Welcome to the North American Subaru Impreza Owners Club Tuesday January 14, 2025
Old 01-08-2025, 11:03 PM   #1
Bugeye01WRX
Member#: 506873
2001 WRX
Sedona Pearl Red
Default 2010 STI rougher than I'd like
Hey everyone !
Recently bought a 2010 STI A Line (auto JDM) and have been looking at it for a while.
I used to have a 350z but a recent back injury (slight bulging disc) made the 350z FAR too uncomfortable to drive.
I thought I was going to have to give up sports cars but the 2010 STI Auto looked comfy and had a nice adjustable seat.
I test drove a few and it was comfy, lots of headroom etc so I thought it was a good compromise.
Anyway, a beautiful one with gorgeous mods came up and I ended up buying it.
However, I never test drove it long distance and I do a little bit of travelling.
It is sitting on TSD coilovers and has a set of Workmesister S1P1s on stretched tyres.
(https://boostedkiwi.co.nz/products/s...D5x9Li4HMTK5N9)
https://www.fitmentindustries.com/br...r-S1-3P/18x9.5
Anyway, I bought the car, did a longer trip and it seemed great. However, I had to get the car raised a bit as it was far too low couldn't get in in driveway. Coilovers were sitting between soft and firm and I changed it to fully soft.
Anyway, did a 1.5 hr each way trip yesterday, and the car felt harsh. EVery little bump I hit I felt like the car bounced aggressively and it did it in a way where the car felt like it weighed 10 tonnes and landed and "left my body behind" and I ended up slamming down into my seat if that makes sense.
It is kinda hard to explain but you imagine a plush car bounces and you kind of go up and down gently. This felt like the car would drop immediately and harshly and would jar my neck, back and head.
I am now in a bit of a conundrum. Car is stunningly beautiful and has very nice mods but I really want to make it more comfy.
Will returning to OEM struts/springs be enough? Or is is always going to be inherently too rough because it is an STI.
Is it a combination of stretched tyres, cheap coilovers and low profile tyres causing this?
ANy other advice?
I don't need/want it to be aggressive as I just want a sporty car for daily that sounds and looks good
Bugeye01WRX is offline   Reply With Quote
Old 01-08-2025, 11:18 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I don't know those struts. Can you adjust jounce and/or rebound? Those would likely help you out.
What are your tire (or is it tyre?...LOL) pressure? I usually recommend 80-85% of max inflation based on the molded max on the sidewall, NOT what the owners manual states since tires may have been replaced.
Old 01-09-2025, 12:42 AM   #3
Bugeye01WRX
Member#: 506873
2001 WRX
Sedona Pearl Red
Not sure on tyre pressure atm but it is running 235/40R18 tyres on 9.5 inch wide Works
Old 01-09-2025, 01:29 AM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Book values for tire pressure is for the OEM installed tires.
Example, on my 1998 Legacy GT with the RE-092's, max inflation was 46PSI, book pressure was 38?
I switched to Conti extreme contact M&S with a max inflation of 55, I would run 44-46PSI, the book of 38 was a poor ride.
Old 01-09-2025, 02:23 AM   #5
Bugeye01WRX
Member#: 506873
2001 WRX
Sedona Pearl Red
Is my tyre size also contributing to it ? Should I go for Taller tyres with more sidewall and go back to OEM suspension ?
WIll that make it a lot more comfortable?
Old 01-09-2025, 09:11 AM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Sidewall is some of a hard ride. Partly due to less sidewall give, partly due to higher pressure to avoid killing tires.
Your tire size means you have some sidewall which helps.
Here's a thought, is there another Subaru around you with the same bolt pattern? Ask to do a tire swap for a couple days. Theirs should be close to OEM size.
It could be their winter tires if they have them.
Old 01-10-2025, 06:53 PM   #7
nomoretickets
Member#: 538662
What spring rates are you running? If you are running really stiff auto-x springs, the ride would probably be pretty tough and I would consider swapping to something softer.
nomoretickets is online now   Reply With Quote
