Welcome to the North American Subaru Impreza Owners Club Sunday November 18, 2018
Old 08-09-2018, 11:01 AM   #1
joepep72
Member#: 464604
Default Need help!!
2014 Subaru STI
-Perrin exhaust
-Cobb downpipe
-Cobb Accessport
-Cobb Intake
-TGV deletes
-Air/oil separator
My Check engine light came on reading
-P0024 Exhaust cam2 (LH) system range/perf
I brought it to a well known Subaru performance shop and theyre telling me my oil was once probably really low ( which I wont lie. I might have neglected it once or twice) and that I need a full short block rebuild. He wants to charge me $8k and I cant really afford that at this time. I was wondering if maybe buying a used engine would be cheaper and if Im being overcharged for the rebuild? Id appreciate the help. Thank you
joepep72 is offline   Reply With Quote
Old 08-09-2018, 11:17 AM   #2
Stretch18
Member#: 239822
2010 WRX
pandiculation
$8k for an engine replacement at a shop is pretty much par for the course.
Did they say why they think it needs a rebuild though? That code does mean you might need new AVCS gears but jumping to full engine replacement without some other symptoms seems extreme...
Stretch18 is offline   Reply With Quote
Old 08-09-2018, 11:17 AM   #3
Stretch18
Member#: 239822
2010 WRX
pandiculation
double post, that was weird...
Old 08-09-2018, 01:52 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Agreed to a point.
Low or dirty oil can gum up variable cams/lift.
A couple short changes may free it up.
Pulling and cleaning the oil control valves may help.
Swapping the oil control valves and see if the problem follows.
No rod knock or similar (knock sensor will trip a code as the sound is similar to det) would make me think oil control not rebuild.
Charlie-III is online now   Reply With Quote
Old 08-10-2018, 04:03 AM   #5
iconojett
Member#: 489955
Thanks for sharing
iconojett is offline   Reply With Quote
Old 08-10-2018, 11:06 AM   #6
joepep72
Member#: 464604
Thank you for the help. The guy said my engine is a ticking time bomb. I could change some parts but he said the problem wont be fixed. He said it would be like putting a bandaid on the problem. Is he bull****ting me?
Old 08-10-2018, 03:36 PM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Originally Posted by Charlie-III View Post
Agreed to a point.
We don't know from where we are.
You have 2 decent replies.
I gave some inexpensive options.
If you ran low on oil long enough, yes, it may be a ticking time bomb.
Sorta your choice based on ideas posted and your gut and wallet.
Me, I would try cheap and easy, but maybe start saving some money.
But that is me.
Old 08-11-2018, 03:53 PM   #8
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
He kind of is...
Do an oil flush, stay on top of your maintenance, and worst case, you'll need a cam sprocket, maybe an OCV. That code does not indicate the engine is about to blow up.
CaptainSlowbaru is offline   Reply With Quote
Old 08-16-2018, 12:31 PM   #9
joepep72
Member#: 464604
Originally Posted by CaptainSlowbaru View Post
He kind of is...
Thank you for the help man. Will do.
