Welcome to the North American Subaru Impreza Owners Club Thursday October 10, 2024
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds
Old 02-18-2005, 05:30 PM   #1
jared nelson
Member Sales Rating: (11)
Member#: 35075
Default stock WRX intake mani with wiring, rails, TGVs, ect.
forsale intake manifold off of an 02 WRX
I bought it off ebay needing just the coil packs and now the rest is forsale to whoever wants something off it. make offers.
I took the MAP sensor off, but the AIC valve is still on
sitting here looking at the manifold, ill list all parts still intact.
TPS sensor
IAC valve and sensor
throttle linkage
Throttle body
Fuel rails and lines
Tumble generators valves (2 are damaged)
Brackets for mounting the stock topmount
Misc Emmissions shti Misc coolant lines
Upper and lower manifold its self
Stock BOV
Engine wiring harness
3 good coil packs one bad one (these retail for 100 per pack)
Stock Fuel pump
jared nelson is offline   Reply With Quote
Old 02-18-2005, 05:51 PM   #2
jared nelson
Member#: 35075
also i have the stock intake elbo and an extra AIC valve.
Old 02-18-2005, 06:05 PM   #3
ride4fun05
Member Sales Rating: (2)
Member#: 62747
1998 Impreza L
Red
do you have an exhaust manifold?
ride4fun05 is offline   Reply With Quote
Old 02-18-2005, 06:06 PM   #4
jared nelson
Member#: 35075
I do but im not sure If I am going to be selling it. its tapped for an EGT bung right below the passenger cyl bank. might even be ported, but im not sure.
Old 02-19-2005, 01:25 AM   #5
azn2yunr
Member#: 67229
9295 BC/gm6
winestone/funky blue
dibs on the fuel system (rails and injectors) ill talk to ya this weekend
azn2yunr is offline   Reply With Quote
Old 02-19-2005, 03:38 PM   #6
jared nelson
Member#: 35075
i dont have injectors, just rails and all the other lines. injectors are NOT hard to come by though , i know where you can get new ones that are premodded for 100 bucks.
Old 03-04-2005, 03:12 PM   #7
jared nelson
Member#: 35075
bump, the exhaust manifold is now forsale for sure! i just recently ported the inlets on both banks, and painted it with ceramic 1500 degree paint. I put on about 5 coats of it, and also painted the heat sheilds inside and out. Its obviously not as good as ceramic coating the manifold, but it does retain much heat, and keep the engine bay cooler, and the EGTs higher. It changed my spool up by about 400 RPMs with the uppipe that I am using. which is also painted with this same stuff. I am going to port them more, and also change the middle pipe section to a larger one, for added flow. then when you put it on your car the look will be stealth, and stock even if someone gets under your car, but you will be adding some pretty good power. Ill sell the manifold like it is right now, for 125+ shipping. It is also tapped right under the pass side bank for an EGT probe. the headers will come with the probe for an extra 25 dollars.
Old 03-05-2005, 12:42 AM   #8
jared nelson
Member#: 35075
bumpo..
Old 03-05-2005, 02:29 PM   #9
jared nelson
Member#: 35075
bumpe thanks
Old 03-07-2005, 05:10 PM   #10
pgapro
Member#: 39348
PMed You
pgapro is offline   Reply With Quote
Old 03-07-2005, 05:33 PM   #11
jared nelson
Member#: 35075
responded
Old 03-07-2005, 06:01 PM   #12
dug-e-fresh
Member Sales Rating: (4)
Member#: 4568
10.7 @ 136, '02 WRX
12.8 @ 112, '09 spec.B
I want the engine wiring harness. PM me what you want for it.
def
dug-e-fresh is offline   Reply With Quote
Old 03-07-2005, 06:16 PM   #13
jared nelson
Member#: 35075
make an offer, what is it from the factory...? ill charge you less than that.
Old 03-07-2005, 06:20 PM   #14
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
From Subaruparts.com- $221.70
I'll offer $100?
def
Old 03-07-2005, 07:36 PM   #15
jared nelson
Member#: 35075
sold to the fresh man named dug!
Old 03-07-2005, 07:36 PM   #16
jared nelson
Member#: 35075
plus shipping
Old 03-08-2005, 11:08 PM   #17
Section 8
Member Sales Rating: (3)
Member#: 821
$15.00 shipped for the fuel rail that doesn't have the regulator on it (just tubs in and out)?
Section 8 is offline   Reply With Quote
Old 03-08-2005, 11:54 PM   #18
WRX-CBR
Member#: 82197
03 WRX
Still have the BOV? How much?
WRX-CBR is offline   Reply With Quote
Old 03-09-2005, 11:23 AM   #19
jared nelson
Member#: 35075
i do still have the BOV, ill ship the fuel rail for 15 [email protected] is my paypal, ill send the items 24 hrs after the money is sent.
Old 03-09-2005, 04:39 PM   #20
Section 8
Member#: 821
Payment sent
Old 03-09-2005, 05:23 PM   #21
jared nelson
Member#: 35075
thanks, everything is going out tomorrow. if anyone has any questions please email me at [email protected]
Old 03-18-2005, 01:40 PM   #22
pitcrew
Member Sales Rating: (19)
Member#: 45715
1995 2.?L miami vice
Heavy Metal
Do you still have the bare intake manifold? How much are you asking for it?
pitcrew is offline   Reply With Quote
Old 03-18-2005, 01:43 PM   #23
jared nelson
Member#: 35075
just sold it for 125, but id be willing to possibly sell the one off my car in lue of making another one out of aluminum... let me know if you are interested in that... i would not be selling the lower portion of it which is the tumble generator valve section, just the upper part with NO throttle body.id keep the TB and then make my own upper mani...
Old 03-18-2005, 02:08 PM   #24
Section 8
Member#: 821
pitcrew-
I have a set of TGV's if you need them. They are completely stock. I can remove the accelerator plate if you want me to.
Jared-
Recieved my stuff. Thanks.
cheeRS,
Greg
Old 03-19-2005, 12:15 PM   #25
jcu1276
Member Sales Rating: (12)
Member#: 49754
great seller
jcu1276 is offline   Reply With Quote
stock wrx stuff - catback, wing, fuel rails, tgv sensors, etc. arrowscooby SCIC Private Classifieds 1 04-19-2010 01:47 PM
FS: Stock WRX Intake System with K&N Drop-In JASWRX Engine/Power/Exhaust 11 07-27-2009 12:30 AM
F/S stock wrx intake mani and TB inmotionwrx SCIC Private Classifieds 11 06-13-2009 12:20 AM
FS: Stock WRX Intake System with K&N Drop-In JASWRX SWIC Private Classifieds 7 05-12-2009 07:36 AM
FS: 02 WRX short block, TGVs, intake mani, TB, fuel rails rewt Engine/Power/Exhaust 24 11-28-2007 11:43 AM
