Welcome to the North American Subaru Impreza Owners Club Thursday January 27, 2022
Old 05-06-2007, 10:57 PM   #1
UpTown I-TS
Member#: 13594
2000 2.5 RS-T Coupe
Default HELP! Turbo timer to aftermarket Alarm Install (arming problem)
I am at a dead end with this unless someone knows the answer.
Alarm: Clifford Cyber 3
Turbo Timer: Blitz FATT
I am not able to arm the alarm untill the car is completely turned off. I have read on the forums somewhere to cut the green wire from the OEM Security module. I am running an aftermarket one.
Does anyone know if there is a way around it or know where i can find a wiring diagram for this alarm system (highly unlikely for theft purposes)
Thanks.
UpTown I-TS is offline   Reply With Quote
Old 05-07-2007, 02:12 PM   #2
dtang
Member#: 122001
2005 STi
On my 05 STi, what i did was wire the alarm ignition input wire to the key sensor wire. Basically instead of the alarm waiting for the ignition to turn off, it senses whether the key is still in the ignition.
dtang is offline   Reply With Quote
Old 05-07-2007, 03:08 PM   #3
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
you need to cut the ignition wire so that when the turbo timer is active, the alarm does not see voltage on the ignition wire.
now if the sensitivity on the alarm is set really high it may still trip the alarm from the vibration of the engine.
just need to pick up a relay and wire it like so:
thedaddyb is offline   Reply With Quote
Turbo timer and aftermarket alarm question litlechina Electrical & Lighting 2 04-04-2006 02:12 AM
turbo timer & aftermarket alarm ? billy boi Electrical & Lighting 2 03-09-2004 07:24 PM
turbo timer & aftermarket alarm ? billy boi Car Audio, Video & Security 1 03-09-2004 06:07 PM
updated single relay for turbo timer and aftermarket alarm!!! netZ Car Audio, Video & Security 3 06-03-2003 11:01 PM
turbo timer with aftermarket alarm REDOO2000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-30-2001 11:40 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
