07-26-2021, 10:27 PM | #1 |
Member#: 50072
South East
Vehicle:2017 STI Blue |
Killer B Hard Inlet
Items on the left are included, items on the right were purchased separately:
Crawford/IAG AOS Options: I received my Killer B hard inlet last week and I'm in no rush to install it since it's F'ing hot outside, so I took the liberty to ensure that I had everything needed to make it work with my Crawford AOS. If you have a Crawford or IAG AOS, you'll likely want fittings with a 1/2" barb. Threads on the inlet are all 1/4" or 3/8" NPT according to the instructions in the "Additional Information" section on the product's page. Some black plastic/nylon fittings would be nice, but this is what I ordered from Amazon to get started with: B07CRWC42C - EDGE INDUSTRIAL 1/2" Hose ID to 1/4" Male NPT MNPT 90 Degree Brass Elbow Fitting Fuel / AIR / Water / Oil / Gas / WOG B07CRTM8P7 - EDGE INDUSTRIAL 1/2" Hose ID to 3/8" Male NPT MNPT 90 Degree Brass Elbow Fitting Fuel / AIR / Water / Oil / Gas / WOG B07CPH3L85 - EDGE INDUSTRIAL 1/2" Hose ID to 1/4" Male NPT MNPT Straight Brass Fitting Fuel/AIR/Water/Oil/Gas/WOG This should give me enough hardware to figure out what I'm going to do during the install process, I'll hunt for pretty fittings later. How well would high-temp spray paint hold up on these brass fittings? Hoping to see other peoples' installs before I go in. |
07-27-2021, 12:23 PM | #2 |
Member#: 13530
Vehicle:EA63 , EA81T, EJ20G, EJ205 |
Nice looking part, I'm looking forward to reading people's thoughts and install notes.
07-27-2021, 12:25 PM | #3 |
Member#: 508105
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
Just got mine as well. Got it with a 3" and 2.4" coupler so I can use it on my 20G-XTR now and GTX3576 G2 later.
Love the way killer B made it modular. |
07-27-2021, 12:53 PM | #4 |
Member#: 450713
Vehicle:2017 WRX Stage 3ish world rally blue |
Do you actually expect any noticable gains from this part? or is it just for reliability and high hp builds mostly?
07-27-2021, 12:55 PM | #5 | |
Member#: 508105
And going with metal over silicone allows the inlet to avoid collapsing, and it allows the walls of the inlet to be thinner, allowing for more flow via a larger cross-sectional area. And thats ignoring that the OEM inlet WILL rip on you at some point... Here is Killer B's testing against the OEM inlet with Bren tuning on a Mustang Dyno: Last edited by K3rm1tth3fr0g; 07-28-2021 at 01:36 PM. |
07-27-2021, 05:56 PM | #6 |
Member#: 420364
Vehicle:2013 STI Hatchback Black |
What was the purpose of buying the other elbows? The killer b is supposed to fit into an oem system and the aos is supposed to fit an oem intake isn't it? Just curious because I have both but neither is installed yet.
07-28-2021, 01:16 PM | #7 | |
Member#: 50072
South East
I think the included fittings work with most of the stock hoses and the Killer B AOS, however, it does not include the fitting that would connect to the inlet near the turbo, so it requires at least one additional fitting to work as a completely stock replacement. The IAG and Crawford AOS both require two connections to the inlet, since those AOSes use 1/2" hose to the inlet, you might want to consider ensuring you have the necessary fitting unless you're fine with using an assortment of hose sizes and union/reducer connections to make everything work. |
07-28-2021, 02:07 PM | #8 | |
Member#: 420364
08-06-2021, 04:26 PM | #9 |
Member#: 420364
Just a heads up, be very careful with the brass going into aluminum. Even with teflon tape my fitting galled up and ripped out some threads of the inlet when I tried to remove it. I just purchased some plastic fittings that will be here tomorrow so we'll see how that turns out instead.
08-06-2021, 05:19 PM | #10 |
Member#: 447898
BAIC
Vehicle:2022 Tesla M3P 2019 STI CWP |
I have this sitting in my garage waiting to be installed as well.. way too hot in Califronia right now to be installing this in my garage
08-06-2021, 06:38 PM | #11 |
Member#: 420364
08-06-2021, 06:41 PM | #12 |
Member#: 508105
08-06-2021, 07:48 PM | #13 |
Member#: 420364
08-07-2021, 08:28 AM | #14 | |
Member#: 50072
South East
08-07-2021, 10:52 AM | #15 | |
Member#: 420364
08-07-2021, 12:25 PM | #16 | |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
NPT threads DO need sealant or teflon tape because the root of the tread is square, leaving a gap, even when tight. NPTF (Fuel) can be tightened without sealant or teflon because the root of the thread is radiused, so there's no air gap when tight. <---- fastener dork |
08-07-2021, 05:19 PM | #17 |
Member#: 50072
South East
Thanks for the thread explanation.
I went down to the garage and inserted and removed all of my fittings a few times and they do seem to go in far enough when finger-threaded. The starting thread on one of my Amazon fittings had some roughness in it that might have affected its ability to smoothly thread in, so I cleaned that up and it's looking good. Pardon me, I'm thread shy. I don't wanna tear this up. Was considering installing this week, but I got stuck with on-call again. |
08-13-2021, 10:22 AM | #18 |
Member#: 524797
Vehicle:2010 XT Forester |
Appears there are issues with the 3” inlet forming a golf ball sized collapse when installed. Hopefully the smaller silicone joiner don’t suffer the same fate. Last edited by tmp042; 08-22-2021 at 09:21 AM. |
08-13-2021, 11:52 AM | #19 |
Member#: 420364
My OEM size looked fine. I'll take a look again when I install everything back on. I had a breather hose spit on me and spit oil everywhere so it its currently apart again.
08-13-2021, 12:38 PM | #20 |
Member#: 524797
Killfire, Do you have a photo from above of the Killer B intake installed onto the compressor housing. Curious to see how it fits around the TGV.
08-13-2021, 02:40 PM | #21 |
Member#: 420364
08-13-2021, 12:04 PM | #22 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
is it just me or can you loosen the clamps to let it onto both the turbo and the inlet more?
08-19-2021, 09:43 AM | #23 |
Member#: 198281
The coupler fitment is the most challenging part of the install. It's going to take several trial and trim, and trial and clock fits to get it right. The is a part of the installation where patience is your friend because you can only trim off so much before you're in trouble.
If you need another coupler, we do offer them individually. |
08-19-2021, 03:09 PM | #24 |
Member#: 420364
The first picture was taken before any trimming done and was just doing a test fit.
The second picture is everything installed and running. It does touch on the corner of the IM and TGV and I couldn't figure out a way to prevent that. I talked to Killer B and they said it shouldn't be a problem. I do have IAG TGV deletes installed so the stock TGV housing may fit differently. |
08-20-2021, 04:12 PM | #25 |
Member#: 50072
South East
I'd buy a JDM long runner intake manifold if it worked with a DBW throttle body. That TGV bolt area is the most annoying part of installing an inlet.
