Welcome to the North American Subaru Impreza Owners Club Tuesday August 16, 2022
Old 05-21-2022, 06:40 PM   #1
2.5LBoxer2
Member#: 529466
Default Multiple Misfires after Timing Belt Done
Hey Subie Community,
Been a stalker here for a long time but now im banging my head against an issue that is beyond my understanding.
I purchased a 2011 WRX running e85 and a bunch of other mods with a tune on it, from the original owner, but since I bought it from the second owner, he has no clue about anything.
Was getting a p0018 crank to cam timing difference code with random misfires on 2 and 4. I looked at the timing and it looked like it jumped a tooth.
Went ahead and replaced timing belt, cam seals, and all idlers and thermostat. After putting it together it was running even rougher and i noticed i was off a tooth. Redid the job and now everything lines up perfectly, ive spun the crank many times to verify.
Now im getting issues with all cylinders misfiring (mostly 2 and 4)and very rich AFR at 11 at idle. Wont really drive without bogging and major misfiring if RPM'd at all. I swapped spark plugs hoping that was the issue and the coil packs were swapped before purchasing.
Still having issues and getting carbon fouling on the plugs themselves. I datalogged at idle and have found major differences in the VVT advancing angle where the left side is at 80-90 angle and the right side is at 4-5 angle. I thought that in neutral the vvt should not be advancing. Also the OCV duty cycles are the same for both sides at 9.41 percent. This is all at idle in neural with some RPMing. The car is still tuned but I am thinking of setting it back to stock to troubleshoot better and take one less this out of the equation.
I know its alot of information, thank you for taking your time and going over it. Ill post my data logs
1.Time (msec) 2.Mass Airflow Sensor Voltage (V) 3.Ignition Total Timing (degrees) 4.Injector Duty Cycle (%) 5.Roughness Monitor Cylinder #1 (misfire count) 6.Roughness Monitor Cylinder #2 (misfire count) 7.Roughness Monitor Cylinder #3 (misfire count) 8.Roughness Monitor Cylinder #4 (misfire count) 9.Intake OCV Duty Left (%) 10.Intake OCV Duty Right (%) 11.Coolant Temperature (F) 12.Intake VVT Advance Angle Left (degrees) 13.Intake VVT Advance Angle Right (degrees) 14.Mass Airflow (g/s) 15.Learned Ignition Timing (degrees) 16.Intake OCV Current Right (mA) 17.Intake OCV Current Left (mA)
Underlined is the VVT advance angle
1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17.
272600 1.26 7.5 1.6 0 0 0 0 9.41 9.41 189 88 3 8.38 10 0.06 0.06
272662 1.26 14.5 1.64 0 0 0 0 9.41 9.41 189 88 4 8.44 10 0.06 0.06
272726 1.28 6.5 1.78 0 0 0 0 9.41 9.41 189 87 3 8.13 10 0.06 0.06
272789 1.26 4.5 1.73 0 0 0 0 9.41 9.41 189 88 3 9.09 10 0.06 0.06
272852 1.26 13 1.98 0 0 0 0 9.41 9.41 189 88 4 8.99 10 0.06 0.06
272914 1.24 8.5 1.63 0 0 0 0 9.41 9.41 189 88 3 8.72 10 0.06 0.06
272979 1.28 11.5 1.7 0 0 0 0 9.41 9.41 189 88 4 8.89 10 0.06 0.06
273041 1.26 15 1.73 0 0 0 0 9.41 9.41 189 88 4 8.08 10 0.06 0.06
273103 1.26 6.5 1.53 0 0 0 0 9.41 9.41 189 88 3 8.74 10 0.06 0.06
273167 1.26 12.5 1.93 0 0 0 0 9.41 9.41 189 88 4 8.4 10 0.06 0.06
273230 1.26 10.5 1.76 0 0 0 0 9.41 9.41 189 88 3 8.48 10 0.06 0.06
273291 1.28 7.5 1.67 0 0 0 0 9.41 9.41 189 88 3 8.69 10 0.06 0.06
273355 1.24 15 2.08 0 0 0 0 9.41 9.41 189 88 4 8.14 10 0.06 0.06
273418 1.28 5 1.65 0 0 0 0 9.41 9.41 189 88 4 8.46 10 0.06 0.06
273481 1.26 10 1.65 0 0 0 0 9.41 9.41 189 88 4 8.72 10 0.06 0.06
273545 1.28 10 1.72 0 0 0 0 9.41 9.41 189 88 4 8.3 10 0.06 0.06
273608 1.26 7 1.52 0 0 0 0 9.41 9.41 189 88 4 8.84 10 0.06 0.06
273672 1.26 15 1.77 0 0 0 0 9.41 9.41 189 88 4 8.07 10 0.06 0.06
273734 1.24 10 1.77 0 0 0 0 9.41 9.41 189 88 4 8.22 10 0.06 0.06
273797 1.3 13 1.67 0 0 0 0 9.41 9.41 189 88 4 8.61 10 0.06 0.06
273859 1.24 13.5 1.81 0 0 0 0 9.41 9.41 189 87 4 8.1 10 0.06 0.06
273922 1.26 4 1.61 0 0 0 0 9.41 9.41 189 87 3 8.54 10 0.06 0.06
273985 1.26 7.5 1.88 0 0 0 0 9.41 9.41 189 88 4 8.9 10 0.06 0.06
274049 1.24 5.5 1.86 0 0 0 0 9.41 9.41 189 88 3 9.04 10 0.06 0.06
274111 1.28 7.5 1.61 0 0 0 0 9.41 9.41 189 88 4 9.37 10 0.06 0.06
274174 1.24 9 1.83 0 0 0 0 9.41 9.41 189 88 4 8.38 10 0.06 0.06
274237 1.26 4 1.62 0 0 0 0 9.41 9.41 189 88 3 9.29 10 0.06 0.06
274301 1.26 10 1.9 0 0 0 0 9.41 9.41 189 88 4 8.99 10 0.06 0.06
274364 1.24 6 1.86 0 0 0 0 9.41 9.41 189 88 4 8.8 10 0.06 0.06
274427 1.28 9 1.61 0 0 0 0 9.41 9.41 189 88 4 9.15 10 0.06 0.06
274489 1.24 11.5 1.78 0 0 0 0 9.41 9.41 189 88 4 8.42 10 0.06 0.06
274553 1.26 6 1.57 0 0 0 0 9.41 9.41 189 88 4 9.12 10 0.06 0.06
274615 1.26 11.5 1.84 0 0 0 0 9.41 9.41 189 88 4 8.55 10 0.06 0.06
274678 1.24 9.5 1.8 0 0 0 0 9.41 9.41 189 88 4 8.64 10 0.06 0.06
274742 1.26 13 1.7 0 0 0 0 9.41 9.41 189 88 4 8.89 10 0.06 0.06
274806 1.24 15 1.84 0 0 0 0 9.41 9.41 189 88 4 8.06 10 0.06 0.06
274868 1.28 10.5 1.57 0 0 0 0 9.41 9.41 189 88 4 8.33 10 0.06 0.06
274930 1.26 15 1.43 0 0 0 0 9.41 9.41 189 88 4 8.03 10 0.06 0.06
274993 1.26 15 1.65 0 0 0 0 9.41 9.41 189 88 4 7.46 10 0.06 0.06
275056 1.24 12.5 1.45 0 0 0 0 9.41 9.41 189 88 4 8.37 10 0.06 0.06
275119 1.26 15 1.83 0 0 0 0 9.41 9.41 189 88 4 8.07 10 0.06 0.06
275183 1.26 14.5 1.65 0 0 0 0 9.41 9.41 189 88 3 7.37 10 0.06 0.06
275245 1.26 11 1.45 0 0 0 0 9.41 9.41 189 88 3 8.13 10 0.06 0.06
275308 1.26 15 1.72 0 0 0 0 9.41 9.41 189 88 4 7.55 10 0.06 0.06
275371 1.24 10.5 1.59 0 0 0 0 9.41 9.41 189 87 3 8.37 10 0.06 0.06
275435 1.28 13.5 1.66 0 0 0 0 9.41 9.41 189 88 4 8.95 10 0.06 0.06
275498 1.22 15 1.99 0 0 0 0 9.41 9.41 189 88 4 7.97 10 0.06 0.06
275560 1.26 8.5 1.57 0 0 0 0 9.41 9.41 189 88 4 8.08 10 0.06 0.06
275625 1.24 15 1.59 0 0 0 0 9.41 9.41 189 88 4 8.31 10 0.06 0.06
275686 1.26 10.5 1.69 0 0 0 0 9.41 9.41 189 88 4 7.8 10 0.06 0.06
2.5LBoxer2 is offline   Reply With Quote
Old 05-22-2022, 03:17 AM   #2
Jp925
Member#: 510046
Switch your OCV cylinders, I had an issue like this, odds are one is on its way out.
Jp925 is offline   Reply With Quote
Old 05-22-2022, 11:59 AM   #3
SuperPete
Member#: 517987
did you reset ECU after timing job?
SuperPete is offline   Reply With Quote
Old 05-24-2022, 01:31 AM   #4
2.5LBoxer2
Member#: 529466
I reset my ECU, most likely thats the problem, will order one and keep everyone updated.
Old 06-10-2022, 09:10 PM   #5
2.5LBoxer2
Member#: 529466
replaced OCV and its still happening. Not sure whats going on? left side cam gears advancing at 89 degrees while right side is at 4.
Old 06-21-2022, 02:06 PM   #6
kakarot09
Member#: 182375
08 Sti
Wrbm
I would pull the cam gears back off and see if you didn't align the dowel pin on the cam inside the cam gear. I've seen this twice before where the dowel pin wasn't in the hole it's supposed to be.
kakarot09 is offline   Reply With Quote
Old 06-24-2022, 11:57 AM   #7
benflynn
Member#: 515308
The gears can get damaged multiple ways, pull one and look down the barrel. Mine were bad from installation, when tightened they “mushed” the metal into the next hole, elongating the dowel hole and almost closing an oil port
benflynn is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
