Welcome to the North American Subaru Impreza Owners Club Saturday April 10, 2021
Go Back   NASIOC > NASIOC Classifieds > New Product Development
Old 10-13-2015, 12:40 AM   #76
moto55yz
Member#: 170700
2004 wrx sti
Java Black Pearl
Originally Posted by brcewane View Post
The 04 STI is cable driven like my bugeye. I'm working on a way to retrofit the 05 servos into a cable driven Impreza so that you could do the 05 console swap and use our 10.1" kit.
I posted details on the parts list a few posts back and i'll post up details on the swap as I retrofit the parts in my bugeye.
After doing some research, it turns out the 04 Sti does have electronic climate control. You can see the electrical harness connection on the back of the dials in this picture.
The question is whether the 05-07 Sti climate control harness is the same as the 04 Sti?
moto55yz is offline   Reply With Quote
Old 10-13-2015, 01:24 PM   #77
Workshop12
Member#: 423858
Flat Gray
Attachment 75397
Ah right, my mistake. The 04 STI's had the first generation of automatic climate control. I don't believe it had all of the sensors that the 05 did.
Workshop12 is offline   Reply With Quote
Old 10-13-2015, 09:26 PM   #78
Below100hz
Member#: 354505
2004 STI
Java Black Pearl
2004 STi has semi auto climate control. auto controls fan speed, a/c, recirc, but not vent zone.
I'm not familiar with the 04 to 05 console swap, but I wonder if it becomes full auto with the 05 HVAC unit?
Below100hz is offline   Reply With Quote
Old 10-14-2015, 03:03 PM   #79
Kenmichi
Member#: 329599
2004 STI Aspen White
2015 Jetta TDI
I have an '05 console swap into my '04 and I notice a slight change in zone venting when I set it to automatic. However, I find myself still manually controlling it for faster response. Which means it doesn't actually work or it doesn't work as well as newer models.
I'd love to beta test one to see if we can roll out some kinks.
Kenmichi is offline   Reply With Quote
Old 10-15-2015, 09:24 AM   #80
Workshop12
Member#: 423858
Flat Gray
As a FYI, I posted some details on climate control retrofits for 02-04's over in the feedback thread in audio/video
http://forums.nasioc.com/forums/show...1#post43872771
Old 10-27-2015, 10:44 AM   #81
Workshop12
Member#: 423858
Flat Gray
We're now in the last week of our discount qualification period. If you haven't done so already make sure you sign up for our Newsletter by the end of day October 31st (GMT) to be registered for 10% off of your first order
https://brainiac.workshoptwelve.com/
Old 10-28-2015, 04:31 PM   #82
Workshop12
Member#: 423858
Flat Gray
We just posted up a new editorial covering our views of the importance of great embedded electronics to create an environment for innovation in the in-car experience. We titled it "Your Car is More than Just an Accessory for your Phone". We hope you enjoy it!
Blog Post
http://workshoptwelve.com/2015/10/28...or-your-phone/
Old 10-30-2015, 01:14 PM   #83
iainb
Member#: 391762
2015 STI Launch Ed.
2016 Golf R (wife's)
Very cool but I'll be really interested when you are making parts for the VA chassis.
iainb is offline   Reply With Quote
Old 11-02-2015, 01:57 PM   #84
Workshop12
Member#: 423858
Flat Gray
We're still working through the button designs and hazard button placement, but I thought I share a quick rendering with everyone.
Since space is a premium in the FRS/BRZ we're looking at using the same buttons as are used with our double-din 7" unit. The below rendering doesn't yet show the "grills" on both sides of the buttons (for the microphone and cabin air temperature sensor).
We're also still working on the hazard switch relocation to the far right of the bottom pocket that will re-use the AUX port opening. We should have some designs of that area to share soon
Old 11-02-2015, 02:32 PM   #85
Workshop12
Member#: 423858
Flat Gray
Our early supporter 10% discount offer closed on the end of day October 31st. Thanks again to everyone for their support in making Brainiac a reality!
Blog Post
http://workshoptwelve.com/2015/11/02...er-now-closed/
Old 11-12-2015, 02:55 PM   #86
Workshop12
Member#: 423858
Flat Gray
Another design update for the BRZ/FR-S. To get a better viewing angle we've started to move out the bottom "chin" of the display. This should allow us to tip the top of the screen back a bit more.
It will create a bit of an overhang over top of the lower pocket, similar to how the vertical "bars" between the toggle switches stick out a bit on the BRZ climate control.
This drawing also has the beginnings of the circular design for the hazard switch that will snap into the existing AUX input location.
Goal is to be starting the 3D printing of prototype plastics next week so that we can do some test fitting
Old 11-15-2015, 11:30 AM   #87
zach90
Member#: 425690
2007 Sti
Urban grey metallic
What is the pre-amp output voltage?
zach90 is offline   Reply With Quote
Old 11-15-2015, 11:39 AM   #88
Workshop12
Member#: 423858
Flat Gray
It's not 100% finalized yet, but the current spec is 4V on the preouts
Old 11-16-2015, 04:59 PM   #89
Workshop12
Member#: 423858
Flat Gray
Ooops.. double post
Old 11-16-2015, 05:00 PM   #90
Workshop12
Member#: 423858
Flat Gray
Here's another up close and personal shot of the 05-07 WRX/STI install
Old 11-16-2015, 05:55 PM   #91
zach90
Member#: 425690
2007 Sti
Urban grey metallic
Default Pre-orders
When will pre-order codes be sent out and when will the actual purchasing begin?
Old 11-16-2015, 06:13 PM   #92
Workshop12
Member#: 423858
Flat Gray
Discount codes will be sent out once the pre-order goes live... which should be very soon
Old 11-16-2015, 06:40 PM   #93
bootleg22bGC8
Member#: 262782
any plan on making it for the 15+wrx/sti ?
bootleg22bGC8 is offline   Reply With Quote
Old 11-19-2015, 10:07 AM   #94
Workshop12
Member#: 423858
Flat Gray
We do have plans... but we need to get our pre-orders rolling for our other vehicles first so that we have the capital to start in on more vehicles
Our pre-order campaign will be starting VERY soon
Old 11-19-2015, 10:07 AM   #95
Workshop12
Member#: 423858
Flat Gray
Another milestone reached for the BRZ/FR-S! We now have the initial 3D models available for 3D printing and test fitting. These are not the final plastics, but are meant to give us a model to test out proportions and fit in the dashboard.
So there will still be more revisions to come to incorporate all of the details from the final sketches. There's lots of 3D renderings in the blog post so check them out and let us know what you think
Blog Post
http://workshoptwelve.com/2015/11/19...-models-ready/
Old 11-20-2015, 02:35 PM   #96
Workshop12
Member#: 423858
Flat Gray
We're excited to announce a third option for those wishing to custom install a 10.1" Brainiac unit into their dashboard. The 10.1" Brainiac Retrofit Kit!
Blog Article
http://workshoptwelve.com/2015/11/20...-retrofit-kit/
Old 11-21-2015, 09:21 AM   #97
Workshop12
Member#: 423858
Flat Gray
We're getting very close to launching our Brainiac preorders on Kickstarter. We just posted a blog article to give more details on what to expect and how early supporters will redeem their 10% discount
Blog Post
http://workshoptwelve.com/2015/11/21...for-preorders/
Old 11-26-2015, 09:24 AM   #98
Workshop12
Member#: 423858
Flat Gray
The FR-S/BRZ plastics are out of the printer and we're hard at work getting them sanded and prepped for paint. We're getting really close to test fitting these so that we can get a better idea of how it all looks and fits in the car!
The top piece was too long to fit in our printer, so we had to print it as two separate pieces and then join them back together.
Old 11-26-2015, 05:21 PM   #99
Workshop12
Member#: 423858
Flat Gray
Still working on the FRS/BRZ prototype plastics for the 10.1" Brainiac snap-in kit.
A few more rounds of filler primer and sanding are needed. But we're getting closer to paint!
Old 11-27-2015, 10:31 AM   #100
Workshop12
Member#: 423858
Flat Gray
We've posted up our lower pocket designs for the Scion FR-S and Subaru BRZ to relocate the hazard switch. Our current direction is to pursue design 5.1
Check out all of the different designs and let us know if you think we're on the right track!
Blog Post
http://workshoptwelve.com/2015/11/27...pocket-design/
