Welcome to the North American Subaru Impreza Owners Club Tuesday January 15, 2019
Old 04-20-2010, 12:41 PM   #1
Surestick
Member#: 196594
2002 Outback Sport
Default Darn it... Just stripped the threads on the bolt that holds the knock sensor in.
It's Heli-Coil time I guess...
Bloody thing was in tight or corroded in. When I installed the new one with the torque wrench it just kept spinning.
Anybody know the thread size for the helicoil?
Surestick is offline   Reply With Quote
Old 04-20-2010, 04:59 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Should be M8x1.25mm.
In the meantime, there's another hole on top of the bellhousing. Put the KS there until you fix the other threads.....and I'd put the torque wrench away. I don't think it's critically necessary for that.
Jay
Old 04-21-2010, 05:47 PM   #3
Surestick
Member#: 196594
2002 Outback Sport
Thanks!
Old 04-21-2010, 06:28 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
If you didn't rip out every last thread and make it perfectly smooth, I would personally just get some threadlock or some silicon and coat the bolt with it and screw it in there. Just keep an eye on it for the next week or two to see if it's holding. If it works loose, you'll know it because you'll throw a knock sensor CEL and the car will run like crap. It can't hurt anything...
wanted: anyone have the stock oem bolt that holds the red intake manifold on the head 949 SCIC Private Classifieds 3 07-30-2009 10:30 PM
6 speed where is the 6m 1.0 bolt..that holds the clutch fork 04 Slo Sti Transmission (AT/MT) & Driveline 14 06-27-2008 10:04 PM
Size of 2 bolts that hold the driveshaft in the middle of the car jefersun Transmission (AT/MT) & Driveline 5 03-25-2004 08:44 AM
The 6 bolts that hold the waterpump down White 2.5rs Private 'For Sale' Classifieds 4 12-19-2003 02:13 PM
Got some new toys today. Then broke the bolt that holds the neg battery terminal down Kwyjibo Southern California Impreza Club Forum -- SCIC 2 02-12-2003 03:21 AM
