whilst making the other side so it came together relatively easy.
https://i.imgur.com/EZu9uVR.jpg?1
I then installed the rear differential and rear axle to get a look at how everything has come together.
https://i.imgur.com/Ardw1kP.jpg?1
Moving forward I have some big purchases to make which may take a bit of time to save some money.
The first thing I need to do is purchase a manual transmission, adapter plate and clutch setup. At this stage I am looking at the BMW ZF 5 speed as the best option, obviously a sequential would be the ultimate but its just not in my budget. The BMW trans seems to be a strong and affordable option, whilst not being too heavy.
With the engine mated up to the trans I can then do all the fabrication around the engine mounts, front crossmember and steering rack.
I also need to get some wheels and tyres.
JDwhiteWRX is offline   Reply With Quote
Old 06-01-2020, 09:56 AM   #127
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Have you seen what the DKG ECU guys are doing with the BMW 7AT DCT ?
It might be able to do everything you want
https://www.dkgecu.com/l/what-is-dkgecu/
Gigs90 is offline   Reply With Quote
Old 06-01-2020, 11:47 PM   #128
JDwhiteWRX
Member#: 190502
Thanks, I had not seen or considered this option but it does look promising! I will have to do some research.
Old 06-03-2020, 05:24 AM   #129
JDwhiteWRX
Member#: 190502
So far the only downside I can find is the weight penalty, these DCT are very heavy at about 30 - 40kg more than the other manual trans options I was considering.
At least its in the center of the car and down low, paddle shift would be really nice to drive!
Old 06-12-2020, 07:25 PM   #130
JDwhiteWRX
Member#: 190502
Saving up for a few bits at the moment but that hasn't stopped me working on the car.
Something I have been thinking about for a while is pushrod suspension but I was just not sure it was something I could do. So I figured while I'm waiting I would make a full scale mock up and see if I could get my head around it.
The main reason for doing this is to design a rising rate suspension to help with aero loads. Version 1.0 was completed last night, below is the video
https://www.instagram.com/p/CBU5x_1AjT1/
This allows me to measure the wheel travel versus the shock travel. I then put the numbers in excel and I can plot a graph showing whether the design is regressive, linear or progressive.
Version 1.0 came out regressive and it is not using all of the shock travel. So by adjusting the angles on the bellcrank and the distances between holes I will work to getting it how I want.
Old 06-21-2020, 04:50 AM   #131
JDwhiteWRX
Member#: 190502
I have finally selected the coilover shocks I will be using with the pushrod suspension in the front.
They are from a Suzuki GSXR1000 09 - 15 year models and they feature 11.6kg/mm springrates, both high and low speed compression dampening and rebound.
Now that I have exact measurements of the spring rate, eye to eye length and shock travel I can complete the bellcrank design and possibly begin fabrication. The only thing I am not sure about at this stage is the amount of rate increase I should design into the rising rate suspension. I have ordered a book to hopefully help with this.
Old 06-22-2020, 10:16 AM   #132
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Interesting. I'd been looking at similar aged R1 dampers for my Locost project. They are also low and high speed on dampening and rebound.
Old 06-23-2020, 03:09 AM   #133
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Nice. Looks like pretty good dampers.
Old 06-26-2020, 04:36 AM   #134
JDwhiteWRX
Member#: 190502
Well after 14 variations of my design I feel I have come up with a scale model that is at least 95% complete.
In order to complete it 100% I would need to know the final corner weights.
I wanted to write down something about how I got to this point, a few weeks ago I knew almost nothing about pushrod suspension other than there would be advantages to having it in this project.
So if I had some CAD software and knew how to use it I could have saved myself some time but I don't and there is something special about building a scale mock up, holding it in yours hands and seeing something work in real life, not on a screen.
I knew that I needed to know how much the shock would move relative to the wheels, this is the motion ratio. It does not stay constant throughout the movement of the wheel.
The next consideration is packaging. I knew I could put the shock almost anywhere it would fit but I wanted to keep it as low as possible to benefit the COG. The obvious choice was almost directly inline with the motion of the lower control arm, the only things in the way are the main chassis frame rail and the steering linkage between the steering rack and steering column.
Early mock up was done with some cardboard and a pressure can.
https://i.imgur.com/xcBHrI7.jpg?1
I knew there was a possibility to use motorcycle shocks but had no idea if it could really work on a full size car until I had figured out the motion ratios. I used the dimensions of a Suzuki Hyabusa shock found online as it was the largest size with a decent amount of springrate options.
Next I made the 3 points everything would pivot around out of some steel and minimally tack welded them into position on the car.
This is the pushrod attachment on the lower wishbone. The hole position is based on getting a 5/8" rod end as close to the outer pivot as possible.
https://i.imgur.com/otzBqgp.jpg?1
The bellcrank pivot is shown here, I ended up moving this a couple of times.
https://i.imgur.com/M9gcScU.jpg?1
All the other parts are made of some scrap aluminium extrusions I had lying around the garage. This photo shows all the bits used so far.
https://i.imgur.com/9wwsBev.jpg?1
To mimic the shock travel I made the eye to eye length match the Hyabusa shock with a ruler stuck inside the extrusion to read zero millimetres.
The whole point of using this pushrod setup is to have the springrate increase at the wheel (wheel rate) as the aero pushes down on the car at increasing speed. To do this you need a rising rate suspension.
The parameters you can play with to achieve this are all in the bellcrank design.
You have the distance to where the pushrod mounts to the bellcrank from the pivot point and the distance to where the shock mounts to the bellcrank from the pivot point.
Then you have the angle between the pushrod attachment point on the bellcrank and bellcrank pivot and the angles between the shock attachment point on the bellcrank and bellcrank pivot.
A good starting point is 90 degrees for both these angles. For progressive you set the shock angle at 90 at full bump travel and the pushrod angle to 90 at full droop.
Why 90 degrees?
As the wheels come up in bump the shock approaches 90* which is the angle at which it is pushing back most thus increasing the rate at the wheels. If it were to go past 90* then it would become easier again so this is why we set it to 90* at full bump travel.
On the pushrod side the angle is getting smaller as the wheel comes up so by setting it at 90 at full droop all the advantage is with the shock as it approaches 90.
These 90* settings give you a very progressive rate but its a good starting point and then you can adjust to lower the rate from there.
The way I got the starting 90* angles was two use to separate bits of extrusion with holes drilled in them instead of a solid bellcrank, see photo below.
https://i.imgur.com/en1i9zX.jpg
So I just set my angles in bump and droop and scribed a line in the middle so I could make a solid bellcrank. It took a few tries as the shock would hit the chassis rail at full droop or was too close to the steering linkage.
You can see in this photo I had some cardboard to show where the spring would sit and possibly hit things.
https://i.imgur.com/f0UCr1A.jpg?1
Once I had a solid bellcrank made I could then move the wheel in 10mm increments and measure the position on the shock mock up. The first few didn't work as I was not getting full shock travel or too much travel or the shock was hitting the chassis rail etc. I had to keep drilling new holes and making longer pushrods.
Once I had something that gave me full shock travel for the complete wheel travel I made a spreadsheet in excel and plotted a graph.
Motion ratio = wheel travel / shock travel
not to be confused with installation ratio which I have seen interchanged with motion ratio and this added a lot of confusion
If the motion ratio is decreasing with wheel travel then you have a progressive suspension rate.
How much progression do you need?
Well I still don't know, the last 2 books I bought didn't really have as much detail on progressive suspension rates as I would have liked. I have read that 10% is enough but that was a road car, the Carroll Smith book I have is too old but he does mention no more than 20% increasing slope if you graph the wheel rate.
The spring ratio is constant, its the wheel rate you want to know.
The wheel rate is just the spring rate / motion ratio ^2
My most recent version of bellcrank gives an 11.6% increasing wheel rate slope if you graph it but what I have done is measure the motion ratios of pushrod to bellcrank attachment points in 4 positions around a central point so I would know the exact effect of moving this attachment point in any direction. So once I know my final corner weights I can make a bellcrank exactly how I need it. I can also put multiple attachment points on the bellcrank if I require stiffer or softer wheel rates after testing.
I didn't end up using a Hyabusa shock in the end, they are only 2 way adjustable, not 3 way like the GSXR1000 shocks I bought and after working out the math I knew almost any shock could work. It's crazy how cheap they are to buy too!
Old 06-27-2020, 09:23 AM   #135
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
'08 Mustang GT (the toy)
Couple of thoughts . . .
Motion ratio would be the reciprocal of installation ratio. So if somewhere in your math you were going to divide by either of those, it would still work by multiplying by the other. In Excel, I tend to worry less about what the parameter I'm using is called and just work the math correctly.
I think for progression you might want to start by setting some target for how much loss of ride height you're going to allow from aerodynamic downforce at some speed (probably up around your maximum speed, though I suppose you could target a specific ride height for the speed through an important high-speed corner). I'm guessing that you might not want to be sitting on the bump stops, especially considering what braking is going to do.
FWIW, I remember reading that when the upper level racing series started tinkering with rising rate suspensions to the point where rising rates were employed at both ends of the car you could have a car that was great one week on one track and terrible the next week on another.
Norm
Old 10-17-2020, 06:53 AM   #136
JDwhiteWRX
Member#: 190502
Just watching some videos on the HKS TRB03 and found some information on the springrates they are using.
34kg front and 60kg rear, pretty crazy!
https://i.imgur.com/owwQ5Ds.jpg?1
https://i.imgur.com/wWtmk7n.jpg?1
This project is still going, I have just been collecting some small parts and investing in new tools lately. Hopefully I can bring some updates soon.
Old 10-17-2020, 08:55 PM   #137
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Good to hear, looking forward to updates.
Old 10-19-2020, 04:31 AM   #138
JDwhiteWRX
Member#: 190502
Today I picked up a set of tyres which I will need to have so I can modify the body for the new ride height and make some new panels to suit. These tyres are way past their use by date but I got them dirt cheap. No point buying new tyres unless I was planning to drive this thing some time soon.
I couldn't resist the opportunity to mock up what the car might look like with some wheels on, speaking of wheels, they will be my next purchase.
https://i.imgur.com/lvirmxj.jpg?1
https://i.imgur.com/mYQnwgg.jpg?1
Old 10-19-2020, 07:00 PM   #139
parker
Member Status: Member
Member#: 46241
- Can I get
a wayo
Yeah, when it comes to certain mock ups, resistance is futile.
parker is offline   Reply With Quote
Old 10-27-2020, 01:53 PM   #140
Homemade WRX
Member#: 33782
96 3MI Racing
I snagged some Porsche cup car take-offs for the same reason!!
Old 11-22-2020, 09:11 PM   #141
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Nice! Keep the info coming.
Old 11-29-2020, 08:16 PM   #142
JDwhiteWRX
Member#: 190502
Hey guys, a few things have been happening.
To start with I have taken delivery of my new AC/DC dedicated TIG welder. Up until now I have been doing all my welding using a multi-purpose MIG welder that has a lift-arc TIG function in DC only.
Now that I have a welder that can weld any type of metal I can save a lot of money by making my own catch cans, dry sump tank, swirl pots for example. So it has cost a fair bit up front for the welder but over the long run it should pay for itself.
After a fair bit of back and forth with measurements I have also ordered a set of wheels from Japan. The wheels are 18 x 10.5 but I have had to be very careful with the offset because I am in danger of the car being too wide to fit on my trailer. I won't spoil the surprise and say what they are but as soon as they arrive there will be lots of photos. Unfortunately due to Covid they are going to take a fair while to arrive.
The last thing is I have ordered a pair of genuine Subaru rear wheel bearings off the 08 onwards STi to convert the rear end to 5x114.3 pcd. The front RX8 uprights are already 5x114.3 so this has given me larger wheel bearings and a much wider selection of wheels to choose from.
Old 11-29-2020, 09:16 PM   #143
chanomatik
Member#: 159474
2017 Impreza Sport
Lithium Red - OLDKID
I love this thread.
Old 12-09-2020, 04:52 AM   #144
JDwhiteWRX
Member#: 190502
Rear wheel bearings arrived today, brand new genuine Subaru from the 08+ STi. Got these to convert the rear to 5x114.3 PCD so when my new wheels arrive I can bolt them straight on.
The front PCD is already 5x114.3 with the Mazda RX8 front uprights.
https://i.imgur.com/bdzalF5.jpg?1
Next to the old wheel bearings you can easily see the size difference.
https://i.imgur.com/cE8eXWg.jpg?1
Old 12-23-2020, 04:23 PM   #145
WeRX
Member#: 3652
1989 Honda Pirate
Type RRRRRR
Any updates to this awesome thread??
WeRX is offline   Reply With Quote
Old 12-25-2020, 10:15 PM   #146
JDwhiteWRX
Member#: 190502
Hey mate, some work has been happening, I have been modifying the Honda K24 valve cover so that the motor is less tall and dry sump ready. The design is based on the Honda Racing HPD valve cover.
I'll do a more detailed post once the work is done but here is a teaser for now.
I am also hoping to have a gearbox coming within the next few weeks.
Old 12-26-2020, 12:12 AM   #147
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
we tried to do that for a k20 project. it didn't go super well... ended up getting really warped from all the welding. If yours turns out nice i might have some questions for you. Good work!
Zefy is offline   Reply With Quote
Old 12-26-2020, 01:57 AM   #148
JDwhiteWRX
Member#: 190502
That is good to know, I am most concerned about the welding because I only recently bought a TIG with AC and need more practice with it before I tackle this job.
The saving grace is that the welds will need to be ground down so I should be able to weld small sections at a time without worrying too much about how good the welds look. Some large chill blocks should help too.
Old 12-28-2020, 10:35 PM   #149
JDwhiteWRX
Member#: 190502
Some exciting news, I finally got a trans for the car! It's a ZF 5 speed S5D 320Z from a BMW. Good for 320Nm of torque which should be plenty behind my turbo K24 engine. I weighed the box at around 37kg (82lbs) which is rather light considering the strength, its very compact too.
https://i.imgur.com/mShV1Z8.jpg?1
Now I just need to get an adapter plate and I will be able to get a lot more fabrication done, engine mounts, trans mount, steering rack mounts etc.
Old 01-01-2021, 08:30 PM   #150
JDwhiteWRX
Member#: 190502
I did some test welding yesterday on some of the scrap cast aluminum I cut off the valve cover just to see how it welds and how well it might clean up after with a flap disc and file finish.
It was not as difficult as expected so as long as I can manage the heat I have a lot more confidence in the project now.
