Welcome to the North American Subaru Impreza Owners Club Thursday October 6, 2022
Old 09-06-2022, 05:26 PM   #1
Wrxxxalexx
Member#: 521366
Default A/C not blowing cold air
I have a 04 wrx not blowing cold air. After doing some diagnostics I noticed the compressor was spinning, fuses were all good, and the engine was low on freon. After refilling it, it was cold but after a day it was giving constant warm air. So I have a leak some where in my ac lines, I see no fluids anywhere near my engine I keep it pretty clean, so if any fluid was to leak I would notice. Though I donít see where my ac could leak any ideas??
Sent from my iPhone using NASIOC
Wrxxxalexx is offline   Reply With Quote
Old 09-07-2022, 01:37 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
use UV dye.
yarrgh is offline   Reply With Quote
Old 09-07-2022, 02:07 PM   #3
Jedi03
Member#: 491095
2009 STi Blue
there are also sniffers that work for locating as well...is your pressure actually dropping or is it just getting warm? are your fans both working? have you cleared out your radiator/condenser fins?
Jedi03 is online now   Reply With Quote
Old 09-22-2022, 07:12 PM   #4
Tyjamo87
Member#: 520275
2007 Impreza WRX Wag
Pearl white
You probably have a leak, since it blew cold after topping up on refrigerant, then went warm after leaking out. Best thing to do is get a vacuum/pressure test from an A/C professional. That will confirm your leak. Then, you'll need to have the professional use his machine to evacuate the refrigerant, which is a gas, not liquid. Once you've done that, you can add some UV Dye to the system, fill it up again, and locate the leak, which may require a black light to see the Dye. A/C diagnostic professional is the best answer. They may help you fix it yourself or not.
Tyjamo87 is offline   Reply With Quote
