Welcome to the North American Subaru Impreza Owners Club Sunday August 7, 2022
Old 05-03-2012, 11:27 PM   #1
driftingrotary
Member#: 234715
2003 wrx
charcoal
Default Car won't start, no signs of life... HELPPP!!!!!!!
my car was running fine, then it died at an intersection. when you turn the key to the on position there's no signs of life, no fuel pump, no lights for the gauge cluster, no head lights, windows don't roll down, car doesn't have power locks, but the only thing that it has is the dome light and the amount of miles on the odometer. i've checked all the grounds and replaced all the fuses and relays. last of all, the fuse box underneath the driver's side behind the change holder. NONE of the fuses are getting any power. any help would be great! thanks.
driftingrotary is offline   Reply With Quote
Old 05-04-2012, 12:47 PM   #2
LIChuck
Member#: 266122
2007 WRX Limited
UGM
Start at the battery and trace power from there. Most likely a blown fusible link.
LIChuck is offline   Reply With Quote
Old 05-04-2012, 03:08 PM   #3
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
The main fuse/link doesn't look like a conventional fuse so it can be missed when checking, it sort of looks like a relay. It's in the engine fuse box, has a clear top and has stud terminals with nuts. If it blows just about nothing in the car will work.
It's 80A and they don't blow for no reason, so if it did blow the fix may be more than just swapping in a new one.
Mulder is offline   Reply With Quote
Old 05-04-2012, 03:20 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Power to the panel under the hood is carried by the smaller battery lead tied to the positive post. Make sure power is making it to the panel and to the fuse Mulder mentioned. Hopefully you have a test light probe to check for power. It is a good thing to purchase if you don't have one already.
Cougar4 is offline   Reply With Quote
Old 05-04-2012, 04:18 PM   #5
LIChuck
Member#: 266122
2007 WRX Limited
UGM
A fusible link can have a mechanical failure, if it failed from a short, he'd probably know something was seriously wrong.
Old 05-04-2012, 04:33 PM   #6
It_wasntt_me
Member#: 300955
2004 WRX
Java Black Pearl
Must've been hit by an emp.
It_wasntt_me is offline   Reply With Quote
Old 05-05-2012, 11:25 AM   #7
klarowe
Member#: 284753
2004 WRX STI
CHeck your battery terminals to make sure they are tight and not corroded. Take the terminals off, clean everything with a wire brush, then put them back on tightly. If that doesn't work, move on to the wire between the battery and fusebox, then to the fuse, etc.
klarowe is offline   Reply With Quote
Old 05-17-2012, 02:35 PM   #8
07wrxstage2
Member#: 262366
07 wrx-sold 06sti-
sold 00rs-rip 05 GRP LGT
^+1. I had this problem on my 2000 rs and I went and bought a new battery because everything seemed fined but then realized there was to much corrosion one of the terminals. Went to wal-mart and bought a new one for like $5 and used the old battery and it worked. Ofcourse I returned the new battery I didnt need. May not be the problem though. good luck
07wrxstage2 is offline   Reply With Quote
Old 05-19-2012, 12:00 AM   #9
Jman00
Member#: 310102
07 WRX
WR Blue
I have an 07 WRX and also have a problem with it not starting. I replaced the headlights (and had to remove the battery), and now it doesn't start. Lights come on, AC works and the radio even turns on but the motor won't turn over. Does anyone know what I need to do to solve this?
Jman00 is offline   Reply With Quote
Old 05-19-2012, 02:31 AM   #10
It_wasntt_me
Member#: 300955
2004 WRX
Java Black Pearl
Charge battery
Old 05-19-2012, 09:05 AM   #11
Jman00
Member#: 310102
07 WRX
WR Blue
I tried that and it still does the exact same thing. Is there anything else I can try?
Car won't start, no a/c, pw or radio power Cushman Electrical & Lighting 1 07-20-2011 11:43 PM
AP Flash Failure? Car won't start, no test patterns with connectors connected BOFslime Engine Management & Tuning 5 06-02-2011 12:57 AM
Car won't start, no power in Acc mode wo^tron Electrical & Lighting 13 03-11-2010 11:05 PM
My car won't start, no spark boost_wagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-07-2009 09:07 AM
car won't start, dip stick indicate no oil. dknc Service & Maintenance 9 09-18-2003 05:33 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
