Welcome to the North American Subaru Impreza Owners Club Saturday October 16, 2021
View Poll Results: What is the state of your EJ255?
Spun Rod/Blown/Damaged 5 21.74%
Still running or sold under 120,000 miles 6 26.09%
Still running or sold over 120,000 miles 12 52.17%
Voters: 23. You may not vote on this poll
Old 09-07-2021, 02:08 PM   #1
jeffambo
Member#: 507933
2013 WRX Base Hatch
Obsidian Black Pearl
Default EJ255 Owners or Past Owners, what is the state of your engine?
Trying to see how many blown vs non-blown
jeffambo is offline   Reply With Quote
Old 09-07-2021, 11:37 PM   #2
shadowsports
Member#: 446364
'17 STI LMT '08 LGT
DGM / QSM
Why 2 threads
shadowsports is offline   Reply With Quote
Old 09-08-2021, 09:07 AM   #3
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Why this thread all together? It is a useless thread and even a more usless question. Peoples answers will give you nothing. Some one can drive a blow up a eng in the first 5k miles. Then another person a 60 y/o grandma can drive a STi and it can last for 150k miles.
BlackFighter is offline   Reply With Quote
Old 09-08-2021, 10:16 AM   #4
jeffambo
Member#: 507933
2013 WRX Base Hatch
Originally Posted by shadowsports View Post
Why 2 threads
mistake i guess
Old 09-08-2021, 10:21 AM   #5
Karlot
Member#: 339923
2006 Impreza WRX STi
grey
BLEW up the ringlands on cyl 4 at 90210 miles. got an iag block running strong at 140k ish miles now (50k ish on the iag motor). and i do beat on the iag block.
Karlot is offline   Reply With Quote
Old 09-08-2021, 10:50 AM   #6
Jedi03
Member#: 491095
2009 STi Blue
176k an counting on original block...had a bit of a scare as started consuming oil again, multiple hoses had cracked, found PCV stuck so cleaned it, got samco hoses to replace all the rubber! will know about consumption soon as just did oil change as well!
Jedi03 is offline   Reply With Quote
Old 09-14-2021, 01:10 PM   #7
benflynn
Member#: 515308
Bust #4 ringland 05fxt vf39 160k
benflynn is offline   Reply With Quote
Old 09-16-2021, 06:25 PM   #8
jeffambo
Member#: 507933
2013 WRX Base Hatch
My Number 4 spun at 110k, Stage 2 OTS map, Invidia DP.
Probably a coincidence but it spun the one I used 5-30 instead of 5-40
Old 09-22-2021, 04:00 PM   #9
SixBladeKnife
Member#: 370019
I don't have enough posts to vote. But my 13 rex only has 52k miles (85k kms). Still going good.
Motor oil: Castrol 0W-40 twice a year since new.
Gear box & rear diff get Fuchs TITAN SINTOPOID 75W-90
SixBladeKnife is offline   Reply With Quote
Old 09-22-2021, 04:00 PM   #10
SixBladeKnife
Member#: 370019
double post some how. please nuke this sone
Old 10-03-2021, 10:05 AM   #11
Ikea_Wrx
Member#: 477215
2012 stock engine no mods. 191k on og motor and transmission. HG done with timing belt around 100k
Ikea_Wrx is offline   Reply With Quote
Old 10-03-2021, 11:53 AM   #12
Matt
Allergic to turbos
Member#: 181
147k 2009 Impreza GT with minimal oil consumption. Oil pump seal was replaced with timing belt during a massive leak around 85k miles.
Matt is offline   Reply With Quote
Old 10-04-2021, 07:09 PM   #13
FlangeBolts
Member#: 520730
Can't respond to poll. Haha. Turbo Baja with 220k on the original engine / trans and still very strong.
Mostly OEM everything. **** gets replaced when it wears out. Easily good for another 100k+
FlangeBolts is offline   Reply With Quote
Old 10-04-2021, 07:09 PM   #14
FlangeBolts
Member#: 520730
EDIT What is with this interface and making double-posts omfg and I can't delete it
Old 10-13-2021, 01:45 PM   #15
StarkWRX
Member#: 473969
2006 WRX
I have wondered about this also, and I think I created/contributed to a thread for logging failures, so we would all know more or less what the average part life span for this engine/platform.
06 WRX, 195K miles, stock engine with many mods, stock turbo, Stage 2 Cobb map
Head gasket blew after overheating at 140K miles (damn OEM radiator). Have a Koyorad rad now, works great. Put in some Barr's HG copper sealer and it has worked for 50K miles, as long as I stay out of boost (pushing coolant into overflow tank).
I have a massive oil leak (my guess is the turbo) about 1 qt every 500-1000 miles. Evident oil leak from rocker cover gasket on passenger side (and a bit on driver side).
Other than that it runs fantastic, I get compliments and I've been using E30 every now and then.
StarkWRX is offline   Reply With Quote
