Welcome to the North American Subaru Impreza Owners Club Saturday June 15, 2024
Old 07-01-2021, 07:12 PM   #1951
De36
Member#: 475437
2018 WRX
Originally Posted by basyager View Post
You mean the fluid overheats cuz calipers can't dissipate the heat? If so, wouldnt it have to start boiling to have an effect? I just dont understand how calipers can overheat. Theyre just pieces of iron
Larger calipers & rotors = more mass = more heat (aka thermal energy) absorption. Which means the pad can take more thermal energy & stay cooler longer. Pads have a working-heat range that they have to stay within. Above this working heat range will cause brake fade.
Cooling comes from things like ducts, rotor fins, etc... You can use thermal paint to determine cooling: LINK
Fluid boiling is a function of fluid type (e.g. Motul 600 vs 660). Which causes a spongy pedal.
Hope I explained that clearly...
De36 is offline   Reply With Quote
Old 08-06-2021, 09:51 PM   #1952
milkywitness
Member#: 522156
Helps me at least lol
milkywitness is offline   Reply With Quote
Old 03-09-2022, 04:08 PM   #1953
spkrfrk
Member#: 529167
Default Newbie here with a broken clutch and Tranny 2015 Wrx limited. :/
Hey guys and gals, iím a newb to this forum and stoked to be here! Unfortunately iím also here because according to Subaru my clutch broke and screwed up my transmission. I bought the car at a used car dealer @54k miles and it drove great, no upgrades, completely stock to 89k mikes.
The Dealer is saying i need a new clutch and tranny rebuild. They want to charge $5,140 dollars. I can afford it so thatís not an issue i just wanted to reach out to see, since iíve almost paid off the car and do plan on keeping it and modding it down the road what other options are out there as far as upgrading to a used Sti tranny for example or upgrading the clutch. Though Iíve owned 4 STiís and this my first WRX iíve always had them stock - Iíve seen plenty of posts on these forums about Ďgoing to stage 2í etc and was wondering since its gonna cost a pretty penny what you all think i should do.
Any advice is greatly appreciated, thank you.
spkrfrk is offline   Reply With Quote
Old 03-09-2022, 06:14 PM   #1954
my name is joe
Member#: 171412
Upgrade to a 6 speed. It's about the same cost as Subaru fixing it.ep
my name is joe is offline   Reply With Quote
Old 04-18-2023, 09:39 AM   #1955
MarkC
Member#: 533947
2015 WRX
Default New to WRX
Thanks for this info. Never knew about NASIOC
MarkC is offline   Reply With Quote
Old 09-22-2023, 02:39 AM   #1956
ilikain
Member#: 535195
Was going to post a help request but since this is about a 2015 WRX thought maybe I could post it here.
2015 WRX, manual 6 speed transmission. 160k miles. Just had $3k work done on the Timing Chain, also had a solenoid replaced... can't find the paperwork, but think it was cam shaft related.
During acceleration the car becomes extremely jerky the majority of times (very rarely it runs smoothly with no issues).
Happens around 2.5k rpm and seems to happen pretty consistently up into high speeds/rpms, but the jerkiness tails off at highway speeds and only happens during acceleration. More pronounced at lower speeds.
As the boost starts to engage it feels like a delay in the power transfer a short lag and the the acceleration hits hard and jerks the car around. PSI on the boost meter bounces with the jerks.
The turbo itself has a more pronounced whine to it that also persists longer than normal.
Fuel efficiency has dropped from about 23mpg combined to under 17mpg combined.
There is no engine light on and it never turns on.
Subaru dealership reset my ECU and updated the firmware and it seemed to go away on the drive home, but was there the next time I ran the car. They found no other issues.
When the car is shut off after driving I am smelling something that smells a bit more like burning rubber than oil, but is light and isn't as pronounced as straight burning rubber, if that makes sense.
In California and always use premium 91 octane gas. No knocking during acceleration either.
Just trying to point a mechanic in the right direction to get this fixed, but no one seems sure of what it is. Definitely wasn't the timing chain. Not mechanically learned, so ask any questions that would help.
Thanks in advance.
ilikain is offline   Reply With Quote
Old 09-22-2023, 02:40 AM   #1957
ilikain
Member#: 535195
duplicate
Old 11-07-2023, 08:38 AM   #1958
grifone1977
Member#: 534773
Default timing belt
goodbay..sorry for my english....
i have to replace the kit timing belt to my wrx sti 2015 modello gj 221 kw ej25
which kit gates is correct for my car?
gates KP25612XS-3??
thanks for your help
Stefano
grifone1977 is offline   Reply With Quote
Old 11-20-2023, 08:43 PM   #1959
stopdroprocknroll
Member#: 478560
Default awesome
great post man. have had great times in my 2015
stopdroprocknroll is offline   Reply With Quote
Old 02-12-2024, 11:46 PM   #1960
charlie24
Member#: 537002
Default So helpful
This is awesome. Thank you so much
charlie24 is offline   Reply With Quote
Old 02-27-2024, 04:12 AM   #1961
legrand
Member#: 537169
thank you very helpful
legrand is offline   Reply With Quote
Old 03-02-2024, 01:44 AM   #1962
kamillenielsen
Member#: 536247
Nicely done Gro!
kamillenielsen is offline   Reply With Quote
Old 03-20-2024, 02:58 PM   #1963
JIGG
Member#: 216715
2005 STI
BLACK GOLD RIMS
JIGG is offline   Reply With Quote
