Welcome to the North American Subaru Impreza Owners Club Tuesday December 7, 2021
Old 10-21-2021, 06:22 AM   #16551
orndog
Member#: 34670
2016 slowmobile
I was going to add one in my kitchen, but realized a dedicated circuit is a must, and since I'm a 2 story on a slab I gave up on that dream.
orndog is online now   Reply With Quote
Old 10-21-2021, 08:23 AM   #16552
LostAndFound
Member#: 253380
02 WRX
Anyone ever see fluctuations in their hot water temperature?
I've noticed that sometimes (very rare) my shower isn't as hot as usual and trying to diagnose if it's me, my 15 y/o water heater is on it's way out, or it's something else. I know I should replace the water heater even though visually it's in great shape. Only thing I can think of is I was afk so didn't run the hot water for 2 days and maybe things cooled down in the tank? Or is this a sign of failure.
I'm sure the anodes inside are seeing wear, but it may be to the point that if I try to replace them things just fall apart completely.
LostAndFound is offline   Reply With Quote
Old 10-21-2021, 09:53 AM   #16553
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
Bury a conduit outside.
NutBucket is online now   Reply With Quote
Old 10-21-2021, 10:13 AM   #16554
ShadowIMg
Member#: 31519
2017 Babby Duramax
2020 Lotus Evora GT
Most shower valves are pressure balance valves, so anything varying pressure on either hot or cold will make the temp bounce. Can't really diagnose your hot water heater that way. Maybe turn a tap all the way hot and let it purge for a few minutes so you know you're getting tank hot water, and then see what you're getting there? Probably too hot to touch though.
Better way is probably to drain it and see what happens after it fills back up. As long as it recovers in a reasonable time, should be OK.
ShadowIMg is online now   Reply With Quote
Old 10-21-2021, 10:15 AM   #16555
f4phantomii
Member#: 58504
2004 STi
Aspen White / Silver
You may have sediment collecting in the bottom that is around the element and reducing the ability to transfer the heat to the water.
Or you may have an intermittently working element.
When we replaced our 15yo water heater (which actually was still working just fine), we went with a hybrid water heater.
Have had it just a hair shy of 3 years and have been very happy with it.
It uses about 25% of the power our old one used. And I like my showers scalding, so I have the temp turned up to 135F-140F depending on time of year.
f4phantomii is offline   Reply With Quote
Old 10-21-2021, 10:31 AM   #16556
orndog
Member#: 34670
2016 slowmobile
Sink is not on an exterior wall, or a wall that extends to attic space.
Old 10-21-2021, 10:39 AM   #16557
07WRBSTI
Member#: 147586
92 FW14B
Cannon decals
Can you change the water line running to the sink? If the supply is 1/2" a 3/8" will reduce time by roughly half. If it's in your slab...sorry.
07WRBSTI is offline   Reply With Quote
Old 10-21-2021, 10:46 AM   #16558
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
Originally Posted by Badler View Post
No, but I'm looking into one. I will report back. Just a little plug in 110v one. Seems to work in a little bathroom we have at work, I just don't know if there's a way to override it being on constantly when hot water is flowing. Basically seeing if you can set a temp cutoff point.
Edit: I know they have the 1 and 2 gal ones. I just don't want to give up that much space for the hot water coming on 45 seconds sooner.
Work has under sink tankless heaters, plugged into 110V. They also have an adjustment knob for regulating temperature. This is the sort of thing I'm looking for.
I have the dishwasher outlet right next to the kitchen sink and can grab power from there.
Unfortunately I cant change pipes. The ones going to the kitchen must be on the 1/2 size.
That could be why previous owners upped the water psi to the max on the regulator.
Hint: Dont, unless you want leaky toilets and faucets.
vapore0n is offline   Reply With Quote
Old 10-21-2021, 10:52 AM   #16559
vapore0n
Member#: 21356
2017 Subaru Corolla
I think its recommended to drain the tank once a year to get rid of sediment.
Last place I used to rent, I could connect the garden hose to the water heater and use that for washing the car inside during winter. Worked great The water contained so much sediment, it looked white. I may have done the landlord a favor in draining the water heater.
Old 10-21-2021, 10:52 AM   #16560
vapore0n
Member#: 21356
2017 Subaru Corolla
Old 10-21-2021, 11:49 AM   #16561
orndog
Member#: 34670
2016 slowmobile
I need to drain my tank. I'd guess the steps are cut off the power first. Do you turn off supply and drain, or do you leave supply on and flush?
Old 10-21-2021, 02:49 PM   #16562
noise boy
Member#: 190706
2018 Ford Focus ST
Big time. I've never seen a condenser placed in that location either
Overhangs look rotted. new gutters. That whole place needs an overhaul. Maybe he can use all of that to his advantage and severely bring down the price.
It's pretty common in downtown B'more on rowhouses.
I would suspect that was there because it's a dual zone HVAC system, that is probably the upstairs condensor.
noise boy is offline   Reply With Quote
Old 10-21-2021, 02:52 PM   #16563
vapore0n
Member#: 21356
2017 Subaru Corolla
I think this covers it
Turn off gas if you have a gas water heater or electricity if you have an electrical one.
Allow the water heater to cool down for a while
Shut off water supply
Turn on the hot water from a nearby faucet to prevent a vacuum from forming and allowing the tank to drain easier.
Attach a hose to the drain valve and run the hose to a drain or empty bucket
Drain the water heater tank by opening the drain valve and allow the water to flow until it stops, you may have to empty a bucket several times during this process. The water can be very hot at this stage unless you let the water heater sufficiently cool down, be careful!
Flush the tank by reopening the cold water supply and allow this to drain. Do this a couple of times to rid of all of the sediment.
Close the drain valve
Fill the water heater tank by reopening the water supply valve
Power up the water heater
Old 10-21-2021, 02:59 PM   #16564
f4phantomii
Member#: 58504
2004 STi
I've always turned off the power and supply, and then just drain the tank.
Once it's empty, you can turn the supply back on and flush it a bit more if you like just to get any last dregs out.
I need to drain my new one as well.
My old one I drained after a couple of years because I needed to move it. And then a couple of years after that I drained it to move it again. So it got flushed early in its life.
Old 10-21-2021, 03:04 PM   #16565
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
Last time I did it I drained the water right away and used the hot water to kill some weeds right outside the garage door.
mhoward1 is offline   Reply With Quote
Old 10-21-2021, 03:18 PM   #16566
orndog
Member#: 34670
2016 slowmobile
Thanks. I'm past 3.5 years now, probably should have gotten on this sooner. Along with exercising all my shut-offs.
Old 10-21-2021, 03:41 PM   #16567
ShadowIMg
Member#: 31519
2017 Babby Duramax
2020 Lotus Evora GT
I just use it hot without letting it cool down to clean out my sump pit.
Old 10-21-2021, 03:49 PM   #16568
orndog
Member#: 34670
2016 slowmobile
Maybe I'll just shut the power off the next time the kid is in the shower. When she screams I know it's safe to drain the tank
Old 10-21-2021, 05:33 PM   #16569
Badler
Member#: 133597
This didn't work like expected.
Source: 8yo and me tried to do this to the 5yo the other day and the mixing valves just don't allow it. Basically just shuts it all down to a dribble. Hilarity did not ensue, but at least he finally got out of the shower.
Old 10-21-2021, 09:30 PM   #16570
vapore0n
Member#: 21356
2017 Subaru Corolla
Those are good mixing valves.
Back at home we used to have an online water heater that was right at the shower outlet.
Hilarity would ensue every time someone decides to use the garden hose.
Super hot water due to lower flow.
Old 10-21-2021, 09:33 PM   #16571
ShadowIMg
Member#: 31519
2017 Babby Duramax
2020 Lotus Evora GT
That sounds like you have a thermostatic valve. They are worth every penny.
Old 10-21-2021, 10:04 PM   #16572
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
I have two girls. I put a valve on the outlet of the water heater. So I can shut it off if they take too long.
car_cursed is offline   Reply With Quote
Old 10-22-2021, 03:27 PM   #16573
Badler
Member#: 133597
Alright dudes, I would like to put brick in these channels.
Couple of questions:
Can I just take some of that DG out, dump mortar in there and use the thin brick pictured?
Do I use some type of thinset instead and then just grout around like a normal application?
Would the just dumping mortar and smashing them in there work better with full bricks?
I'm looking for the least amount of hassle/labor since I'm going to tackle this myself.
Meaty?
Finally got the fireplace and step finished after 7 months.
Old 10-22-2021, 03:32 PM   #16574
Salvation27
Member#: 292403
2012 Legacy
Graphite
I would probably dig slightly further down. Loose gravel- mortar- bricks.
Salvation27 is offline   Reply With Quote
Old 10-22-2021, 03:37 PM   #16575
Badler
Member#: 133597
I was thinking about this as well. Digging it out a bit and the putting sand or something in there and compacting it a bit for a base.
Does that seem like a good idea?
