#1 |
Member#: 515256
Vehicle:2006 WRX Black |
![]() Hey guys,
I figured I would start a build thread. It's been awhile since i've used the forums. So here we go! I started a youtube channel to document my car builds. I'm a total noob at filming and editing, but I'm giving it a try. Let me know what you guys think. Thanks! @lrb.wrxsti https://www.youtube.com/channel/UCuG...KOBbZa89ZpH3CA My current video! ![]()
#2 |
Member#: 515256
![]() Picked up my block and a bunch of parts today for my STI!
![]() ![]() ![]() Last edited by lbrown39615; 01-17-2021 at 03:09 AM. |
#3 |
Member#: 515256
![]() I bought my 2006 WRX in April of 2020. Pretty much bone stock. Someone put the sti wing, and side skirts on it also some 04 tail lights. Besides that, stock. I did all the maintenance I could think of when I bought it. It's my daily driver, so I needed it running good. And it's treated me pretty good the past 10,000 miles.
Since then i've added quite a few parts, such as; Engine/Trans **3" Megan Racing Downpipe **3" COBB SS Exhaust **GrimmSpeed Exhaust Adapter **XPT Tuning Stage 2 Tune @18psi **LUK Stock Clutch Kit **STI Top Mount Intercooler **Air Oil Seperator **Walbro 255LPH Fuel Pump **Tomei Turbo Inlet Tube **Torque Solutions TGV Deletes **STI Transmission Mount **STI Pitch Mount **Whiteline Shifter Bushings **New Radiator **OEM Timing Belt Kit **OEM Water Pump/Thermastat **Front and Rear Brake Pads/Rotors **Secondary AIR Removal **OEM Ignition Coils **NGK Iridium IX Spark Plugs **OEM Fuel Filter **K&N Air Filter **Castrol Edge Synthetic Oil 5w30 **OEM Oil Filter **OEM 02 Sensors (front/rear) **Engine Splash Guard Suspension **KYB Excel-G Shocks/Struts **Eibach Pro-Kit Springs **New Shock/Strut Mounts **F/R Sway Bar Endlinks/Bushings Exterior **18x8.5" AVID AV20 Wheels **225/40/18 Tires **OEM WRX Floor Mats **Fog Light Covers **Painted Front Bumper **Front Bumper Lip **Rear Driver Door **Driver/Passenger Fender Liners **Rally Sport Mud Flaps Interior **Tactrix 2.0 **Kartboy Short Shifter **Killer B Shift Knob **Cabin Air Filter **ProSport EVO Water Temp Gauge **ProSport EVO Oil Pressure Gauge **ProSport Electronic Boost Gauge **AEM UEGO Wideband Gauge **AutoMeter Triple Pillar Pod **Alpine Media Deck **Hertz 5.25" Front speakers **Alpine 4" Rear speakers Here's a bunch of pictures of how things progressed with the car until now. Last edited by lbrown39615; 01-16-2021 at 09:25 PM. |
#4 |
Member#: 515256
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by lbrown39615; 01-18-2021 at 12:55 AM. |
#5 |
Member#: 515256
![]() I bought my 2004 STI about 2 months ago. Half of the parts came with the car. The engine was not in the car and had to be rebuilt. I will be assembling the new engine in the next few weeks. Here's the mostly complete list of parts I have for the car.
Engine/Trans **Built Block **JE Pistons **Manley Rods **King Main/Rod Bearings **ARP Head Studs **Rebuilt Stock Heads **OEM Gasket Kit **OEM Timing Belt Kit **Killer B Oil Pickup + Baffle **New 11mm Oil Pump **New Water Pump **Oil Cooler Delete **OMNI 4 Bar MAP Sensor **AEM IAT Sensor **AEM 340LPH Fuel Pump **FP Green Turbo **950cc Sidefeed Injectors **Turbo XS Uppipe W/ EWG **GrimmSpeed 3 Port EBCS **44mm Tial EWG **3" Custom Downpipe **3" HKS Carbon-Ti Cat Back Exhaust **Custom Intake w/ AEM Filter **Perrin Turbo Inlet **Turbo XS FMIC Kit **Turbo XS BOV **TGV Deletes **GrimmSpeed 8mm Phenolic Spacers **NGK Iridium IX Spark Plugs **GrimmSpeed Exhaust Gasket Kit **Custom Coolant Overflow Tank **Crawford V2 AOS **Group N Motor/Trans Mounts **Whiteline Shifter Bushings **6 Puck Clutch **OEM Flywheel Suspension **BC Racing Coilover **Kartboy F/R Swaybar Endlinks **New Swaybar Bushings **Eibach Rear Camber Bolts **Cusco Strut Tower Bar Interior **Cobb V3 Accessport **AEM Uego Wideband Gauge **AEM Boost Gauge **Prosport Oil Pressure Gauge **Dual Cluster Gauge Pod **Kenwood DVD **HKS Turbo Timer Last edited by lbrown39615; 03-28-2021 at 03:00 PM. |
#6 |
Member#: 515256
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I Have my winter wheels on the WRX, so I put these on my STI. ![]() Last edited by lbrown39615; 01-18-2021 at 12:57 AM. |
#7 |
Member#: 515256
![]() I started assembly on my EJ today!
#8 |
Member#: 515256
#9 | |
Member#: 497893
Tri-State
Vehicle:2011 Sti Hatch New color coming soon. |
![]() Quote:
#10 |
Member#: 515256
#11 |
Member#: 521349
South East
Vehicle:2005 STI Aspen White |
![]() Sweet cars and I like your shop area. Hello to a fellow Washingtonian although I haven't lived there for 6 years now.
#12 |
Member#: 515256
#13 |
Member#: 515256
![]() I got a lot done today. I just need to put the clutch and flywheel on tomorrow and it can go back in the car!
#14 |
Member#: 515256
![]() Here's the next video in my build! Almost have the whole engine assembled.
....and a couple of the WRX for fun. ![]() ![]() ![]() |
#15 |
Member#: 515256
#16 |
Member#: 515256
#17 |
Member#: 515256
![]() Here's my newest video.
I ended up having an issue with my engine timing, so I had to order some adjustable idler pulleys to get the timing back in order. |
#18 |
Member#: 515256
![]() I got the IAG adjustable idler pulleys installed and my timing issue should be fixed now! Pretty happy about it. Check it out!
#19 |
Member#: 515256
![]() I needed to get the STI tuned, so I braved the cold weather and snow. Haha. Here's my newest video.
#20 |
Member#: 515256
![]() I got a short video from outside the car. I think it sounds pretty sweet!
#21 |
Member#: 519102
Vehicle:2005 OBXT |
![]() From the picture of your timing belt, your lower idler pulley is missing. I hope that got installed or maybe it was related to your timing problem.
#22 | |
Member#: 515256
![]() Quote:
That was just a picture I took while assembling the engine. I still don't know why the timing is off 10*. We were able to compensate in the tune by taking 10* off the entire map. Even the tune on the previous engine had to compensate in the tune. It's weird. |
#23 |
Member#: 150034
SCIC
Vehicle:2007 WRX & STI SWP & Aspen White |
![]() Wow I want black carpet after seeing your one photo from post #6.
#24 |
Member#: 515256
#25 |
Member#: 516724
![]() Love those rims!
