Welcome to the North American Subaru Impreza Owners Club Thursday February 25, 2021
Old 12-22-2020, 07:24 PM   #226
funk32
Member#: 245787
GD Race Car
very interesting work here! love the data behind it.
funk32 is offline   Reply With Quote
Old 01-12-2021, 10:09 AM   #227
Aczwild
Member#: 71721
98 RSTi, 00 RS
13 Sierra
Would love to see where you mounted the Volvo EPS setup. Just pulled one from a ‘05 S40 for my ‘00 RS track car build.
Aczwild is offline   Reply With Quote
Old 01-12-2021, 01:52 PM   #228
Barge
Member#: 62941
2004 #LesboRacer
#TunedbyBarge
Originally Posted by Aczwild View Post
Would love to see where you mounted the Volvo EPS setup. Just pulled one from a ***8216;05 S40 for my ***8216;00 RS track car build.
I'm not sure where his is mounted but I removed the factory battery tray, drilled a giant hole to recess the pump motor down into the fenderwell and bolted it up there.
I'm using the model with the integrated reservoir.
I don't think the pump was having an issue after changing some other components around but I also added a little cooler in the return line.
My hoses are rather short this way as everything stays on the drivers side of the car. I use an AN adapter on the pressure feed with a hydraulic face seal type o-ring (the factory fitting is some oddball metric tube nut that I couldn't find anywhere).
The return, after having fitment issues with an AN adapter I ended up cutting off the stock return pipe and double crimping on some Parker 801 hydraulic hose for a return.
Barge is offline   Reply With Quote
Old 01-16-2021, 03:37 PM   #229
Sgt.Gator
Member#: 374688
2005 STI
Aczwild and Barge: My installation is not something you would do in a street car. Because it's a full on race car with no passenger seat too, we mounted the pump to the passenger side floorboard, close to the oem ecu. We drilled holes thru the floorboard to the Mooresport rack, which makes for very short lines. We remote mounted the reservoir up on the dash bar where it's easy to see the level and add fluid. Sorry no pics, I'll post a couple later.
On the rack we used the Mooresport AN adapter:
We have an issue with the Mooresport subframe fitment, it rubs on the steering rack rubber bellows and during the course of the race we wore a tear in it. We noticed this when we first setup the rack in the subframe and hoped it would take a lot longer to cause a problem, but no. We are hoping to find a smaller rubber bellows that will fit and not rub.
Lots more upgrades happening over the winter. To start with we are probably going to entirely redo the wiring and gauges with the new AIM PDM + Display + Logger. Most of the aftermarket gauges will be replaced with AIM sensors and the display. Also a mount for the new Garmin Catalyst. We doing CAD (Cardboard Aided Design) now to see how they will all fit.
AIM PDM/Logger
https://www.aim-sportline.com/en/pro...dm08/index.htm
and
Garmin Catalyst
https://buy.garmin.com/en-US/US/p/690726
In the spring I'll be giving y'all a review on both products.
We are also having an issue with boost creep. It doesn't show on the dyno but it does on the track. It may be related to the dyno being at 4,000' and racing at sea level. We have talked with ATP and have some options on how to fix that issue.
Other mods: We are replacing the -AN line from the DS tank in the trunk back to the oem oil pump intake with solid tubing most of the way. More flow, less restriction, less weight.
Rear Diff Pump & Cooler and sensor to the AIM logger.
The windshield has taken a beating over the years and has a couple of cracks. We are debating replacing with a polycarbonate windshield from racingshields.com. We made our own rear poly windshield so we may make our own front one too. The issue is scratch resistance in a car that could go several hours racing in the rain with the wipers on. Racingshields makes strong claims about their scratch resistant coating.
The flat bottom has some off track disturbances to it that need to be fixed.
Sgt.Gator is offline   Reply With Quote
Old 01-17-2021, 07:56 PM   #230
Aczwild
Member#: 71721
98 RSTi, 00 RS
13 Sierra
Thanks for the insight! This will be going into my '00 RS that is full racecar and I pulled the Volvo EPS with the remote reservoir as well as I was thinking of mounting it in the passenger side footwell too with the reservoir mounted to the dash beam or door bars. I like your idea and would love to see how you routed the lines to avoid the exhaust system.
Old 01-21-2021, 11:10 AM   #231
Sgt.Gator
Member#: 374688
2005 STI
I'll get you some pics!
Old 01-21-2021, 02:20 PM   #232
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Going to be interested in hearing your review of the Garmin.
BlueSTI4Me is offline   Reply With Quote
Old 01-21-2021, 04:00 PM   #233
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
It "looks" like it would be useful!!! Hope it preforms as advertised.
Scuby04STi is offline   Reply With Quote
