Welcome to the North American Subaru Impreza Owners Club Monday December 6, 2021
Old 10-11-2021, 06:24 PM   #1
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
Default Alternator wiring question
I have a 98 rs with a 75 amp alternator. Iím upgrading to a 110. The stock fuse is only amps I know I need to up it but will the wiring handle it
jeff6666p is offline   Reply With Quote
Old 10-12-2021, 12:38 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
If you are just changing the alternator without adding a high current load to the normal wiring system I tend to think you will be okay. If the main alternator lead is at least a 8 gauge wire I think you will be okay.
Cougar4 is offline   Reply With Quote
Old 10-12-2021, 01:38 PM   #3
jeff6666p
Member#: 400078
black
I have an 06 wrx swap which came with the 110. I notice at high revs my volts are dropping to 13.2. I donít know what the stock wire is.
Old 10-12-2021, 05:32 PM   #4
jeff6666p
Member#: 400078
black
Well the one I got was a 90 not 110. I put it in and the same thing is happening. Do these cars shut the alternator off at higher loads
Old 10-14-2021, 12:08 AM   #5
Cougar4
Member#: 53443
Winestone
Your alternator may be controlled by the ECU. If there are three wires going to the rear connector that may be the case. Really, 13.2 volts isn't a bad thing. The battery will stay charged up at that rate. Just make sure the alternator can keep up with the load you have on it.
