Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Go Back   NASIOC > NASIOC Classifieds > New Product Development
Old 05-09-2014, 04:53 PM   #1
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default Oiling System Feeler: Racecars Only... Oil Control Valve
Attention! This is not a product that would EVER be needed on a street car.
It is a product for racecars, specifically boxer engine cars, able sustain +1.5Gs consistently. If you are unsure if you have a 'racecar' ask yourself some simple questions. Does my car have a true safety cage? Does my car run race slicks? Do I have a competition license? If you do not answer yes to all 3, this product would very likely be utterly useless for you. If you did answer yes to all 3 please read on.
The Subaru boxer platform can have issues with oil surging in the heads. It can be related to the level of performance, driving style, track conditions and so on. This burden is often overwhelming to the PCV's A/O separator or Catch Can system causing them to fill. Filling an A/O separator or catch can causes oil levels to drop increasing the potential for oil starvation. Another condition is if a catch can fills, and overflows onto a hot engine and/or exhaust system creating a fire potential, which has been known you happen.
This product feeler is for a product that prevents oil flow out of the valve cover ports based on the lateral forces placed on the car. This design has been successfully used in aerobatic aircraft for years and we have adapted the design to be suitable for lateral loading vs inverted flight (which rarely happens in cars). Under straight line acceleration, braking and moderate cornering the PCV vents work just as they normally would; letting blowby gasses vent from all ports. Under severe lateral loads the port from the surging head (facing the outside of a corner) is closed, not allowing oil to pass into the A/O or catch can setup. The balance ports and remaining head and crankcase ports still operate as normal. This has no negative effect on the engine or engine performance, while assuring blowby gasses ONLY are permitted through the PCVs ports.
This product design has been discussed for years and now we are putting rubber to the road. Before doing so we're looking for feedback from the communities to gauge interest, and in turn, production levels.
Please feel free to voice your thoughts, concerns or questions. We'll do our best to answer everything as best we can.
Thanks!
Old 05-09-2014, 05:21 PM   #2
Murphdog
Member#: 75414
2004 STi
Its the Blue one
I'd love to see something like this come into production.
Murphdog is offline   Reply With Quote
Old 05-09-2014, 05:33 PM   #3
DisoDisp
Member#: 187648
2007 WRX
there could be a market for that, oil comes flying out of some catch can systems on the track.
DisoDisp is offline   Reply With Quote
Old 05-09-2014, 06:29 PM   #4
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
#Winning
Crystal_Imprezav is offline   Reply With Quote
Old 05-09-2014, 06:42 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
I can put this to use immediately.
Jay
Old 05-09-2014, 09:38 PM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the feedback guys!
Old 05-09-2014, 10:39 PM   #7
wantsti
Member#: 134764
04 sti
java black pearl
Would this be useful for autox?
wantsti is offline   Reply With Quote
Old 05-10-2014, 09:09 AM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Not really. In Auto-X we really don't see the same combination of forces and RPM that are seen in road course racing.
In Auto-X when oil is seen in the venting system it is due to sloshing, not surging. This can be solved by changing plumbing routing. A cheap and easy fix
Old 05-10-2014, 09:59 PM   #9
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Not sure if the 1.5 G's applies to rally cars, but as slideways as we get, I would assume this system would work for us as well. And I definitely would be in line for this type of system.
Question that just popped up in my head, since we transit in between stages for up to 70 miles, would your system have any effect on "normal" driving.
recce02 is offline   Reply With Quote
Old 05-10-2014, 10:33 PM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yes, under normal driving it operates just as normal, all 3 ports venting. The ONLY time the valves come into play is under severe cornering.
Old 05-11-2014, 12:23 AM   #11
thisisthenewsic
Member#: 156829
05 crosstrek, gc8
cool grey khaki, silver
in for more info!
thisisthenewsic is offline   Reply With Quote
Old 05-11-2014, 02:15 AM   #12
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Killer B's Breather Balls?
ASF Machine is offline   Reply With Quote
Old 05-12-2014, 09:20 AM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by thisisthenewsic View Post
in for more info!
What would you like to know?
Old 05-12-2014, 05:48 PM   #14
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
Would the valves close based on inertia? Ie, would only the valve on the head that is oriented to the outside of the corner close? I see no reason to close both valves at the same time.
The Satch is offline   Reply With Quote
Old 05-12-2014, 09:00 PM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The port going to the head facing the outside of a corner is close only, not both.
Old 05-16-2014, 08:36 PM   #16
Scargod
Member#: 260314
2007 STI
silver gray metallic
Could this product be helpful with oil control to the point that it might lessen the need for a dry sump setup? I'm think in terms of my 818R.
Scargod is offline   Reply With Quote
Old 05-18-2014, 09:42 PM   #17
0STI6
Member#: 248230
03 JDM STI
just trying to get my head around this,
where r these ports fitted, do they stop oil pooling in the head or stop the oil in the heads from entering catch cans??
0STI6 is offline   Reply With Quote
Old 05-18-2014, 07:59 PM   #18
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Depends on how you determine the need for a dry sump. This product will prevent oil from surging out of the heads and into the PCV system.
Old 05-18-2014, 09:54 PM   #19
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Stops the oil from entering the can, or A/O separator, via the head ports.
Old 05-19-2014, 12:45 AM   #20
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
You know I am in Chris
Old 05-19-2014, 10:59 PM   #21
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
I think this would go great on our rally car aswell.
robbieshonda is offline   Reply With Quote
Old 05-22-2014, 10:30 AM   #22
ASF Machine
Member#: 236349
1993 Impreza
OD Green
So is this going to be something similar to an inverted flight breather setup?
Old 05-22-2014, 11:29 AM   #23
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ No, this does not use floats. Thought about going that route, but I'm not convinced it's the better method with intermittent loading at the threshold of activation.
Old 05-22-2014, 12:01 PM   #24
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
I'm interested to hear more.
Old 05-27-2014, 08:14 AM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ What else would you like to hear?
