Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 09-21-2006, 02:44 PM   #1
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
Question Wiring the knock sensor directly to the SAFC, can it be done?
As suggested, I am posting this here instead of EMT because you guys probably dealed with this before.
I have a '95 Impreza, OBD1, with a '97 2.2L engine swapped. I installed an SAFC, as well as a pyrometer to give me an idea of what's going on as I make changes until I can afford an Innovate wideband.
The 2.2L has a knock sensor, but the OBD1 harness didn't consider it, so its currently just chilling there. I am uneducated as far as knock sensors go, but is there a way for me to get the sensor working so that I can monitor knock with the SAFC? How hard would this be, and what steps would be involved?
As I stated, I'm very uneducated with the sensor, and one of the sample numbers the SAFC manual gives for the sensor reading is 23. What does that mean, how do I read it?
I appologize for my n00bishness, but I appreciate any feedback you guys could give me.
t3hWIT is offline   Reply With Quote
Old 09-21-2006, 06:18 PM   #2
suby53
Member#: 59648
97' Legacy Outback
Yes you can! I had almost the same setup on my 95' L. I had a 2.2 with rex turbo and safc-2 for tuning. I just went and got the knock sensor out of the junkyard and wired it directly to the knock signal wire on the ecu. The only difficult part is knowing what the numbers mean. When I was at idle it sat around 8-14 and sometimes when I was on it at higher rpms it would bounce up to 260+. So unless you find out what the limit is its not very accurate but it gives you an idea.
suby53 is offline   Reply With Quote
Old 09-21-2006, 08:37 PM   #3
t3hWIT
Member#: 58779
95 STi RA (rhd)
How does the wire get any signal, considering that the sensor has no power going to it? As far as reading, what do the numbers mean?
Old 09-22-2006, 11:00 AM   #4
pregunta
Member#: 101577
You have to initially setup the SAFC to read knock correctly for your car. There is a acclimation(sp) process you have to do.
pregunta is offline   Reply With Quote
Old 09-22-2006, 08:18 PM   #5
t3hWIT
Member#: 58779
95 STi RA (rhd)
Ok. Do you know offhand if I can just go back now and do it? I didn't set it up the first time, a friend did it for me.
Old 09-23-2006, 02:36 PM   #6
suby53
Member#: 59648
97' Legacy Outback
Ya you can do it anytime. If I remember right its in the setup menu. I'm don't really remember where. But the sensor is just a little electric diode that sends its own signal and the stock ecu or safc interperet it into an electrical signal.
Old 09-24-2006, 12:10 AM   #7
t3hWIT
Member#: 58779
95 STi RA (rhd)
Ok, that works. I'll just have to dig out the wire, extend it, and plug it into the sensor. Thanks for all the info.
AT to MT swap can it be done??? viperrf16 Transmission (AT/MT) & Driveline 9 09-20-2006 11:08 PM
how to fix crab grass and wheat like weeds in the lawn? can it be done this late enozto Off-Topic 6 05-16-2006 11:02 AM
Dealer Bench testing o2 sensor? Can it be done? ShawnRS Normally Aspirated Powertrain 1 11-21-2004 07:13 PM
Crazy Idea for UK lights. Can it be done? has it been done? TeamASR Interior & Exterior Modification 13 10-25-2002 09:52 AM
2.2 to 2.5 engine swap, can it be done? Caron Normally Aspirated Powertrain 1 11-20-2001 12:15 AM
