Welcome to the North American Subaru Impreza Owners Club Tuesday January 26, 2021
Old 01-28-2019, 12:18 PM   #51
Kwincy
Member#: 484052
2011 Impreza WRX
5 months in and the headlights have been holding up well here in Kansas. We've had some very cold days, freezing rain days, snowy days, etc., and no issues. I've yet to install HIDs, but I do have some other projects to do that will necessitate the removal of the bumper. Maybe by spring.
Kwincy is offline   Reply With Quote
Old 02-01-2019, 02:01 AM   #52
Pawel062
Member#: 299305
Someone asked on last page.
http://store.ijdmtoy.com/Switchback-...t-p/50-035.htm
This is the sequential strip I used inside mine. It***8217;s a little long so I just hid them behind the shroud where you Can***8217;t see them.
Pawel062 is offline   Reply With Quote
Old 02-27-2019, 08:47 PM   #53
Alpinwolf
Member#: 180279
2008 Imp. WRX Wagon
WR Blue
Zhentlemen,
The Want is strong with this one as well, for these sexy lights. And what I'm running into is that the market vending them is a crapshoot. I see that the OP bought from OEMassive on Ebay, someone else bought from OEMassive.com, another from ProTuningLab.com, and I've also found them at CarID:
https://www.carid.com/spyder/black-s...&url=110693813
They ID the maker as Spyder, but somehow SpyderAuto.com doesn't have this exact model for sale. Wut....
I'm frugal, but I don't mind spending a few extra bucks for good customer service in case something goes wrong, like dusty or scratched lenses or shipping damage. So whether it was about headlights or any other parts, does the community have a recommendation for a source? Or are they all an equal gamble?
Thanks! Y'all's installs look fantastic!
Alpinwolf is offline   Reply With Quote
Old 04-06-2019, 06:15 PM   #54
DMNDNL
Member#: 448338
Originally Posted by Tfivem View Post
I've had these since May, and have been really happy with the overall quality of them. although, I have not experienced the halogen projectors as I retrofit them with bixenon projectors prior to installing them.
I also went ahead and deleted the amber reflectors while I had them open.
How did you do the amber reflector delete? I was looking at these online and wanted to do the same. From what I'm reading too, it seems like any retrofit suited for the OEM 2008-2014 WRX/ STI headlights would work for these headlights as well?
DMNDNL is offline   Reply With Quote
Old 04-07-2019, 02:47 AM   #55
ElectroEvolution
Member#: 389771
2009 Subaru WRX
grey
These headlights are uber sexy. My stock passenger side headlight has melted somehow and I dont really want to replace the whole headlight so switching to these is definitely the way to go for me. However, I am also unsure of which vendor to get them from. So many places sell them and now there are different variations as well. Some have a tinted sidemarker it seems, while others do not. Its all rather confusing tbh. Also like the post above mine, do any of you know FOR A FACT that the normal 08-14 retrofit/retroquick retrofits will work with these headlights? And also what do you suggest? Iv spent the last month research and the more I research, the more my brain is scrambled. Please dont let this thread die! Cheeeeeers.
ElectroEvolution is offline   Reply With Quote
Old 04-10-2019, 03:51 AM   #56
ElectroEvolution
Member#: 389771
2009 Subaru WRX
grey
Oemassive is down to $275. The question is, do I go with the HID type instead (for STI ONLY) or do I go for the halogen type? Obviously I would need a harness that would make the HID type work with my wrx however, they dont offer that nessecary harness. Does anyone have any idea where to get a compatible harness? Getting the STI version of these C lights would make future light options much, much easier as I woukdnt have to retrofit anything. Just stick in any good compatible HID kit and hit the road.
Old 04-14-2019, 12:48 AM   #57
ElectroEvolution
Member#: 389771
2009 Subaru WRX
grey
Anyone? Haallppp
Old 04-16-2019, 10:43 AM   #58
cknowlen
Member#: 189077
2011 STI limited
Originally Posted by ElectroEvolution View Post
Anyone? Haallppp
This should be a pretty simple answer, as it says right on the advert for the housings. If your car came stock with HID then order that housing, if it did not, order the halogen housing.
Could you install the HID one on your car just the same if it came with halogen from the factory? yes. Are you going to have to either do custom wiring or buy an H11 (factory low beam) to whichever size the HID ballast accepts for a power input connection? possibly, simple either way though.
If you are planning on upgrading to HID, then buy that housing knowing you will have to do some extra wiring, it wont be difficult. The advertisements I have seen for these housings seem to all say they don't come with the HID lowbeam kit, so you would have to source that yourself anyways (don't buy ebay or el cheapo amazon please).
cknowlen is offline   Reply With Quote
Old 04-16-2019, 02:18 PM   #59
nekidfrog
Member#: 489917
2012 WRX Hatchback
Pearl White
So I bought these not to long ago... first things first... these are not DRL! they do not come with a relay to make the c shaped light be the DRL.
https://www.protuninglab.com/pro-jh-si08-lbdrl-c.html <-- I bought these specifically because I have a WRX without HID's. The problem is the halogen bulb that comes with these? ARE NOT H11 but instead are replaced with H7's which is entirely weird why they would change the bulb type from the stock bulb to a lower standard bulb socket? So the nice expensive Diode Dynamic LED bulbs that I have are now useless for these headlights.
Again the C-Shape is NOT a real DRL and does not come with relay's to become a DRL so that's completely false advertisment.
I wanted the blacked out version but they were out of stock so I ordered the Chrome version with the intent to black them out myself. The projector itself is not a chromed smooth finish and instead is a almost sandblasted chrome color?
Both C-Shaped LED lights are dim... as in not that bright at all. The driver side is dimmer than the passenger side, at least on the ones I received are. I'm a bit mad that they are advertising these as DRL but clearly are not DRL and anyone arguing with them about DRL is told to just return them and get a refund.
nekidfrog is offline   Reply With Quote
Old 04-20-2019, 09:30 PM   #60
subieguy2012
Member#: 500617
2012 WRX Hatch
Dark Metallic Grey
So i have a 2012 wrx hatch with the sti hid headlights. Im looking to get LEDs bulbs in the current setup i have now or get these c shape LED lights with maintaining the DRL but done want to buy them if i cant do LEDs. Could anyone help me out with this problem?
subieguy2012 is offline   Reply With Quote
Old 04-22-2019, 02:39 PM   #61
nekidfrog
Member#: 489917
2012 WRX Hatchback
Pearl White
only the c-shaped light bare is LED. The bulbs they come with are halogen unless you buy the HID version. Unless you want the c-shaped bar, just go with LED bulbs in your current setup. Or buy these and make your own relay to make the c-shape bar be a DRL.
Old 04-22-2019, 06:56 PM   #62
ElectroEvolution
Member#: 389771
2009 Subaru WRX
grey
Quite literally what I said lol. Hence why I was asking about a compatible harness to make the HID's work. Anyway, for anyone else planning on buying these, do not buy them. They do not come with the DRl relay to make them work. as just as the guy above me, one side was dimmer than the other. I returned mine for a refund. Im going to stick with the oem housing and try to go with a quad retrofit/halos. its really unfortunate that spyderco is wrongfully advertising.
Old 04-23-2019, 09:35 AM   #63
JDMSTA
Member#: 310615
1213 12'Sport+13'STi
I believed these headlights are only good if you are planning to just retrofitting better HID or LED projectors and better LED "C" lights in them. Otherwise they are useless. LOL!
JDMSTA is offline   Reply With Quote
Old 04-24-2019, 09:27 PM   #64
AnthonyF24
Member#: 482700
2013 STi Hatch
I've been looking into doing my headlights and I want to keep MY OEM ones and found these C lights. After massive amount of research, these headlights are best if you plan on gutting them with proper equipment. Buy a set and build them yourself with a proper projector and real LED'S behind the c light. Or check out circuit demon or ghoztlighting on IG.
AnthonyF24 is offline   Reply With Quote
Old 08-01-2019, 12:32 AM   #65
jsantos1082
Member#: 369254
2013 WRX
Sorry guys, I have the halogen version. What is the size of the low beam bulb and the drl?
jsantos1082 is offline   Reply With Quote
Old 08-01-2019, 01:15 AM   #66
Lemonrod
Member#: 504808
2013 Impreza WRX
Originally Posted by Kwincy View Post
The want is strong with these, but I'm wondering if anyone has bought and installed these yet:
http://oemassive.com/c-style-08-14-s...ck-headlights/
$420 doesn't seem too bad, but I'd like to know if the quality is there before I pull the trigger. I think Akkon via Amazon.com sells them too.
I managed to find some spyder c style headlights on ebay for $185.
Lemonrod is offline   Reply With Quote
Old 09-20-2019, 12:27 PM   #67
Lindy19
Member#: 504761
$200 shipping to Canada
Lindy19 is offline   Reply With Quote
Old 09-21-2019, 11:17 PM   #68
Giant-KiLLer
Member#: 505419
Originally Posted by mugen_ View Post
OEMassive has another set or you found another set on eBay? I'll keep a look out for a sale though.
If you're able to I'd love to see pics of light output and beam spread. Like a pic on a dark road, and another in front of a wall. Still considering if I'll want to split them or just upgrade bulbs.
Have you looked into the spec-D headlights yet? They have a few different options depending on if you want smoked on smoked or clear with smoked or clear with chrome. Just something to look into.... my bad, this was supposed to be in reference to the price being a little much at $420 because the spec-D’s are only $330 and that’s not even on eBay but a parts dealer online like rallysportdirect or carid
Giant-KiLLer is offline   Reply With Quote
Old 09-22-2019, 12:11 AM   #69
Shwammm
Member#: 506641
Lightbulb Just trying to get some feedback from the 15+ owners
I’ve designed and currently have a prototype for a c-light replacement. It uses RGBW led strips that are addressable and an open source MCU so you can program it to do whatever you want. For example, top portion stays white( btw since it’s an RGBW strip it’s Uses actual white leds not red/green/blue together to make white) and the lower blinks amber for turning or literally whatever you want it to do. Working on adapting it to all lights but one thing at a time. Did one set for my 16 wed and I’ve been getting lots of interest so I’m curious...what would you pay for something like this if it were on the market. Gonna be honest the only thing I’d be selling that is my own design is a light diffusing resin c-light with embedded led. If you know how to code in c/arduino you could program your own but I’m thinking a lot with programmed unit and r/l lights. I’ve seen Bluetooth units out there for a pretty penny but you only get one color at a time. Keep in mind this is a prototype and with some good feedback/contribution it will be constantly evolving but I currently think it’s better than anything out right now( I may be a bit biased). So basically given it’s current stage in dev would you be willing to pay for it and if so how much. Videos will be loaded soon btw once it’s actually installed, only crude prototype board wiring at the moment. Thanks all ***9996;***127995;
Shwammm is offline   Reply With Quote
Old 10-29-2019, 09:35 PM   #70
Siress
Member#: 347295
2013 WRX 5DR
To anyone else reading this thread, do NOT deal with ProTuning Labs for these headlights or any other product. That is the worst online experience I've ever had with any entity that presumably holds a business license. I'll report back when the dust settles, but suffice to say that they do not deal in quality products, and aggressively try to fool people into being stuck with them.
Siress is offline   Reply With Quote
Old 12-24-2020, 07:55 PM   #71
SubieLou
Member#: 511364
2013 Wrx
Hey guys reviving a dead thread, but this is relevant to my current project. I am retrofitting these OEMassive headlights with new projectors, demon eyes, and a RGB LED strip from Circuit Demon for the C-light. I have both demon eyes and both c-lights hooked up to a Moriomoto XBT bluetooth controller, and the question I have is:
What is a good source of switched power in the engine bay? I want to set it up so I can turn them on with the parking light switch on the stalk, so can I just tap into a 12V wire right at the turn signal harness?
SubieLou is offline   Reply With Quote
Old 01-12-2021, 02:20 PM   #72
amiexploited
Member#: 251061
18 Trek 6mt,
garage queen 15 WRX 6mt
If you want them to turn on with the parking light you can safely splice them to the parking light on the headlight. I don't remember if the parking light acts as a turn signal so test the wire before you splice. I would tap it with a solder connection not a t tap or a vampire crimp.
If anyone wanted to run the C Light (even though they are not bright in stock form) you can just tap in to the DRL resistor behind the bumper). The website even says the LED Strip requires additional wiring. Not unheard of in the aftermarket headlight world. Good luck.
amiexploited is online now   Reply With Quote
Old 01-13-2021, 09:51 PM   #73
SubieLou
Member#: 511364
2013 Wrx
Thanks for the reply. Yeah that was my first thought but I gutted all the lights out and put in RGBWs from Circuit Demon, they are pretty bright!
