Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Old 04-07-2021, 05:44 PM   #1
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Default Anybody use vf48 "hi flow"?
Hey all, I'm curious who all has used the ihi vf48 hi flow turbo?
Currently have vf39 and dark blue sti injectors (and all other supporting mods) on my 05 Wrx ej205, but i started seeing blue smoke out the exhaust and suspect the ooolld vf39 is on its way out.
I was thinking about just picking up a used vf48, then decided I might as well buy new in hopes of it lasting longer. Then noticed ihi offers the hi flow vf48.
Anyone have experience with both vf48 and vf48 hi flow?
Will my current dark blue injectors and walbro 255 be enough?
I just want to swap turbo and re-tune.
Not looking to re-replace injectors or fuel pump.
I'd really like to hear from anyone that has used it. Especially if you've used both vf48s.
4eat05 is offline   Reply With Quote
Old 04-07-2021, 10:38 PM   #2
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Midnight Black Pearl
After I heard about the HF version of the VF48 I became curious about it and other high performance VF variants available in 2021 and after speaking with my tuner about it and learning about IHI's US branch, if I were to spend money on a new OEM turbo, id get a VF34 from IHI's US sales department, Clover Turbo. The VF34 flows similarly to the VF48 but is ball bearing so it spools a good bit faster. The difference in peak power between the VF34 and VF48HF should be minimal and more than made up for by the decreased spool time in the VF34.
Walrbo 255 pump will be fine and STI injectors should be enough but personally I'd go larger like 1050Xs to allow you to run flex fuel if you so choose and avoid running out of fuel at high rpm.
https://turboturbos.com/products/vf34
I think Clover turbo just changed their name in the US to IHI FWIW.
K3rm1tth3fr0g is offline   Reply With Quote
Old 04-07-2021, 10:43 PM   #3
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Do you happen to have a link to brand new vf34?
Not really interested in changing injectors again any time soon
Old 04-07-2021, 10:52 PM   #4
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
yup it was in the post hiding in the middle
Old 04-08-2021, 12:22 AM   #5
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Had a VF34 on my last 205. Great turbo for that engine. Had dark blue STi injectors. Did max them out before we reached full potential from the turbo, but there wasn't much left. I had AVCS on that engine, but my power band was 3100-6200 rpm. Without AVCS you'll reach full boost a few hundred later
snow_bound26 is offline   Reply With Quote
Old 04-08-2021, 06:16 AM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Go search on IWSTI. There is a thread in there with dyno plots. The cliff notes are same spool as VF48, but more power.
Old 04-08-2021, 07:27 AM   #7
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Is that brand new?
I clicked on that link but assumed it was rebuilt/remanned since it had that green tag on it
Old 04-08-2021, 08:05 AM   #8
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Originally Posted by 4eat05 View Post
Is that brand new?
Its brand new. I asked my tuner that exact question because I was curious of the same thing. But Clover Turbo is just IHI's name in the US.
Old 04-08-2021, 09:42 AM   #9
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
And you would pick vf34 over vf48 hi flow for a non avcs usdm ej205?
I should be able to use my current sti 565cc injectors and walbro 255?
I always thought the consensus was vf39/43/48 was better for the 2.0 because the exhaust housing was smaller? (P17 vs p18?)
Did I read wrong?
Old 04-08-2021, 09:45 AM   #10
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Did I read wrong?
Its mostly personal choice, the VF48 HF will make a bit more power up top but spool a few hundred RPM later than the VF34.
The STI injectors, Walbro pump + a good tune will do you just fine.
For non AVCS 2.0s I'd definitely go ball bearing.
Old 04-08-2021, 11:34 AM   #11
T-37
Member#: 175624
0304 WRX WRX
SY WRB
IMO, especially with the 4EAT, I would look for more top end and raise the WOT shift points to near redline and not worry about a few hundred rpm spool. The VF34 powerband mentioned above (3100-6200) sounds like what you'd expect from a normal VF. Great midrange, but falls off up top. With the HF it should carry that a little closer to the 7k redline. I think you'd see more improvement keeping the gains higher in the rev range with the 2L. I'd lean towards the VF48HF, you'll likely be able to have it tuned with the current injectors, but I'd feel better with lower IDCs with 650-850's.
Ball bearing helps with transient response (off/on throttle when RPMs are above boost threshold.) Spool is down to wheel sizing and A/R. With the 4EAT you're not lifting to shift, so the transient response doesn't matter as much.
T-37 is online now   Reply With Quote
Old 04-08-2021, 11:40 AM   #12
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
I wouldnt want to run a VF48 HF with stock STI injectors personally, and he noted he wants to keep current injectors. The gains up top you'd see with the VF48HF would probably need larger injectors to capitalize on in a meaningful way anyway. Sticking with the STI injectors, I'd still prefer a VF34 if its going on a 205 w/o AVCS.
Old 04-08-2021, 02:10 PM   #13
chrisd87
Member#: 344446
2012 00 GC8, 02 S202
I ordered the VF34 for my EJ207 last week from Turboturbos. Took 2 days to arrive!
I would get right to the point with the VF34. The response is fantastic and peak power is great.
chrisd87 is offline   Reply With Quote
Old 04-08-2021, 02:17 PM   #14
snow_bound26
Member#: 395793
2005 92x Aero
Beige
With a larger injector like a 650 or 850, I bet the 34 and 48HF would flow very close up top. I was limited with the STi injectors which we topped out at 95% just to leave them with a little buffer. As mentioned, with the 4EAT the transient response isn't that much of a benefit. Personally, I'd go for which ever one fit the budget. But then again for the price of a new IHI turbo, I'd go 16g and definitely have that top end that the VFs don't do as well. Which a 16g even on STi injectors should still out perform a 34/39/48. There will just be room to grow once the OP wants new injectors.
Old 04-08-2021, 02:36 PM   #15
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
I run 850cc injectors with a vf48 on an ej207, no need to push beyond 7000 rpm. Pink injectors were maxed out on top end, best to play it safe and upsize the injectors. The vf48 I have is not a high flow, it just has the SoCal porting treatment.
Old 04-08-2021, 03:13 PM   #16
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
imo 16G would def be a better option if he was up-sizing injectors and doesn't care if it's OEM or not.
One other thing to note when comparing a 16g in this situation is pricing.
A standard jb BPT 16g is around 1k, same price as a new VF34 from IHI in 2021. But the VF34 is ball bearing. To get a ball bearing 16g you're spending upwards of $1500. Just worth mentioning.
Old 04-09-2021, 03:27 AM   #17
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
A standard jb BPT 16g is around 1k, same price as a new vf43 from IHI in 2021. But the Vf43 is ball bearing. To get a ball bearing 16g you're spending upwards of $1500. Just worth mentioning.
Vf34 is a ball bearing turbo, vf43 is a journal bearing turbo.
Old 04-09-2021, 10:19 AM   #18
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Typo. Thanks for pointing that out.
VF34
Old 04-09-2021, 10:28 AM   #19
Craig4g63
Member#: 217175
has anyone done a billet wheel upgrade on their vf34?
What were the results on spool, response, and top end if you have?
such as. https://turboturbos.com/products/mfs...d58bc27c&_ss=r
Also please note if it is a 6+6, 11 blade, etc.
Craig4g63 is online now   Reply With Quote
Old 04-09-2021, 04:09 PM   #20
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Had a 6x6 billet wheel on mine. Didn't use the turbo with the OEM wheel so I can't compare. I ran out of top end because I didn't have enough injector to keep it going, but I was fairly close to maxing out the turbo. My power band went to 6200. Probably could've pushed it to 6500-6600 with larger injectors.
