Welcome to the North American Subaru Impreza Owners Club Wednesday December 1, 2021
Old 09-18-2021, 04:41 AM   #1
alexmartynyuk
Member#: 191967
2005 EVO VIII
instagram @boost_reality
Default Reserved thread for cars tuned by me for your entertainment
Hello everybody, my name is Alex as you may already know by my username. I have been meaning to start a thread and post the cars I tune, some of you may find it entertaining.
Most of these cars will be Subarus, although if its ok with the mods I might throw in some other cars here and there but I will try to keep it strictly Subaru related.
Short story about why I tune: I got into tuning many years ago after getting my bugeye wrx. I quickly figured you can't just bolt thing on without a tune. Also figured out that tuning is extremely expensive! So I started reading a lot and making small changes to the tune on my personal vehicle. As the years went on I got more experienced at tuning and started tuning other peoples cars.
Most of these will be logs ran through Virtual Dyno and may not be as accurate as I would like them to be as far as power numbers but they will still show spool/boost/afr.
Anyway I would like to start off with this Black 09 Hatch I'm currently working on remotely.
Car: 2009 JDM STI
Elevation: Pretty much sea level
Weather: HOT 90+
Fuel: 95 Ron on first graph and 95 ron plus VP octanium unleaded and spraying methanol on the second graph
Boost: Straight pump is 19ish psi, octane booster plus methanol injection 27.5psi
Modifications:
Stock Transmission
EJ207
2.5L nitrited crankshaft
Manley Htuff rods
Manley stroker pistons 8.5:1
Heads and cams are stock
FIC1000cc injectors
Walbro 255lph fuel pump
KSTech 73mm cold air intake
Front Mount intercooler
Unequal length headers of some sort
Uppipe with 38mm tial EWG
Grimmspeed 3 port
FPBlue Turbo(non antisurge)
Catless exhaust
Snow performance methanol injection system
Stock ECU tuned on the stock rom still using MAF
Here is straight pump gas, numbers are probably off by a bit as its hard to find a perfectly flat stretch on this island.
Ok here is the graph with VP octanium unleaded plus meth spraying, wideband disconnected during the pull but I have the AFR in the high 10s so if the meth system fails maybe it will not blow up immediately. This run was done on as flat of a stretch of road as possible
Methanol tune vs pump
alexmartynyuk is offline   Reply With Quote
Old 09-18-2021, 05:10 AM   #2
alexmartynyuk
Member#: 191967
2005 EVO VIII
Car: 2004 USDM STI
Elevation: 26 feet above sea level
Weather: 60
Fuel: 92 octane pump gas
Boost: 22ish psi
Modifications:
Stock Transmission
New 2.5L nitrited crankshaft
Saenz rods
JE FSR pistons if I remember right
FIC1000cc injectors
APS 70mm intake
Unequal length headers(agency power I beleive)
FPRed Turbo(non antisurge) 8cm hot side
Catless exhaust
Grimmspeed electronic boost control solenoid
4th gear log on a very flat stretch of road
Old 09-19-2021, 01:59 PM   #3
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default jdm ej205 swapped bugeye wagon
Car: 2003 USDM Bugeye Wagon
Weather: 90* Fahrenheit
Modifications:
Stock Transmission
JDM EJ205 and ecu swap utilizing AVCS
Catless exhaust
Catless Uppipe
Stock USDM TD04
Stock intercooler and intake system
Grimmspeed 3 port EBCS
Old 09-19-2021, 02:40 PM   #4
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 04 WRX Sedan very well sorted stage 2
Car: 2004 WRX Sedan MT
Weather: 65* Fahrenheit
Modifications:
Stock Transmission
Stock EJ205
Catless exhaust
Catless Uppipe with tial 38mm EWG
Stock ported USDM TD04
Gimmick turbo inlet
Cold air intake(dont remember the brand)
Front mount intercooler
Walbro 255 fuel pump
Old 09-27-2021, 03:10 AM   #5
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 2014 WRX Sedan Stage2+
Car: 2014 WRX Sedan
Elevation: 26 Feet above sea level
Weather: 79 Degrees Fahrenheit
Fuel: 92 Octane
Boost: 19.5 psi peak tapering to 15.5psi up top.
Modifications:
Stock Transmission
Rebuilt short block with unknown parts
Cobb SF intake
Aftermarket top mount(mishimoto I believe)
Equal length headers(don't know the brand)
Stock untouched turbo
Catless exhaust
Grimmspeed 3 port
Old 09-27-2021, 03:25 AM   #6
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 2015 STI Stage1
Car: 2015 USDM STI
Weather: 60 degrees fahrenheit
Fuel: 92 octane
Boost: 16.5psi peak tapering to 14psi by redline
Modifications:
Completely Stock
Old 09-27-2021, 03:41 AM   #7
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 2015 STI Stage2
Car: 2015 USDM STI
Weather: 85 degrees fahrenheit
Fuel: 92 octane
Boost: 18.5 psi peak tapering to 15.5 psi by redline
Modifications:
Invidia Catless downpipe
Grimmspeed 3 port
Old 09-27-2021, 05:10 AM   #8
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 2013 WRX Sedan Stage 1
Car: 2013 USDM WRX Sedan
Weather: 49 degrees fahrenheit
Fuel: 92 octane
Boost: 16.5 psi peak tapering to 14.5 psi by redline
Modifications:
Stock
Old 09-27-2021, 05:20 AM   #9
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 2013 WRX Sedan Stage 2
Weather: 50 degrees fahrenheit
Fuel: 92 octane
Boost: 18.5 psi peak tapering to 14.5 psi by redline
Modifications:
Unbranded catless downpipe
Custom single exit catback
Old 10-12-2021, 08:31 PM   #10
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 06 stock block STI SR55 turbo
Car: 2006 USDM STI
Fuel: 92 octane
Boost: 24 psi
Modifications:
APS SR55 turbo (internally gated)
APS Front mount intercooler system
APS 65mm CAI
Torqued solution turbo inlet
Still has tgvs
Stock unported exhaust manifold
Stock uppipe
Side feed injectors unknown brand or actual flow rating(scaled at 800cc)
APS 3 piece downpipe
APS catback
Grimmspeed 3 port
Stock ECU tuned utilizing a merp mod patch set up hybrid speed density as the 65mm intake was maxed out for resolution.
Old 10-16-2021, 02:45 AM   #11
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 09 WRX Sedan Stage 2
Car: 2009 USDM WRX Sedan
Weather: 62 degrees fahrenheit
Fuel: 92 octane
Boost: 18.5 psi peak tapering to 13 and change up top
Modifications:
Catless Downpipe
Catback
Stock ECU COBB AP tuned using Accesstuner
Old 10-17-2021, 03:40 AM   #12
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default My daily beater 2005 Evo 8 GSR Arashidynamics 25g ball bearing
Not a Subaru but this is my personal vehicle that has been on this setup for a few years now.
Car: 2005 USDM Evo 8 GSR
Fuel: 92 octane
Boost: 27 psi
Modifications:
Arashidynamics 25g which was converted to run a 6+6 compressor wheel (internally gated)
VRSF 3.5" front mount intercooler
Custom 4" intake pipe with a 9" k&n filter
VRSF lower intercooler pipe
Short route upper intercooler pipe
Forced Performance race cast manifold ported by me
VRSF o2 dump(sorta equivalent to a subaru divorced downpipe except for the divorced section dumps to atmosphere when the gate cracks open)
3 " downpipe
3" catless test pipe
SRS catback exhaust
Hallman PRO rx mbc ceramic ball with heavy spring
GSC S2 cams
GSC springs and retainers with stock valve keepers
FIC 1000cc injectors
Walbro 255 with pressure relief mod.
Stock ECU tuned utilizing a Tephra 3D Speed density patch
Old 10-26-2021, 04:02 AM   #13
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 07 STI FP3794 92 octane pump gas
Car: 2007 USDM STI
Weather: 59 degrees Fahrenheit
Boost: 26psi
Modifications:
Stock Transmission
Manley Htuff rods
Cosworth pistons(dont remember the alloy or part number)
Still open deck
ARP 2000 11mm head studs with stock head gasket
Heads and cams are stock with farrea valves and fresh valve job
FIC 1200cc top feed injectors
Walbro 255lph fuel pump with pressure relief mod
Radium FPR
Parallel fuel rail system
Long runner TGVless intake manifold from a newer na impreza
Semi equal length discontinued exhaust manifold
Custom rotated uppipe with 38mm tial EWG
Grimmspeed 3 port
FP3794 turbo t3 hotside(dont remember the AR size)
Custom 4" intake with 9" K&N filter
Perrin 3" front mount intercooler
Custom downpipe
Catless exhaust
My custom plug and play IAT harness with a GM IAT sensor
AEM EGT gauge placed in exhaust manifold on cyl 4
DIY Cyl 4 cooling mod
Stock ECU tuned on a Dimemod patch running full speed density
I normally don't recommend trying to push the limits of pump gas. The owner of this car wanted to see what we could get away with on pump gas so I kept increasing boost until he said stop. I kept timing extremely conservative and watched the EGT gauge, at the top of 4th gear runs we saw about 1550*. This turbo was just starting to warm up at 26 psi, sadly the car didn't have a fuel system capable of pushing this turbo on E85.
