#1926 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
![]() I can't say that IM spacers and TB spacers are always going to be useless, but they are on our engines at least.
#1927 |
Member#: 415438
International
![]() Project Hybrid Intake is a success! I had to do some more tweaking than I expected, but everything fits nicely now without any tension. Good clearance everywhere. I also like the looks of all the parts combined.
Some visual results: ![]() ![]() ![]() ![]() One hose clamp had to be mounted out of line to get the connection tight. Maybe I'll cut the silicone adapter parallel to that clamp, but it's ok for now. Function over form. ![]() ![]() ![]() The first vacuum hose connection was positioned quite badly. It was a PITA and it took some more tweaking to get that right. It grinds the metal brace a bit, so I isolated the hose with some good tape. I think this wil hold. Maybe later I'll put something in between or around that part of the vacuum hose just to be sure. ![]() ![]() (I have a lot of close-up pictures uploaded online. So please feel free to ask for more if needed / interested.) I reset the ecu, let the car run for 15 minutes and drove around the block for a bit. So no performance results yet. I did feel some more low throttle response and a bit more pull around 3500 rpm. But I was just carefully testing if everything was ok. I'll let you know when I can say something really useful about that. ![]() Last edited by Roke; 03-23-2015 at 03:48 PM. Reason: Pictures lined up badly; fixed that. |
#1928 |
Member#: 416217
Vehicle:2007 Impreza 2.5i Black |
![]() Keeping my eye on this, looks like a very clean easy install. Minus the hose issue. Let us know how the tune or the general overall performance feels over time. Nice picture quality and good angles - Thank you
#1929 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
![]() how much heat does the mass of the manifold absorb??? how much better off are you if that mass doesn't get as hot??? keeping heat out of the engine bay any way you can is a good idea as heat degrades.....everything over time. some of the benefits of some things just aren't quite as glaringly apparent as others don't dismiss them off hand without a bit more thought |
#1930 |
Member#: 71092
![]() I dismiss them after extensive testing. I've run with thermocouples bolted to the IM both with and without the IMS. The IMS do not produce a measurable reduction in IM temperatures. The IM just gets absolutely baked from radiation off the top of the block and from convective heating from the whole thing. Not to mention the heat absorbed through EGR and PCV systems ducting into the IM. The amount of heat it absorbs via conduction through the small cross-section of the shell of the runners is meaningless vs the large amounts of heating it gets in other ways.
Hell, that's even assuming you aren't still heating the IM via the throttle body hot water loop. Additionally, the IMS increase the effective length of the runners. This moves peak torque lower, which is exactly what this engine doesn't have a problem with. If you want to change runner length on an EJ253, longer is NOT the way to go. |
#1931 |
Member#: 16200
![]() the metal upper header tank on the turbo models is one of the places that many don't think of as an IM heat source, but it is one of the MAJOR heat sources to the IM
and I have played around with a lot of this and .... well....yeah. keeping the manifold as cool as possible is a good idea.....and it cools off a lot faster if it is isolated, too 3mm spacers don't add enough manifold volume to make any difference, either |
#1932 |
Member#: 71092
![]() Keeping the IM cool would be beneficial, yes. However, the IMS don't contribute meaningfully to that. I've vaguely wanted to experiment with putting a low-emissivity coating on it like Swaintech White Lightning to see if that would reduce the temps and then finding some way to encourage more of the hot air rising off the exhaust and block to go somewhere else. Those two things ought to make a difference.
#1933 | |
Member#: 415438
International
![]() Quote:
The vaccuum hose issue will be resolved soon. I'm simply going use a piece of black flexible PVC hose cover (with metal rings inside). The same stuff our MAF cabling is protected with. Two tie-wraps. Done! ![]() Performance has definitely improved. I'll leave a separate post about that. p.s. Pictures were taken with an iPhone 5S. Performs quite well if the surrounding light is good. Last edited by Roke; 03-31-2015 at 09:44 AM. Reason: typo |
#1934 |
Member#: 415438
International
![]() Wouldn't a turbo hood, as rice as it may be, help with keeping the IM cool?
If you think about it: - When driving outside air is blown on top of intake hose / IM area. Cooling everything and pushing down hot air. (Not mentioning dirt and water for now.) - When standing still hot air from engine and exhaust manifold, which is always rising up, can escape a bit. (I have a turbo hood in my garage, but I still haven't decided if I want to use it.) |
#1935 |
Member#: 415438
International
![]() "The vacuum hose issue will be resolved soon. I'm simply going use a piece of black flexible PVC hose cover (with metal rings inside)."
It's quiet in my store, so I decided to do something right away. The Legacy is parked in front, so I could keep an eye on the door. ![]() Tweaked it a bit. Fits great! (Cut could be cleaner, but the bad part is out of sight.) It's sitting tight in the metal brace and there's room enough for the vacuum hose to slide and wiggle a bit. It doesn't touch the intake manifold. Just one tie-wrap underneath it so it can't slide down. (picture 3) ![]() ![]() ![]() I don't think many people will come accross this issue, but if they do this is a good solution. Not pretty, but not really ghetto either if you ask me. ![]() (Excuse me for going berserk with words over this minor upgrade.) |
#1936 |
Member#: 416217
![]() Would look better in light yellow!! :-P nice fix dude, looks it was made that way!
No apologies needed, the best feeling is succeeding on even the smallest mod to ones vehicle. |
#1937 |
Member#: 71092
![]() Yes, the turbo hood is well worth it even though it's ricey. Measurable and significant decrease in both IAT and IM temps and, MUCH more importantly, it's 16lbs, 6oz lighter than the stock RS hood. It's quite an improvement to the handling!
#1938 | |
Member#: 415438
International
![]() Quote:
When I'm enthusiastic I tend to explain everything in detail. That feels like some kind of nerd rage sometimes, but I don't mind. This happens even when using another language so it seems. ![]() |
#1939 | |
Member#: 415438
International
![]() Quote:
Someone once told me it's NOT ok to have outside air running into the engine compartment because that might mess things up. His argument was that the engine needs a certain operating temperature to function like it should. Cooler outside air could compromise that according to him. I don't think this is really an issue, but I've never forgotten it. Last edited by Roke; 04-01-2015 at 04:05 PM. Reason: typo |
#1940 |
Member#: 415438
International
![]() Time for some results!!!
Please keep in mind I own a 2007 Legacy BP5 2.0R (DOHC and AVCS) with UEL header with MagnaFlow cat and a Invidia 3" > 2.5" catback. I've driven around with the hybrid intake enough to be able to say something about how it performs. I really couldn't find the time to run tests, so here's some butt dyno data. I could tell a great deal about it, but I'll just sum up everything I felt. My butt dyno is very sensitive and I'm honest about everything. -Car starts faster. (Starting motor turns less at least one time.) -Car runs smoother at idle. (Also with climate control running.) -No low RPM torque loss. -With cold engine car is a bit more restless. (A bit bumpy when using the clutch.) -Overall better throttle response. -When shifting fast during normal driving the car 'bumps' sometimes. (When stomping one the clutch pedal fast.) -Almost insane boost between 1800 and 3000 rpm. (Almost feels like the car is charged somehow. Makes me do ![]() -A bit more pull between 3000 and 4000 rpm. -No significant difference in higher rpm's, but some more pull around 6500 and higher. (When reaching max. power. That's around 7200 rpm.) -Nice intake 'growl' around 3500 rpm's and a bit in high rpm's. I do have another kind of reverence. I don't know if it worth much, but it is visual proof. ![]() I've shot a video a while ago (with oem intake) while doing 0-150 km/h a fast as I could with normal start and normal shifting. After installing the hybrid intake it did the same thing (besides doing almost 200 km/h). Same setup, same road. The only differences where the outside temperature being a bit hotter and a tool box in the trunk. Just one try because I didn't want to push things. The results where a bit better. (0-100 km/h 0.4 seconds faster. Timed both vid's with a stopwatch 10 times and took the average.) So it's save to say the hybrid intake performs well. I'm VERY pleased with it and I would like to thank everyone that has been contributing to this thread. |
#1941 | |
Member#: 71092
![]() Quote:
Below -10F, the challenge is getting non-engine things warmed up and keeping them that way. Grease in the axles, tranny/diff oil, etc. Below about -30F, just getting it started to start warming things up becomes difficult and you may need to restrict airflow under the hood as well as switch to different lubricants for just about everything. |
#1942 | |
Member#: 415438
International
![]() Quote:
#1943 |
Member#: 384014
Vehicle:81 Brat white |
![]() Wow looks pretty good!
#1944 |
Member#: 415438
International
![]() Hi,
Just letting you all know I'm running the hybrid intake for almost 5 months now without any issues. The negative experiences like the minor 'bumping' when shifting have gone. Thay may partly have to do with me getting used to it, but I'm quite sure things just have smoothened out (ECU learning?). It's still performing great. I've swapped my Cosworth 'performance' panel air filter for a OEM style (Mann Filter) panel air filter because I don't believe in performance air filters any more. They just let through more dirt and the bigger amount of air they claim to let through simply does not noticeable add to performance. I did not feel ANY difference after going back to OEM. (I think a cleaner intake trajectory does more for performance than a bit of extra air.) |
#1945 |
Member#: 429122
Vehicle:2009 Impreza 2.5i Charcoal |
![]() Just getting into the Impreza side of things and am so glad I found this thread! Now my 09 Impreza and my sand drag legacy can breath better! Question though (and it's noobie at best and down right pitiful at worst) Is it possible to for some one to show photos of the snorkus (again, new as can be to subaru world)? Just so I know what I am looking at before I start trying to do this my self.
BTW Roke, nice setup. |
#1946 | |
Member#: 399625
TXIC
Vehicle:2009 Impreza 2.5i Spark Silver |
![]() Can some one explain the downsides of deleting resonator? I've had mine gone for at least 20K with hybrid intake and nothing bad has happened but what could? I'm unfamiliar with downsides.
#1947 | |
Member#: 71092
![]() Quote:
If you deleted the resonator, YOU ARE NOT RUNNING A HYBRID INTAKE. The problems with deleting the resonator are shown clearly in the first post and then discussed about another 20 times in the pages that follow. You don't need anyone to explain anything to you, you just need to re-read what has already been said. |
#1948 | |
Member#: 399625
TXIC
![]() That's my question being that the snorkus on the 08-11 is way different shape I just wanted clarification I did read all of that before I asked. Just didn't see anyone that did resonator delete and left everything else up front the same( Imay have overlooked) but if Id everything "hybrid" but also delete the resonator I'm essentially running in to the same issue as SRI correct?
#1949 |
Member#: 440428
Vehicle:2002 Impreza ts Dirty |
![]() Hey there I'm jumping in kinda late and I admit I did not read all of the 78 previous pages but I think I may have some helpfull ideas and photos. 1st idea is that stock internals can only give what they are capable of so the stock NA subbie really can't effectively give you more just by you trying to feed it more. 2nd idea balance is key. Sound is cool but fast is cooler. I drive a 2002 ts. Engine is bone stock with 212k. I know to much is bad and too little is no fun so all of my more have been in an effort to make the car less restrictive inside stock tuning. I kept the stock headers and increased the front section to 2inch including new cat. Rear cat deleted,2.25 pipe from cat to tip. Intake side is stock air box with the inside trimmed. Also I filed the inlet to the stock filter box to 2.25inches. Basic idea is that the flow of air in and out is balanced. I do realize that more aggressive builds require more flow. But the principal of balance is the same. In my opinion stock parts can and probably should be modified as a part of the initial stages of the build. As I said my car is old and is looking for a donor engine for next year, but it hauls ads. Considerably quicker than stock fom 0-105(current limit 115 ). Here is a link to the exhaust. This is the second setup I've designed for the car. Much better than my uninformed 1st gen designhttps://youtu.be/qqCOIbA2hzU. Hope this wasn't insulting and it provides solid info.
#1950 |
Member#: 71092
![]() Everything you did was pointless. You need to do a hell of a lot more research on the science of how a normally aspirated gasoline internal combustion engine works before you try to "help" people.
You only changed parts that are not a problem and you didn't change anything that actually improved the flow of the engine. Intake and exhaust piping diameters should not be equal because intake and exhaust gas volumes are not equal. |
CAIs, SRIs, and dynos | Bluefoton | General Community | 10 | 04-09-2008 08:27 PM |
problems with 04' sti into an 01' RS help! | Imbaru25rs | Subaru Conversions | 7 | 02-18-2006 02:40 AM |
Any problems with your STI and with SOA? | bbbwrx | STi Forum Archive | 3 | 08-27-2003 04:32 PM |
LOTS of Problems with SOA, Dealer, and MYSUBARU.com | saleen90181 | Newbies & FAQs | 11 | 11-26-2002 01:37 PM |
Anyone with CAI, Unichip and stock turbo? | Dougeefresh | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 04-27-2002 12:13 PM |
