Welcome to the North American Subaru Impreza Owners Club Thursday April 19, 2018
Old 01-13-2004, 03:05 PM   #26
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
I have run Nitrous for a while now. I put 10-12 bottles through my Stock EJ engine running 11's without issue. Its like anything else. you will have to learn and you will have to tune the system.
When I pulled that engine out it tested perfect on the compression and leak down and sold it. Its still running today. Nitrous does not hurt anything. Detonation and ultimate power output does. I would rather have a small turbo and a 50 shot over a big turbo. Because 80% of the time the smaller turbo will be more fun. When you want to take someone down simply fill the nitrous bottle/add some octane and spray. A 50 shot removes almost 1 full second from your 1/4 mile time and you can Bet it will remove 5 tenths everytime.
The issue is that with a VF30 or larger turbo and nitrous its pretty easy to get carried away and overwork those stock engines. Those rods are weak and they will snap if you produce alot of power. The good thing is they are cheap and you can toss the busted one in the dumpster and slam another one in the car in 3 days work.
The point I want to make when using pump and or limited octane fuels is that often times the limit is the octane and in this case the nitrous is not going to help. You will have to give up boost and timing (power) to make room for the power increase by the nitrous. Spraying on 91 octane is pointless. Spraying on C16 is fun
Cya
Clark
AZScoobie is offline   Reply With Quote
Old 01-13-2004, 03:39 PM   #27
wickedbluwrx
Member#: 33299
pretty good points...
wickedbluwrx is offline   Reply With Quote
Old 01-13-2004, 03:47 PM   #28
wickedbluwrx
Member#: 33299
hey azscoobie and big turkey how far are u guys from san antonio
Old 01-13-2004, 08:13 PM   #29
Big Turkey
Member#: 32118
I'm in Houston. Clark is in Arizona. I'm actually setting up right now in the Texas forum for him to come down here and tune some more cars. If you're interested get with me through PM or something. Clark will definately make power, as long as your motor allows. Like he said, some cars make tons of power, some just don't want too.
Big Turkey is offline   Reply With Quote
Old 01-14-2004, 02:16 AM   #30
cronic
Member#: 9749
Big turkey i believe he is in NY(this is rich right, rsorry only know your sqc name)
Rich Louis and i are also talking to Mike to get him and Clark out to Ny for a second dyno day, if by some chance Tx is closer hit up big T if not hit me up if you are interested.. Probally wont be till early-mid spring, but will be well worth the wait..
Dave
cronic is offline   Reply With Quote
Old 01-14-2004, 08:29 AM   #31
wickedbluwrx
Member#: 33299
i'll keep u posted dave
Old 01-15-2004, 11:03 AM   #32
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
I ran a similar setup to an 11.96 with my best trap speeds at 117mph. This was a STG4TMI with NX 50 shot.
I tuned this setup using VP C16 race fuel. It was a great setup and incredibly consistent at the track. As Clark mentioned it's nice to run a smaller turbo with a 50 NX shot as it makes it very easy to launch.
Thanks,
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 01-15-2004, 02:42 PM   #33
AZScoobie
Member#: 8785
netcom.com
Yeah.. ANd you get that huge trq curve and power curve! You want to see lag phil? Click my w w w button below my sig. I am working on it and lots of that is the headers and I had no time to tune it but still.... Its growing old
Clark
Old 01-15-2004, 04:36 PM   #34
wickedbluwrx
Member#: 33299
motox are you running a vf30 or 34
Old 01-15-2004, 06:19 PM   #35
Big Turkey
Member#: 32118
Clark
Man, Clark, I didn't know the lag was THAT bad! Hey at least you're revvin' to 8k..
Old 01-16-2004, 12:43 PM   #36
AZScoobie
Member#: 8785
netcom.com
Yeah but the power drops off hard because of the cams in this motor. That pull was untuned on a dyno day. Its much better now getting full boost in the late 4K range. Manifolds should bring that down. Otherwise I think I will put something small back on like a new 1820 and just spray it with a 75 shot. The car hauls ass now but its just not usable for road racing....
Clark
Old 01-19-2004, 12:50 PM   #37
scooby
Member#: 13085
I have been running a 50shot for about a year with a vf22 @17psi on both pump and race gas. I made 316whp w/o no2 tuned very aggressive though. Then made 373whp with 17psi and 50 shot on pump gas. Then used the aggressive nonnitrous map from vividracing for the link and ran c16 and the nitrous and got 412whp with no problems (I'll try digging up dyno sheets for ya, its been about a year). My motor is fine and i've probably went through as many bottles as azscoobie did and my car has held up fine and it rips pretty good, only problem is i had to differ to a rps 6 puc clutch and blew first gear and third. I would worry more about gears than the 2.0L block.
good luck,
your choice
scooby is offline   Reply With Quote
Old 01-19-2004, 03:04 PM   #38
motoxphil
Member#: 5094
wickedbluwrx,
I was running the VF30.
Clark,
Wow, that is just an unacceptable amount of lag. I agree, I couldn't live with that on a street driven car.
Phil
TurboXS
Old 01-19-2004, 07:13 PM   #39
wickedbluwrx
Member#: 33299
wow hopefully i can get up to these numbers. thanks for the info guys
Old 01-27-2004, 08:08 PM   #40
MissWRX
Member#: 22983
2004 AP2
Former 280whp Rex Nut
Rich....
Do I get to beat on, I mean drive it first since it was my turbo on my car??
MissWRX is offline   Reply With Quote
Old 01-28-2004, 11:59 AM   #41
wickedbluwrx
Member#: 33299
of course you do anything for my girl. when do you think we will be able put the little blue devil together.
rich
Old 01-29-2004, 12:20 AM   #42
V REX
Member#: 11102
02 WRX,05STi Sold
01 Boosted IS300
good luck,
your choice
How long did your tranny last? Did it blow right away or after a few bottles?
V REX is offline   Reply With Quote
Old 01-29-2004, 11:27 AM   #43
AZScoobie
Member#: 8785
netcom.com
Moral of the story... Run a stock clutch guys. 400+ whp does not make a stock clutch slip. If it does, replace it, its just worn. You want that cushion to keep the trans together. If anything go to the 30% stronger Exedy sport clutch. Scooby. You must have used Brainstorms dyno right?
Clark
Old 01-30-2004, 03:33 PM   #44
wickedbluwrx
Member#: 33299
ive been seeing some nice numbers with water injection. is water injection like running race gas all the time?can you run c-16 and WI or is there no such thing. what do think the vf34 will run on WI? sorry for all the question but just looking to run a good set up
Old 02-02-2004, 11:40 PM   #45
MissWRX
Member#: 22983
2004 AP2
GO ALCOHOL hehehhehee,
Old 02-03-2004, 11:53 AM   #46
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
I think it would be kind of redundant to run WI w/race gas, I mean Rich you still have a stock bottom end or a whole stock motor for that matter how aggressive do you really want to get? Do a search on WI you'll see that a few people have made great gains with it from pump gas, in some cases as much as 30whp gain. Pretty impressive, and yes tuning with WI from what i can tell it's similar to tuning using race gas. You can run the car leaner, run alittle more boost, or advance the timing a degree or two.
It's not without risk though, read up on it bro.
Paul
PaulRex is offline   Reply With Quote
Anyone running a PDX Custom Cobb Tune? scotty144 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 52 02-05-2006 07:19 PM
Anyone Running a Bosal Down with a vf34 uncle lewie wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-16-2005 05:13 PM
Anyone running a LinkPlus on an RS-T redmeanie Texas Impreza Club Forum -- TXIC 1 07-10-2002 10:50 PM
Anyone care to comment on Cobb Tuning? Darryl Texas Impreza Club Forum -- TXIC 25 07-29-2001 08:06 PM
Anyone running a GanzFlow on their MY 95-99? gtguy Normally Aspirated Powertrain 9 02-09-2001 07:56 AM
