#5001 | |
Member#: 139693
Vehicle:Dura ngo 95 horrorshow |
![]() Quote:
#5002 | |
Member#: 183032
NESIC
Vehicle:RWD Camry Pull me over red |
![]() Quote:
The winter driving example wasn't to initial a crossing of the streams, it was just a timely example from like ~2 weeks ago; mechanical handbrakes are still relevant, so are manual transmissions. I will continue to seek them out until I can no longer find them. I don't care about, nor did I make a reference to your age. to your 99.9% "statistic" - 97.6% of people don't care enough to drive a car with a manual (or purchase vehicles where it isn't a option) as only 2.4% of sales in the US are cars equipped with a manual transmission. |
#5003 |
Member#: 528253
![]() I don't like having a manual hand brake when E-brake exists. E-brake is much easier to use IMO. Some manual cars needed them because of roll-back.
#5004 | |
Member#: 141373
E. Canada
Vehicle:2019 Crosstrek Sport 6MT |
![]() Quote:
The large infotaiment/HVAC dash is also a mistake IMHO. Single point of failure for a critical system - defogging and defrosting. Anecodtal occurence, but there is a local Legacy here where the screen/system froze (reboot tentatives failed), on a winter morning. The owner couldn't go to work because the car was unsafe to drive. |
#5005 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
#5006 |
Member#: 67807
MAIC
![]() You can't hide the rally heritage with darker colors.
#5007 | ||
Member#: 26859
TXIC
Vehicle:of TXIC I also like (oYo)!!!! |
![]() Quote:
they are going to be on the output shaft of the transmission. if you're parking on a SF style incline, sure, use your parking brake. if you're parking in the street and expect someone to rear end you hard enough to move your vehicle, sure, use your parking brake. they are more than adequate at holding a vehicle in 90% of parking situations. certainly on flat and level ground in a parking lot, or driveway. granted it's been nearly 25 years at this point, but I was a transmission tech at a Ford dealership, so I was highly specialized in automatic transmissions, which I guess gives me a bit more insight on the subject than most might have, and by all means, you do you, but it's just not a necessary thing to do with the parking brake in an automatic transmission. Last edited by samagon; 01-24-2022 at 03:56 PM. |
#5008 | |
Member#: 528253
![]() Quote:
Manual cars do not have a parking gear, so the parking brake is needed on them. |
#5009 | |
Member#: 442
NESIC
Vehicle:17 Imp Spurt 00 S2k |
![]() Quote:
Page 7-39 - "Parking your vehicle" In the section right after "Parking brake".... "Parking tips When parking your vehicle, always perform the following items. . Apply the parking brake firmly. . For MT models, put the shift lever in the "1" (1st) for upgrade or "R" (Reverse) for a downgrade. . For CVT models, put the select lever in the "P" (Park) position. Never rely on the mechanical friction of the transmission alone to hold the vehicle." ![]() And my uncle? Owner of a transmission shop servicing all types and models of transmissions for 50+ years? "Just do it." I'll actually listen to him because he's seen it all and I've learned more about transmissions from him than I needed (or, sometimes wanted) to know. LOL ![]() Last edited by KC; 01-25-2022 at 08:50 AM. |
#5010 | |
Member#: 75071
Tri-State
Vehicle:AR Giulia,Tesla MY 05 08 11 WRX 18 STI 18TM3 |
![]() Quote:
#5011 |
Member#: 26859
TXIC
![]() yup, you guys do what you guys gotta do.
#5012 | |
Member#: 28976
Vehicle:2016 Step 2 Push Buggy GT |
![]() Quote:
-Plastic cladding blends in on darker colors -Aggressive spring rages, jarring ride on city streets. Sharp ride on canyon roads. -Spongy brakes -Crappy shifter feel -Tinny/econobox feeling -Feels roomy for 4 adults -Seating position is too high, feeling of sitting on top rather than sitting in. However.... It does everything well. ^^^All these things are pretty much standard issue on Subaru's and fall well within "clunkiness" factor Subaru's are known for. Welp folks there you have it. Subaru has a big hit on their hands. Certainly record setting sales are on the horizon for the 2022 WRX. I predict nothing will change on the STI, |
#5013 | |
Member#: 75071
Tri-State
![]() Quote:
#5014 |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
![]() Parking pawls are awesomely sturdy, and all.. but rust belters can attest to handbrake failure from disuse. You bought it, use it. Keep it working for when you need it. The tiny drum brakes inside the rear rotors of cars like Subarus are especially prone to falling apart when they remain static all winter long while being soaked in salt brine.
I use the brake all the time, even in automatics. My PHEV Clarity moves significantly in Park in my sloped driveway without the brake, and I know this because the E-ebrake switch is the only button in the cabin that sometimes fails to register. My wife likes to jump out the moment I put the car in Park and then gets mad at me when the car rolls back a few inches. ![]() Anyway, the e-brake handle is a pretty silly point of contention with the WRX. The "I need all the manual control" folks are yanking an e-brake against a center diff with a viscous locker that sends a shuddering braking action to the front axle. The auto (VTD) and STI can at least open the center locker when you pull the e-brake. Maybe seek your e-brake jollies with a drivetrain that isn't still related to 1960s farm equipment. At least with actual farm equipment you can get the fun kind of differential braking. |
#5015 | |
Member#: 442
NESIC
![]() Quote:
"You know, you should drive it in 4WD every month or so to keep everything working/lubed, right?" *blank stare* /And knowing is half the battle! |
#5016 | |
Member#: 527254
![]() Quote:
Some of those things can be fixed simply by getting the GT model. ![]() |
#5017 | |
Member#: 28976
![]() Quote:
![]() Couch position (on the Fatty Recaros), likely not to change on the GT Trim Crappy shifter, likely not to change on the GT Trim Tinny/Econobox feeling, likely not to change on the GT Trim Spongy brakes, likely not to change on the GT Trim Yah no, I gotta disagree ![]() Adjustable dampers, no thanks. I'd rather go KW V2 route or something. |
#5018 |
Member#: 132389
BAIC
![]() Brake sponginess aside, I think 12.4" front rotors is on the smaller side for the class.
Don't get me wrong, going to 12.4" on the VA coming from puny 11.6" on the GR/GV was a huge upgrade; but, the much lighter Civic Si gets 12.3", both GLI and GTI get 13.4" and Elantra N gets 14.2" up front (straight from the Genesis G80 3.5T). An obvious and inexpensive factory upgrade, IMO, would be the 13.1" rotors from the Ascent... |
#5019 | |
Member#: 28976
![]() Quote:
The Si has 12.3" Vented discs in the front, 11.1" Solid discs at the rear. But the Si is appox 400lbs lighter. The Elantra N has nice sized brakes. And agreed, at least a 13" Rotor would be ideal with upsized calipers. |
#5020 | |
Member#: 527254
![]() Quote:
I think you’re mistaken. I’ve sat in the Recaro’s on the GT trim, they didn’t have a weird position but I didn’t drive the car. They were just really tight on the side of your legs. I don’t believe the Limited trim they drove are even Recaro seats. From what I recall, Recaro branded seats are on GT only. You can’t get a crappy shifter, because it can’t come with a manual. Adjustable dampers are one of the biggest things I’m looking forward to. And like it was said in the video, the spongey brakes might be from a bad previous driver. We will know once we have buyers actually giving reviews on brand new cars. The tinny feeling is one reason I would like to go with the Golf R. But, the interior plastics and everything feels less tinny than my 2014 BRZ. So it’d be an upgrade for me. |
#5021 |
Member#: 419593
Vehicle:2019 EA888 Gen3 crew |
![]() So their main complaints were the spongy brake feel, stiff ride and shifter feel, however he did note they just came from reviewing the Blackwing and Si and according to him those have the two best shifters on the market. Car felt quick and handled great at speed. Ton of interior room and great visibility. Very easy fixes when it comes to the complaints. I am sure we will see upgraded pads, SPT short shifter option and DCC with a manual soon enough. Subaru has a winner on their hands, these will sell like hot cakes.
#5022 | |
Member#: 482289
![]() Quote:
#5023 |
Member#: 419593
![]() Most of the buyers purchase these cars because they offer AWD, space, utility and excellent performance at this price point. It looks great too.
#5024 |
Member#: 21356
NESIC
Vehicle:2017 Subaru Corolla STI Limited SE-R Type (R) |
#5025 | |
Member#: 26859
TXIC
![]() Quote:
cable shift doesn't have to feel that bad. it sounds like the new one isn't any better. |
