#1 |
Member#: 123159
VIC
Vehicle:Now with 75% more spite. |
![]() Im going to Afghanistan and will be returning with hella cash and am putting 10K into my suby. If you were me, and had this car, what would you do with it to make it a well rounded ride ?
2003 WRX (MBP) mods: Cobb AP Work emotion cr kai Champiro HPZ tires H-tech springs Samco IC hoses catless TBE (Cobb, PDE) HKS UP Hawk HPS front pads Obviously I am going to replace the springs with coilovers, and switch to a FMIC with a bigger turbo. Here is my tentative list: evoIII 16g perrin FMIC 650cc Deatchwerks injectors some sorta coilovers walbro fuel pump 4 piston brakes FSB/RSB kartboy endlinks meth kit PPG 1st gear ? Thats just the start, and the plan is to buy a lot of it used to save money... but I dont think this is too close to 10K yet. The next option is to put a 2.5L in and go big, but then I have to start on the tranny... Alright, lets hear what you guys think I should do.
#2 |
Member#: 92003
SCIC
Vehicle:04 bicycle! |
![]() 2.5 block + gears thats about 6g right there
#3 |
Member#: 48199
Vehicle:06 WRX WRB |
![]() If *I* had 10k I would invest it into my future. Houses, safe investments, etc...
But if you are going to invest it into a 4 year old car. Then yes your on a good start. I'd probably go Axis stg 2 + ppg set and 20g or bigger turbo + supporting mods and tuned for a built motor. |
#4 |
Member#: 123159
VIC
#5 |
Member#: 121031
![]() I'd make it into a bugeye STI.
2.5 block/VF39 6 speed and DCCD Brembos or just 06 4/2pots New headlights And use the leftover 2-3k for cosmetic stuff for your new Bugeye STI, such as gauges ![]() |
#6 | |
Member#: 123159
VIC
![]() Quote:
#7 |
Member#: 123159
VIC
![]() If Im going to put a 2.5 in I would go a lot bigger than a VF39. For the amount of money a new block would run I would have to put something worth all that money in there. The brakes, headlights and gauges are a good idea though.
#8 |
Member#: 129692
SCIC
Vehicle:2011 WRX Sedan Obsidian Black Swirl |
![]() Gamble it all.
I kiiiid. Your plan sounds mighty fine. I'd do the tranny first, but thats me. |
('93-'01) If YOU had my car....What would you do? | Jeff~ | Impreza Forum | 8 | 10-04-2009 12:52 AM |
If you were to turn around the Yankees, what would you do? | Thursday | Off-Topic | 14 | 11-24-2003 08:31 PM |
$20,000,000 -- what would you do with it? | gerbs | Off-Topic | 93 | 11-17-2003 10:05 AM |
If u had an engine from an 850i, what would you put it in? | dcoty | Off-Topic | 50 | 04-03-2003 08:19 PM |
If you had $2000 to spend in japan, what would you buy? | xsnoiz | Southern California Impreza Club Forum -- SCIC | 19 | 09-10-2002 11:38 PM |
