Welcome to the North American Subaru Impreza Owners Club Monday December 18, 2017
Old 08-19-2003, 05:05 PM   #1
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Default More 2.5 STI short block info...
here is a link to more info
http://www.i-speed.us/news/sti_block...=ST;f=12;t=115
More Pics: http://www.i-speed.us/news/sti_parts.shtml
Also, we do not know if people are telling you this, but we have been told be several Subaru Reps and Subaru dealers that the 2.5 STI short block will ONLY work with the 2.5 STi heads. Well, that's not entirely true.
With the help of our engine builder, Crawford Performance, we can now get the new 2.5 STI block to work with USDM WRX heads! We keep the 2.5 STi turbo crank and rods and use special forged Crawford pistons. These Crawford pistons keep the proper compression ratios that the wrx heads need to operate effectively. Without specially designed pistons in place of the STI pistons…the 2.5 STI block will not work with the wrx heads.
Now, it's time to put that R/D on the street and then the DYNO
Chris
i-speedusa.com
[email protected]
Crawford/I-Speed is offline   Reply With Quote
Old 08-19-2003, 05:16 PM   #2
nmyeti
Member#: 4980
Link isn't working.
Just out of morbid curiosity can you confirm that the picture above is your custom piston setup installed in a 2.5L sti block?
Those pistons look like they have quite a bit of dish in the picture (could just be picture quality). Do they have more or less dish than the standard UDSM pistons?
Any chance you are willing to reveal dish volume?
nmyeti is offline   Reply With Quote
Old 08-19-2003, 05:23 PM   #3
nmyeti
Member#: 4980
Old 08-19-2003, 05:27 PM   #4
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
nmyeti - yes it is our custom setup (2.5 STI block with Crawford custom pistons).
Yes, there is quite a bit of dish when compared to the stock STI pistons. And yes, we know the picture is not the greatest.
Sorry, not ready to divulge dish volume.
Chris
i-speedusa.com
[email protected]
Old 08-19-2003, 09:54 PM   #5
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
the 2.5 block will also work with the JDM STi heads as well btw
DarthChicken is offline   Reply With Quote
Old 08-19-2003, 10:14 PM   #6
hotrod
Member#: 14141
2002 Impreza WRX
Default heads won't work
Could you clarify the "stockUSDM wrx heads won't work" statement.
Do you mean that with the stock heads and no change in piston you have excessive compression, or you get valve to piston interference or both.
Do your custom pistons return the engine to the stock (for the 2.5 STi) compression ratio, or did you choose a slightly different compression ratio to make the heads work?
Thanks for the info and pic's!!
Larry
hotrod is offline   Reply With Quote
Old 08-19-2003, 10:30 PM   #7
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Larry - Yes keeping the stock STI pistons with the USDM heads will get you "excessive compression". We also noted that you may have "valve to piston interference".
BTW: We did not test the interference theory. But other people are more than welcome to try it
"Do your custom pistons return the engine to the stock (for the 2.5 STi) compression ratio, or did you choose a slightly different compression ratio to make the heads work?"
We chose a different ratio
Chris
I-Speed USA
[email protected]
Old 08-19-2003, 10:40 PM   #8
XT6Wagon
Member#: 524
04 STi
So how much of an overbore is possible with this block? looks to be much more capible of mega displacement than the normal STi EJ20 block.
XT6Wagon is offline   Reply With Quote
Old 08-19-2003, 11:06 PM   #9
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
how much more do you need? I speed already has a 2.8...
Old 08-19-2003, 11:19 PM   #10
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Can't wait for testing results
MAD REX is offline   Reply With Quote
Old 08-20-2003, 12:33 AM   #11
BoostedAWD
Member#: 19519
2002 Subaru WRX
World Rally Blue
i thought the 2.5 STI blocks were closed deck? cuz it seems to me that, that looks open deck
or am i wrong in the defintion of what a closed deck is?
-thanks
BoostedAWD is offline   Reply With Quote
Old 08-20-2003, 12:36 AM   #12
totoherbs
Member#: 7321
.... 122 IggPoints
-thanks
The new age sti blocks ej207/257 are not closed decks... they are reinforced decks. The older blocks ej20g,k? and the ej22t are semi closed decks. There are no closed decks from the factory
Old 08-20-2003, 12:37 AM   #13
Scuba Steve
Member#: 35543
04 GT35R STi+E85
[email protected] @5800ft elv.
-thanks
The 2.5 STi block is "semi-closed".
Scuba Steve is offline   Reply With Quote
Old 08-20-2003, 12:55 AM   #14
BoostedAWD
Member#: 19519
2002 Subaru WRX
World Rally Blue
thanks for the info.
Old 08-20-2003, 01:18 AM   #15
Tuning Factory Inc.
Vendor
Member#: 3600
Where can I get a set of those pistons? I need sety for a block I have sitting here.
Tuning Factory Inc. is offline   Reply With Quote
Old 08-20-2003, 01:37 AM   #16
Austin
Member#: 7089
2016 STi
Are normal people now able to get ej257 shortblocks through normal channels?
Austin is offline   Reply With Quote
Old 08-20-2003, 01:37 AM   #17
STEALTH-WRX
Member#: 7822
Multi layer snot green
Let me say that i have personally dealt with Crawford Peformance and all i can say is that he knows alot. He knows his stuff. He also has been messing with subarus for years and lives and breathes motors. Anything from Crawford gets two thumbs up from me.
STEALTH-WRX is offline   Reply With Quote
Old 08-20-2003, 01:42 AM   #18
I am mattjk
Member#: 36411
I can be PM'd at
"mattjk"
Nice! Time for me to start saving my duckets.
I am mattjk is offline   Reply With Quote
Old 08-20-2003, 01:44 AM   #19
mlambert
Member#: 13831
Not sure why you would want to waste your time running crap usdm wrx heads on a 2.5L block, unless you want a (small) stump puller that falls on its face at high rpm. If you want to do it, do it right the first time.
mlambert is offline   Reply With Quote
Old 08-20-2003, 02:34 AM   #20
I am mattjk
Member#: 36411
I can be PM'd at
"mattjk"
I'm not trying to run 9's like Nick is... I'd be really happy sticking the new forrester engine in my car
Whatever is cheaper, cuz I'm poor
I guess I could just get a 2.5 sticker.
Old 08-20-2003, 02:44 AM   #21
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
“Where can I get a set of those pistons? I need sety for a block I have sitting here.”
We would need to know exactly (compression, material, size etc…) what you are looking for and the application you would be using them for. That would help us to help you better. Email me for details.
“Are normal people now able to get ej257 shortblocks through normal channels?”
I have no idea. Crawfords' Subaru connections run fairly deep. To be honest we all were surprised when we got what we asked for.
“Not sure why you would want to waste your time running crap usdm wrx heads on a 2.5L block, unless you want a (small) stump puller that falls on its face at high rpm. If you want to do it, do it right the first time.”
True the WRX heads may not be completely up to the 2.5 STi short block potential. However, getting the 2.5 STi short block to work with heads that most people seem to have is what we were after. In any case, this option now provides new avenues for people to mod their WRX. Where those people go from there is up to them and most often… their pocket book.
Chris
I-Speed USA
[email protected]
Old 08-20-2003, 03:01 AM   #22
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Woops...forgot to answer this one
" So how much of an overbore is possible with this block? "
The overbore capability is 1mm. But in fact the overall thickness of the liner and casting is less than the 2.0.
Chris
I-Speed USA
[email protected]
Old 08-20-2003, 03:45 AM   #23
XT6Wagon
Member#: 524
04 STi
Well its just that some people seem to bore the EJ20 block out for 100mm pistons.... and since the inner AND outer diamiter of the "liners" is bigger in radius I figured that it could take a decent ammount of extra bore size.
Old 08-20-2003, 04:12 AM   #24
mlambert
Member#: 13831
I dont want to turn this thread into a bitch fest as I think there could be useful information gained from it but...
... the pocket book argument is ****ing weak when it comes to building a proper 2.5L stroker. If you are in the market for something like this, please do yourself a favor and atleast get cams to stand up to the task at hand.
Old 08-20-2003, 04:31 AM   #25
I am mattjk
Member#: 36411
I can be PM'd at
"mattjk"
I can't even afford brake pads, let alone cams right now.
Feeler: 2.5 STI Short block and 2.0 heads ryan_west06 Engine/Power/Exhaust 49 04-05-2009 11:04 PM
Fully built 2.0L or 2.5 Sti short block? jifnjelly05 Built Motor Discussion 11 01-18-2007 12:06 PM
Want to switch from a blown stock 2.0 to an 2.5 sti short block jaltman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 02-01-2006 07:40 PM
[B]Want to switch to a 2.5 sti short block from blown stck 2.0[/B] jaltman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 01-20-2006 12:39 PM
2.2 legacy or 2.5 sti short block garret Normally Aspirated with bolt-on Forced Induction Powertrain 28 10-16-2003 04:34 PM
