Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Old 04-26-2014, 11:59 PM   #51
thill
Member#: 377200
18 Miata Club
Jet Black Mica
Originally Posted by -vanguard- View Post
Hmmm, my leather on my left thigh bolster is already showing some creases 250 miles in.
Cars is low so I rub on it every time lol.
Same thing happened with my BRZ Limited. After four months it looked like the seat was four years old..
thill is offline   Reply With Quote
Old 04-27-2014, 01:24 AM   #52
beat22
Member#: 113763
15 sti launch
04 wrx wrb
Subscribed
beat22 is offline   Reply With Quote
Old 04-27-2014, 09:27 AM   #53
Redeemed77
Member#: 378138
2015 WRX
CWP
Best thread on the board, subscribed
Redeemed77 is offline   Reply With Quote
Old 04-27-2014, 09:51 AM   #54
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP 2016 Sienna
Suspension:
2015 WRX Swaybars: Front 24mm, Rear 20mm. Apparently the rear is same as 2008-2014 models and can interchange but no one has done it yet.
I've got a 22 mm whiteline. Should I do it?
Old 04-27-2014, 10:23 AM   #55
thill
Member#: 377200
18 Miata Club
Jet Black Mica
Yes!
I mean if it drives worse or you don't notice any difference you can always swap the OEM back on.
That said, I think it would be an improvement since the front is 24mm. That is a big sway bar and I believe the car might drive better with a larger rear that comes closer in size to the front.
I am thinking about doing this one too, but would love for you to be the guinea pig
I am hoping the crew at Turn In Concepts gets a 15 WRX soon, those guys are super helpful.
Old 04-27-2014, 11:31 AM   #56
Celery GT-5
Member#: 98210
yeah that would be nice
Old 04-27-2014, 01:35 PM   #57
Gro Harlem
Member#: 165782
2015 WRX Limitd Stg2
'02 Stg4 & JSW TDI Stg2
Subaru Stars
yes! so we can 100% confirm they actually fit. I don't think anyone has actually swapped a GR sway on.
If the whiteline is adjustable i'd put it in the firmest setting.
Gro Harlem is offline   Reply With Quote
Old 04-27-2014, 01:40 PM   #58
Defiantguy
Member#: 41268
2015 WRX
Some excellent reading here. Thanks for doing this for us new/returning WRX owners.
Defiantguy is offline   Reply With Quote
Old 04-27-2014, 01:43 PM   #59
Celery GT-5
Member#: 98210
I would, because the stock one is already 20mm
The only reason I don't want to do it is because you have to brake loose those big ass 17mm nuts that are nicely oem torqued from the factory lol
Old 04-27-2014, 01:44 PM   #60
gargleblaster
Member#: 11107
2015 WRX STi
Crystal White Pearl
Rally Sport Direct has already confirmed that the 2015 STI rear bars are compatible with previous gen sedan bars. I would imagine the WRX will be the same.
edit: link to proof:
http://www.iwsti.com/forums/3979763-post16.html
gargleblaster is offline   Reply With Quote
Old 04-27-2014, 01:49 PM   #61
Celery GT-5
Member#: 98210
has anyone confirmed if extended hangers help the exhaust fit
I read that the sway would fit before, just not sure if I want to mess with perfection trollol
Old 04-27-2014, 05:43 PM   #62
ECP
Member#: 280021
Default Disabling the DRL on a 2015 WRX
Havent seen this around the forum yet but before you go taking things apart under the hood like the thread here http://www.iwsti.com/forums/2015-sti...ng-lights.html
about this topic, just lay down on the ground under the passenger side front under the headlight assembly, look underneath and remove all of the plastic clips holding the mud deflector it's only like 7 of them and 1 10mm bolt, push up through the bottom and right next to the horn, attached to the support brace that holds the horn is the DRL resistor.
Just seperate the connector, wrap it in tape or plastic if you want and align the deflector back in place and clip and bolt it back together. 15 mins tops to do this
No need for a lift or ramps, its that simple
ECP is offline   Reply With Quote
Old 04-27-2014, 05:55 PM   #63
-vanguard-
Member#: 379708
2015 WRX Limited Nav
Has anyone figured out how to make the C LEDs DRLS yet?
-vanguard- is offline   Reply With Quote
Old 04-27-2014, 06:27 PM   #64
quantum13
Member#: 389143
2015 WRX Limited
i could be wrong here - but when i was checking out the car at the dealer, i don't recall it being particularly easy to tell when the C LED's were on in bright daylight. not sure they'd have any effect when used as DRLs
i know the highbeams are currently the DRL's at partial intensity but what i cannot remember is under what circumstance the C LED's come on - i want to say it's the 'parking light' - the setting before your headlights come on but i don't recall
quantum13 is offline   Reply With Quote
Old 04-27-2014, 06:40 PM   #65
-vanguard-
Member#: 379708
The Limited's LED C's are definitely bright enough to be used as DRLs.
The problem is, the non-limited C's aren't bright so subaru had to make the highbeams a low powered DRL for all the models.
When its daylight outside and my limited has the parking brake on, the C's are very visible and bright.
Old 04-27-2014, 06:47 PM   #66
quantum13
Member#: 389143
2015 WRX Limited
hmm- maybe i saw a different model? i think i was looking at an STI because they didn't have any limiteds on the lot yet. it had LED headlights but maybe the C's were not LED? well i may be mistaken; clearly yours are good enough so who knows what i saw. i was more focused on figuring out what the LED headlights look like so i wasn't paying close attention to the C LED's.
i did have the thought that with all those other lights on the car, there must be a way to do DRL's using something other than the high beams but i guess i wasn't motivated enough to try and rig that up. could be that some electronic switch might exist that can activate a relay to energize some other light source when the high beams are sent partial power - but then pass the current through to the highs when they are sent the full power. doesn't sound terribly complicated but i have no idea if such a thing exists
Old 04-27-2014, 06:54 PM   #67
quantum13
Member#: 389143
2015 WRX Limited
this guy redirected his DRL's to his fogs. not a bad idea...http://forums.nasioc.com/forums/show....php?t=2383843
possible that similar technique could accomplish your goals. i'd be inclined to just disable them; running halogens at 40% or whatever isn't the greatest for bulb life.
EDIT: i read further on in the thread that his method pulls the power BEFORE the resistor box so you get the full 12V to do with what you please. i'm sure you could tie the output to the LED's just as well as he did the fogs. give it a try; let us know how it goes!
Old 04-28-2014, 09:39 AM   #68
transit
Member#: 354722
2015 WRX Limited
I'm not sure if this has been covered, but does 15 WRXs share the same windows/windshield as 2014 Impreza?
transit is offline   Reply With Quote
Old 04-28-2014, 11:52 AM   #69
-vanguard-
Member#: 379708
Gonna wait till someone else experiments lol.
Old 04-28-2014, 11:57 AM   #70
Gro Harlem
Member#: 165782
OMGHi2U
Awesome info! I added it to the knowledge base. I'll be disconnecting my resistor immediately when I get my car...WHICH IS AT 4PM TODAY can't wait!!!
UPDATE: Also Added Stereo/Speaker information but need confirmatoin on the nav unit. Apparently the BRZ had two different types of nav units and I'm not sure which one they are putting in the 2015 WRX/STI's, anyone remove theirs yet to confirm? The wiring kits are different is why I'm asking.
Also I need to figure out if the wiring adapters to get steering wheel controls work from the 2014 Impreza/Crosstek's for both the base and nav head units.
Going to add speaker adapter info when I have someone confirm whether the ones from the GD/GR's are the same, and still need to find out speaker depth limits.
Old 04-28-2014, 12:02 PM   #71
thill
Member#: 377200
18 Miata Club
Jet Black Mica
In the US, the BRZ both head units in the BRZ are a Fujitsu 10 unit to my knowledge with the difference being AHA radio support.
The 2015 WRX/STI looks like it uses this exact same head unit (Fujitsu 10).
Old 04-28-2014, 12:22 PM   #72
epv
Member#: 381966
2015 WRX
I haven't been able to get my car to understeer in street driving, so I would say no unless you've had different experience so far. Car is absurdly planted.
epv is offline   Reply With Quote
Old 04-28-2014, 12:44 PM   #73
Celery GT-5
Member#: 98210
Yeah that's why I haven't done it. Although maybe with the bar it would oversteer a little...
Old 04-28-2014, 12:47 PM   #74
SoapBox
Member#: 204578
My wife said she'd
buy me a Lotus, AKA REX8
Go into a parking lot, lock the wheel in one direction and floor it.
You're not going to get understeer until you break traction, by definition. You have to be in a real hurry for that be be occurring on the street.
SoapBox is offline   Reply With Quote
Old 04-28-2014, 12:48 PM   #75
Celery GT-5
Member#: 98210
Yeah based on trying that in my old wrx I would never do that..felt awful
