Welcome to the North American Subaru Impreza Owners Club Friday March 5, 2021
Go Back   NASIOC > NASIOC Classifieds > New Product Development
Old 04-03-2020, 12:10 PM   #51
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by 2slofouru View Post
Cool deal. Anyone have a photo of one installed yet, and ground clearance?
The clearance is the same as our older Fab'd pan.
We do keep getting asked about durability, which was one of my own personal concerns with using cast technology. We use a very specific material and process that is only done here in the USA. Needless to say, it's not cheap, but the quality is outstanding.
In regards to toughness, we have MANY installed on rally cars. Some have some great stories of survival. This pic from last year is one of my favorites. This team went off course in a bad way. The belly-pan pictured here was hit so hard that it pushed the pan (engine) hard enough to tear both motor mount. The pan is still in use today! The engine was spared of oil starvation as you would have normally expected with an impact of this magnitude.
Old 08-23-2020, 02:24 PM   #52
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Sorry for recent shipping delay. Back in stock!!
Old 09-01-2020, 01:21 PM   #53
Jedi03
Member#: 491095
2009 STi Blue
thats ridiculous...but based on that it sounds like i could use my oil pan to jack up my car! lol...i dont suggest it and i am not really going to try it!
Jedi03 is offline   Reply With Quote
Old 09-21-2020, 06:36 PM   #54
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I've never done it, would not recommend it, but I've seen it
Old 09-23-2020, 01:47 PM   #55
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
I had to use my killer bee oil pickup as a trailer hitch once... tough.
As always your the engineering of your products is impeccable, well thought out and tested. But my favorite thing about your products has always been that you don't rest on your laurels, you always refine the process and part where you can. Every build I have done since I had first met you has at least 1 if not more of your parts.
robbieshonda is offline   Reply With Quote
Old 10-09-2020, 01:07 PM   #56
Sample_Name_123
Member#: 473565
Is there a plan for an FA version?
Sample_Name_123 is offline   Reply With Quote
Old 11-13-2020, 08:57 AM   #57
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
There is a plan
Old 01-04-2021, 07:35 AM   #58
wuuusaa
Member#: 92894
2015 Wrx
There is a plan
I take it probably won't be for another couple of years?
wuuusaa is offline   Reply With Quote
Old 01-04-2021, 08:33 AM   #59
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Like many others, we're waiting on the next gen STi
Old 01-09-2021, 09:19 PM   #60
ScoobyJD
Member#: 185910
2007 FSXT
This may have been asked before but I don't feel like looking through all the posts. What is we bottom out and it hurts the pan. Won't a cracked pan be hard to weld if not impossible as opposed to just bending the pan back and welding it?
ScoobyJD is offline   Reply With Quote
Old 01-10-2021, 01:03 AM   #61
Jedi03
Member#: 491095
2009 STi Blue
its only as hard to weld as other similar materials...stock pan is steel, the killer b is cast steel...different methods for welding but all fixable
Old 01-10-2021, 10:23 AM   #62
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We've actually never once had a cast pan get damaged. At least I've never seen one. The fab pans, I've seen three come back: two from drag cars that threw a rod into the side and deformed/cracked a spot in the side, and another guy who got into a catastrophic accident and a curb damaged the pan.
We weld the pans, fabricated and cast. They both weld very nicely.
Just an FYI, our cast pan is aluminum. Each is also heat treated twice to attain T6 to maximize strength and toughness. No one else does this (likely because of the cost it adds), but it does make for a lighter and stronger part.
Old 01-11-2021, 12:14 PM   #63
Jedi03
Member#: 491095
2009 STi Blue
my apologies! you are correct that is a lot of extra cost, but you putting that into your product helps keep us guys using you as the go to! Hey as random thought, have you thought about putting together a dry sump kit? you have a lot of other high end stuff and this would be great to come from you...from my perspective at least!
Old 01-11-2021, 01:46 PM   #64
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We've consulted with teams to spec out DS systems, but the 'requirement' for DS is extremely low, thanks to some of our products actually.
Our pan on its own is good to ~1.6Gs. Anything over that tended to be problematic due to oil surge out the heads causing the oil available in the sump to be reduced. Our Oil Control Valve that was released a few years ago addressed that issue, which generally allow ~1.8Gs sustained. That's pretty much open class T/A territory. I welcome logged telemetry above that, but have yet to see it be produced. A couple have claimed to, but no logs So between you and me, we do have a new pan and pickup coming out for the top 1%-ers. It addresses high crankcase pressures and oil surge up the back of the crankcase during extreme launch/gear changes at 800+hp, improved oil control to the pickup, and the highest flowing oil pickup ever (yes we did test them all).
But in short, we spec out DS systems per application. The few instances we have, it has really been required; Circle/oval track, and Aerobatic Aviation applications. For anything else, there's just no need for the complexity, maintenance, and cost.
Old 01-17-2021, 01:27 AM   #65
Jedi03
Member#: 491095
2009 STi Blue
lol ya its a pretty penny to put those in...will be excited to see the new stuff! I definitely dont put my car through the paces to need it, just one of those what if upgrades lol!
Old 01-17-2021, 10:16 AM   #66
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I think we all at one point or another get caught up in that mindset.
Worse we see too often, 'I saw this setup on a racecar (of course built for a very specific single use) and need it on my street car because I'm making 500whp'. That's almost always NOT why to pick a component or setup.
Old 01-25-2021, 12:25 AM   #67
SDblitz858
Member#: 498585
Hello! i see some people having problems with leaking oil thru the oil pan dipstick tube? and having to put rtv sealant on the hole? is this because of user install error? or there are new O rings provided to change the stock one and makes it feel “ tight” when the dipstick tube is inserted on the oil pan?
also, is it really necessary to take off the airpump and dipstick bracket? or i dont need to?
just curious seen some post on other forums.
SDblitz858 is offline   Reply With Quote
Old 01-25-2021, 11:29 AM   #68
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I have heard, but haven't seen personally. We've never had a leak here, but I have a theory.
I believe when there have been issues, it has been with the OEM o-rings being re-used, new OEM o-rings were used, or dipstick tube was damaged during removal. If you use the OEM o-rings, they can bind, twist, and even fold when the tube is inserted into the pan. This can cause a slow-to-fast leak. Using our supplied o-rings, the unit should not leak.
I don't believe the air pump needs to be removed to reach the dipstick tube mount, but a socket extension to reach the bolt is needed.
Old 01-25-2021, 12:47 PM   #69
Jedi03
Member#: 491095
2009 STi Blue
i was one with the same issue, took several tries till i got the following to work...put new rings and as much RTV as i could between the two rings and then squirted some in the tube w/dipstick settled and so far so good...not sure where issue is as fit seems similar to OEM and did not have leaks with OE pan
Old 01-25-2021, 03:40 PM   #70
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Did you put the o-rings in dry? When dry they can roll out of the groove. They need some lube so they stay put.
Old 01-25-2021, 06:17 PM   #71
Jedi03
Member#: 491095
2009 STi Blue
nope...plenty of oil of different weights to try to help it...
Old 01-27-2021, 05:35 PM   #72
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thread announcement, we have a new pan (and pickup) coming out for those looking for the best obtainable performance. Our new Super-G (pat. pending) is coming soon. Only teaser pics for now :P
