Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 09-27-2011, 06:12 PM   #1
mjyeams
Member#: 111236
2010 WRX Hatch
Default Rod knock on cold start?
So on Monday of last week, I left for the beach, but took my girlfriends car for the trip. My 2010 WRX sat parked on the street for 5 days and when I got home just this past Saturday I started it up to make a trip to the grocery store. Upon starting the car, I got a horrible knocking sound from the engine that quickly tapered off after a few seconds as it settled into a normal warm up idle.
I spun a rod bearing in my old 2000 Impreza RS and the sound my WRX made when I started it sounded exactly like the RS engine after the rod bearing spun. However, after that initial start up the WRX has sounded fine and been running perfectly fine. Has this happened to anyone else? I'd really appreciate some input as to what you all might think have caused the engine to do that and maybe some things I should do to troubleshoot? I have a couple friends with 2009, 2010, and 2011 WRX's and all of them have left their car's sit for over a week without starting at one point or another and never had anything like this happen....
Thanks!
mjyeams is offline   Reply With Quote
Old 09-27-2011, 07:16 PM   #2
kuntryquest
Member#: 278027
2005 Legacy GT
Pearl
Synthic oils are actually so slippery that it will "slide " down and away from things. The hotter the weather the worse it is.
kuntryquest is offline   Reply With Quote
Old 09-27-2011, 07:26 PM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
i don't even know where to start...
Old 09-27-2011, 11:55 PM   #4
atomicfire
Member#: 136296
2005 STi
This is a pretty well documented issue - a lot of Subaru people report minor knock on cold starts after the car as been sitting for a while and in very cold weather. It did it to me on my 05 STi once in NJ on a cold winter morning at 0F and happened to my gf's 08 STi in Colorado on a -20F morning. The important thing is that the knocking goes away quickly. If it lingers for more than a few seconds then you have a problem. If it goes away quickly, you're fine. Don't worry about it; if it does bother you take it to the dealer and have them look it over and document it in case it does turn into trouble.
atomicfire is offline   Reply With Quote
Old 09-28-2011, 07:10 AM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I've not heard of anything like this except in very cold weather. What oil viscosity are you using?
It might not be a bad idea to check a known issue on these cars, the OEM oil pickup (PICS HERE). A cracked oil pickup can cause delayed initial oiling (when cold), low pressure at idle and reduced pressure at cruise/load. It's a pain to check, but much easier than replacing an engine.
KillerBMotorsport is offline   Reply With Quote
possible piston slap or knock at cold start?? Flyin_Hayn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-31-2009 04:57 PM
Rod knock on cold start blitzmr2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 06-19-2008 10:38 AM
Knock at cold start shm777 Normally Aspirated Powertrain 13 03-19-2005 06:41 PM
Brake / Clutch Knock Noise on Cold Start -AliasMunky3- Brakes, Steering & Suspension 1 01-25-2005 02:00 PM
Knock with cold start jetsiphon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-26-2003 12:53 AM
