#101 |
Member#: 518381
![]() Only if someone would commit to making a PNP harness.I would if I was confident and experienced to do so,but electrical is not my thing.
On those 10 pin connectors there is a 10 pcs minimum.You need 2 for yourself And are left with enough connectors to make another 4 and offer them for sale.I wouldn’t mind contributing to that to get the ball rolling if someone committed to making it.I was hoping Andrew_l_s would make them since he offered a PNP harness for the front camera and already invested in a crimper. Some one please make this harness so I can order the folding mirrors.
#102 |
Member#: 518663
![]() Nice mod man! I really appreciate you sending out actual instructions making it a fairly easier diy for newbies wanting power folding mirrors
#103 | |
Member#: 446616
MWSOC
Vehicle:2018 WRX Limited Lapis Blue Pearl |
![]() Quote:
I'm doing some digging into it, stay tuned. Also looking at the possibility of swapping power folding mirrors from the 2020 Ascent. They're the updated mirror design that's more aerodynamic for less wind noise and readily available from US suppliers. AND the parts exist to put the Side View Monitor cam on the passenger side mirror ![]() |
#104 | |
Member#: 50586
BAIC
Vehicle:64 Impala |
![]() Any updates??
#105 | |
Member#: 490151
Vehicle:2018 WRX STI Limited Ice Silver Metallic |
![]() Quote:
![]() ![]() Ascent info is interesting. |
#106 |
Member#: 519370
SCIC
Vehicle:2020 WRX WRB |
![]() So basically for 2017 and newer wrxs that aren't the limited trim, we just need to repin the d84/83 kick panel footwell harness to pins 24 and 25 using the diagram from @ajsti24 and then follow directions from OP to get everything working?
#107 |
Member#: 218339
Tri-State
Vehicle:2017 STI Lapis Blue Pearl |
![]() Quote:
Driver side: -D84 plug remove pin#14(Light green) and tap into pin#25 -D15 plug pin#6(Black), cut and run a new wire and tap into pin#24(Blue with red stripe) on D84 plug Passenger side: -D83 remove pin#14(Light green) and re pin to pin#25(blank spot from factory) -D5 pin#6(Black), cut and run new wire and tap into pin#24 on D83 plug Then the mirrors would be able to fold open and close by pressing the switch on the panel. Hope this sounds correct or hope you can chime in and help out |
#108 | |
Member#: 519370
SCIC
![]() Quote:
#109 |
Member#: 218339
Tri-State
#110 |
Member#: 519370
SCIC
![]() Alrighty got everything working thanks to ajsti24's instructions. One gotcha was to actually cut that ground wire and not tap it! I think that's how I ended up burning the fuse lol. Anyways after replacing the fuse it worked.
Tapping into the D83/84 plug was a major pain and I ended up having to solder it on since there wasn't much room to use a t-tap or positap. You should probably use a 20 awg wire, the fuse is rated to 7.5 amps. Definitely would be nice if anyone figures out which pin these plugs need. The auto folding module is actually extremely simple to install. You just need to take the black wire at pin 1 from the 16 pin plug that goes into the main window switch and the white green wire from the 3 pin plug that also goes to the main window switch and route those two to the empty white 2 pin plug that comes with the module. Take care to follow the instruction manuals when releasing and repinning these; it gets kind of tricky. Then route the black wire back to the 16 pin and the red to the 3 pin. You also need to tap into the red/green-blue wire with the black t-tap they provide. Then everything should work. The review on japanparts with the pictures and ajsti24's post on iwsti really helped. Somehow the main window switch for the passenger side stopped working for me. This might be the fact that I blew the 7.5 amp fuse since I didn't initially cut the ground wire. If anyone experienced anything similar in the past, please help ^^. Last edited by blueberryapple; 11-01-2020 at 10:21 PM. |
#111 |
Member#: 519873
![]() thats awesome
#112 |
Member#: 519370
SCIC
![]() Okay so I figured out why the main window switch wasn't working for the passenger side! I just needed to reset the window switch following this https://m.youtube.com/watch?v=SXfAKIOxLPQ
#113 |
Member#: 218339
Tri-State
![]() Nice, i still haven't gotten to mess with it yet but I'm guessing on the passenger side D5 to D83 plug is not tapping but running a new wire?
#114 | |
Member#: 519370
SCIC
![]() Quote:
https://imgur.com/a/iiHxEdK Last edited by blueberryapple; 11-03-2020 at 10:51 AM. |
#115 |
Member#: 218339
Tri-State
![]() Quote:
#116 |
Member#: 218339
Tri-State
![]() So finally got around and finished the wiring, got everything working as it should. Just need to install the auto folding module and ill be set but really happy that i got it working and with the help from this thread
#117 |
Member#: 345666
SCIC
Vehicle:2019 S209, 22 WRX |
![]() Glad your installs are doin well, feel free to PM me for any questions and will try to help out as much as i can. Cheers!
#118 |
Member#: 519370
SCIC
![]() Are you guys using the jdm wide angle mirrors too?
#119 |
Member#: 218339
Tri-State
![]() Yeah but had installed the prova lens on them
#120 |
Member#: 516834
NESIC
Vehicle:2020 WRX Lapis Blue |
![]() For anyone who's looking to build their own adapter harness, Corsa Technic now has the USDM connectors in stock: https://www.corsa-technic.com/item.php?item_id=1436
#121 | |
Member#: 435783
SCIC
Vehicle:2018 WRX Limited Crystal White Pearl |
![]() Quote:
I really need help knowing what pins go in what socket location. I depinned the JDM 12 pin socket to repin into the USDM 10 pin socket but so far all I can get working is the mirror motor and turn signals...the actual folding and unfolding is still not functioning. Any and all help would be greatly appreciated. |
#122 |
Member#: 399840
Tri-State
Vehicle:2015 6Spd LimitedWRX Crystal White Pearl |
![]() Would anyone happen to have any of the old Imgur photos saved? Nothing is showing up anymore.. I have a 2015 wrx limited. I purchased the SMY Performance power folding mirror kit. The website lead me here but seems like all the photos no longer work.
I have the housing, the auto folding module w/ wiring, and the trim panel w/ the switch. |
#123 | |
Member#: 527264
![]() Quote:
#124 | |
Member#: 435783
SCIC
![]() Quote:
Note: during the de-pinning process, I did crack the housing of the USDM 10 pin connector; so have soldered quick connects for my wires now. Driver Side Car to Mirror Wires Brown w/ white stripe (car) to blue (mirror) Brown w/ blue stripe (car) to pink (mirror) Blue (car) to purple (mirror) Red w/ blue stripe (car) to black (mirror) Black (car) to white (mirror) White w/ red stripe (car) to green (mirror) Passenger Side Car to Mirror Wires Red w/ blue stripe (car) to black (mirror) Black (car) to white/black (mirror) Blue w/ white stripe (car) to purple (mirror) Red w/ white stripe (car) to pink (mirror) |
#125 |
Member#: 518381
![]() Has any 1 made a plug and play harness yet?
