#151 |
Member Status: Member
Member#: 46241
SWIC
Vehicle:- Can I get a wayo |
![]() Aluminum has it's properties.
Looks pretty good to me...
#152 | |
Member#: 48377
MWSOC
Vehicle:1996 Gutted, built XP class Impreza L |
![]() Quote:
#153 | |
Member#: 48377
MWSOC
![]() Quote:
#154 |
Member#: 80649
South East
Vehicle:2000 2.5 Auto-X RSTi Sparkly |
![]() I tend to stitch the piece in alternating sections. Basically divide the piece into quarters and weld each one alternating with the one furthest away to keep the heat in the part even.
The other trick is having the part bolted to something or mated to another surface so it can't warp while welding. This is key for exhaust welding as the flanges are the first to warp. |
#155 |
Member#: 190502
International
![]() I finished the welding last night, it took a long time because I was letting it cool off a fair bit and only welding about 1" at a time.
I could not be happier with how good it came out, its not warped at all which is not surprising as I never let it get very hot. I'll post a bunch of photos showing the full process once its painted but here is a sneak peak. I still need to weld a bung into it as a breather to the dry sump tank. ![]() |
#156 |
Member#: 338863
Vehicle:PSM 05 WRX WGN 5MT 95 Caprice 6spd Track Rat |
![]() Nice work!
#157 |
Member#: 369411
International
Vehicle:2002 WRX STi Limited Silver |
![]() Looking good. Can't wait to see the finished product.
#158 |
Member#: 190502
International
![]() ok it's finally finished! I'm super happy with how good it came out, looks like a bought one.
#159 |
Member#: 159474
NESIC
Vehicle:2017 Impreza Sport Lithium Red - OLDKID |
![]() That's perfect!
#160 |
Member#: 190502
International
![]() My transmission adapter and clutch kit arrived yesterday from PMC Motorsport. Everything looks good except they didn't include a clutch release bearing, not a big deal I should be able to get one locally.
https://i.imgur.com/a9JEJJy.jpg?1 I don't have an engine crane at the moment so I had fun lifting the engine onto a dolly so I could slide it out and test fit the adapter. https://i.imgur.com/oKr5QmB.jpg?1 Now I just need to figure out how I am going to mount the engine permanently in the car. The lowest point of the engine trans combo is actually the front of the trans, it hangs lower than the stock oil pan. We are currently in the middle of a heatwave so work might be a little slow going but big things are finally happening. |
#161 |
Member#: 190502
International
![]() I have started working on getting the engine mounted in the car, first step was to make a basic low profile dolly long enough to carry the engine and trans mounted together.
https://i.imgur.com/ifPW9kn.jpg?1 It cost me about $30 in material, the castors are cast iron so they can easily take they weight, it works really nice. https://i.imgur.com/7pCx8Xc.jpg?2 I tried to slide the engine into position but the reinforcement in the tunnel stopped it going as far back as allowed under the rules. https://i.imgur.com/FHcceva.jpg?1 Removing the reinforcement was not fun at all, especially during the heatwave that just ended today. 2.16kg in total. https://i.imgur.com/yyUdYOX.jpg?1 All gone! https://i.imgur.com/AJ24KVF.jpg?1 The engine could now slide back as far as I needed with some room to spare. I also took opportunity while the car was up in the air to lower the rear differential so I would have a better alignment and lower COG. https://i.imgur.com/pP57KFU.jpg?1 These next 2 photos show the engine basically 99% in its final position. I have ordered a laser pointer to get it in the exact position. You can see it sits reasonably low and a fair way back. https://i.imgur.com/IrgUw6Z.jpg?1 https://i.imgur.com/yoqmZBe.jpg?1 Next step is to figure out engine mounts, steering rack mounts and basically triangulating everything together. |
#162 |
Member#: 338863
![]() Tucked way back! Not bad!
Did you have a goal date for completion/competition? Sorry if I missed it earlier in the thread. |
#163 |
Member#: 190502
International
![]() Not really, I'm 4 years in already so the project is already the same age as my youngest son. I just work on the car when I find the time and I don't want any deadline as it just becomes a chore not something to enjoy.
#164 | |
Member#: 338863
![]() Quote:
#165 |
Member#: 190502
International
![]() I spent some time on the weekend installing everything into the rear end. All control arms, drive shafts and the new 5x114.3 wheel bearings.
https://i.imgur.com/KMCZwWm.jpg?1 https://i.imgur.com/Rsm0Wi3.jpg?1 https://i.imgur.com/P2PaOgy.jpg?1 My laser pointer arrived today so I should be able to line the engine up correctly with the rear differential and then look into making some mounts. |
#166 |
Member#: 149890
NESIC
Vehicle:09 Forester Green |
![]() awesome work, looks great. Excited to see more progress on your project.
#167 |
Member#: 190502
International
![]() I've been going back and forth with the design of the front end for the past 2 weeks. I am now confident with what I have come up with so work has begun.
I was trying to design a way of mounting the engine that is strong enough but not over done and heavy. It's not just the engine but the whole front end needs triangulation that ties back into the roll cage because I have removed so much metal. Speaking of removing metal, the front came off yesterday https://i.imgur.com/dE9Zkq5.jpg?1 https://i.imgur.com/0nzXDcz.jpg?1 I am not 100% sure how I am going to cap off the frame rails yet so I had to use a hole saw to cut the lower part out so I could mount the steering rack at the correct height. https://i.imgur.com/mfA5A8a.jpg?1 I've ordered some polyurethane bushings for mounting the engine and gearbox, they are not very large so should be very stiff but take the edge off the vibrations. I did think about solid mounting it all but I don't really want everything vibrating undone all the time and this way I still have the option of replacing the poly with nylon if I decide I want it solid at a later date. |
#168 |
Member#: 190502
International
![]() I haven't updated this thread for a while but lots of things have been happening.
I have got my poly mounts for the engine and the gearbox, I'll post some photos when I have mounted the engine. I bought myself an engine crane and engine stand to make my life easier. I needed to flip the engine over and modify the sump so there would be space for the main crossmember. https://i.imgur.com/o8NhwWk.jpg?1 I have placed an order for an AT Power belt driven dry sump kit but I did not order the billet oil pan with it to try and save some money. Due to Covid it will take 8 weeks to arrive. Not to worry I just need to make an oil pan and then I can continue getting the engine and transmission mounted in the car. Version 1 of the dry sump oil pan involved cutting the base off the OEM pan and then a lot of CAD to form the desired shape. https://i.imgur.com/FAg02NU.jpg?1 https://i.imgur.com/Gc3Vu8U.jpg?1 I went as far as tracing all the cardboard templates onto some sheet metal and then cutting them all out and bending them to shape. https://i.imgur.com/KaK27zV.jpg?1 It was then I realised I was never going to be able to beat the metal into shape well enough to close up all the gaps and weld it together. So I went back to the drawing board and came up with a very simplified design that was much easier to cut out and will be relatively simple to weld. https://i.imgur.com/nmcN7wx.jpg?1 The engine is on a 13 degree tilt so oil will run down to the box section in the bottom of the pan where I will have two -12 lines running to the external oil pump. I have also added a notch that will give extra clearance for my tubular crossmember and to some degree separate the scavenge stages from each other. https://i.imgur.com/g3qTsdL.jpg?1 https://i.imgur.com/WRCZnq7.jpg?1 It's all ready to weld, I'm just waiting for the -12 AN weld on fitting to arrive. |
#169 |
Member#: 48377
MWSOC
![]() This is awesome to read. With that statement you have become awesome in my book!
#170 |
Member#: 190502
International
![]() I got some more work done on the weekend, I've welded up most of the dry sump pan now, its not finished because I'm still waiting for the weld on -12 bungs but good enough for me to continue working towards getting the engine mounted in the chassis.
https://i.imgur.com/wx0Hi3f.jpg?1 You can see the motor is looking much less tall now. https://i.imgur.com/GvZlGp2.jpg?1 The lowest point on the engine is now the adapter plate so I have gone to the extra trouble of shaving that down a little for maximum engine lowering. https://i.imgur.com/TMuazQ2.jpg?1 I have freed up a little extra space in the engine bay by removing these corner brackets. The tube I will be adding to triangulate everything back to the roll cage will be more than enough. https://i.imgur.com/eMsf12c.jpg?2 Lots of space now https://i.imgur.com/V03b16V.jpg?1 With the modified sump pan the engine was no longer stable on my home made dolly so I had to make this little bracket to stop it toppling over. You can also see the start of what will become the engine mounts. https://i.imgur.com/nDPTEXW.jpg?1 So with the engine moved back into position this is the final height it will sit at, I can't go any lower than this. https://i.imgur.com/BaVI2Cp.jpg?2 I started making the front cross-member last night so hopefully soon the engine will be in. |
#171 |
Member#: 190502
International
![]() I have been working on the front cross-member this week.
Starting off with a single tube that joins the existing lower control arm mounts. This tube needed to drop down to a specific height and it was incredibly difficult to make but turned out perfect. https://i.imgur.com/ZYU25Yu.jpg?1 There will be a second tube coming from further back which picks up some existing chassis mounts. I made these sections for joining that tube to the chassis. https://i.imgur.com/excDzjn.jpg?1 https://i.imgur.com/PtWByFX.jpg?1 I then decided to fabricate my shock mounts as they are sharing the same space as the first cross tube and their position can't be moved. https://i.imgur.com/nuud4zm.jpg?1 They are just tacked in place for now. I will box them in a bit for added strength at a later date. https://i.imgur.com/FWFQ82G.jpg?1 I decided to test fit the shocks too https://i.imgur.com/ymd5IQJ.jpg?1 Looks pretty cool with the inboard suspension I've tacked the first cross tube in place too to make sure it doesn't move around whilst I'm making up the rest of the tubes. https://i.imgur.com/LKdrONy.jpg?1 |
#172 |
Member#: 190502
International
![]() Mega update time!
I have been very busy working on the car. First off, the dry sump pan is all done. Since my last post I added all the weld-on bungs required. 2 scavenge stage bungs which accept a -12 AN fitting with mesh filter screen and the -10 AN turbo drain. https://i.imgur.com/VWHcSwK.jpg?1 https://i.imgur.com/9yNmjHy.jpg?1 https://i.imgur.com/yt85Qd6.jpg?1 turbo oil drain https://i.imgur.com/7Kv5W2g.jpg?1 These are actually M4 Rivnuts that I flash tacked on with the Tig. I needed something to hold down the small windage tray I made. https://i.imgur.com/13Q9mnt.jpg?1 This is the finished pan, it has been painted with engine enamel which has been baked in the oven for an hour. https://i.imgur.com/qUIiN7V.jpg?1 https://i.imgur.com/I4Z5YQF.jpg?1 https://i.imgur.com/uNZeZr0.jpg?2 I'm very happy with how good it turned out and it cost me very little money to make. |
#173 |
Member#: 190502
International
![]() Next up was the continued work on the front crossmember.
I notched out a bunch of tubes and tack welded them in place on the car before removing it so I could weld it all together with the comfort of my work bench. To do this without everything moving I had to build a jig. https://i.imgur.com/CUe9iaV.jpg It came together quickly with the hot glue gun (Mig) https://i.imgur.com/45SDLas.jpg?1 https://i.imgur.com/FfbjHcf.jpg?1 Before welding the crossmember together I had to finish of the shock mounts. I had to fully weld them to the tube and then add some gussets using CAD. https://i.imgur.com/GsxQsIl.jpg?1 https://i.imgur.com/Z0eKC7T.jpg?1 The gusset also joins them to the main cross-tube to stiffen the mounts up some more https://i.imgur.com/f2cV25M.jpg?1 and then it was just a whole lot of welding https://i.imgur.com/fk2aabq.jpg?1 https://i.imgur.com/SVZqe5q.jpg?1 one of my better welds https://i.imgur.com/uzMqqQf.jpg?1 and here it is all done on the car https://i.imgur.com/3XOYIIK.jpg?1 With that finished I have something to build my engine mounts onto. Next job will be putting the engine into its final position and building the mounts. |
#174 |
Member#: 149890
NESIC
![]() Looking good JD. That is a nice hurdle to be over. The motor mounts should be simple. Can't wait to see the progress
#175 |
Member#: 33782
MAIC
Vehicle:96 3MI Racing search FIRST, then PM!!! |
![]() It's been a hot minute and don't recall off-hand; isn't this going to be a K-series powerplant?
Seeing early potential from the FA24, any plan to go back to boxer or settled on the K-series? |
